Snowflake6515
Score: 100 Joined: 1/7/2008 Last Login: 5/20/2013 From: Wells,
ME, USA Status: offline
Mr. G, so glad it worked out for you. I'm starting to think I understand the -18 programming when you have multiple servos on a control surface. I look at the DEFAULT mapping (even though you can override it via channel assignment...) because one of the pair will provide normal throws and the other of the pair provides a reversal on the other surface. E.g., with dual ailerons, normally, the left aileron goes into the AIL channel on the rcvr and is assigned channel 2, whereas with dual flaps, the right flap goes into the GEAR port and the left flap goes into an AUX port (depends upon whether you have retracts...). Thus, in mixing, LAIL will have the ailerons move as normal; i.e., one up, the other down, whereas mixing RAIL, both will go up or down, together. With dual flaps, mixing RFLP will have them behave as normal, but mixing LFLP will have them moving in opposite directions (as flaperons...) I forget the dual elevator mixing, but, and I could be completely wrong, I would look at the DEFAULT assignment of which elevator half is assigned to the standard rcvr ELE channel and I bet that one, when mixed, will provide for both elevator halves moving up/down, but mixing the other half would provide for split up/down movement (for vectored thrust effects would be my guess.) The other key point I am learning is that the mixes are based on FUNCTIONALITY and not the STICK or the concept of AILERON, ELEVATOR, etc.; hence LAIL, RAIL, LFLP, RFLP, etc. E.g., for my Habu 32 EDF, with variable nosewheel steering sensitivity, I had to use two mixes: one PMIX between RUD and AUX4 (for the nosewheel steering servo) and a second PMIX for RUD and AUX4 for the increased (or decreased) sensitivity. I had tried to use channel assignment capability to "copy" the rudder to aux4, but then I could no longer increase/decrease aux4 with a SINGLE mix as AUX4 was no longer listed as a destination option, but "rudder" was. Slowly, it is coming together, but I do agree that the programming examples in the manual leave a lot unstated. Andy did recommend that sailplane folks go to Kennedy Composites site and look at the template and PDF instructions for the -18. I did that, even though I have a rather simple/brain-dead glider, as there was a wealth of information WITH explanations about mixes with dual ailerons, flaps, etc. It was worth a look/read. It will come. Andy had told me that it will "click" and I have to admit that more and more of my first programming setups are now working, or, within a minute or two, I know what I did wrong and can get it right. Not an expert, by any means, but starting to get it. :-) Good luck and stick with it. By us all pooling our learning experiences, we may wind up with an on-line "programming manual for dummies" that others can use. :-) Michael
Hide Signatures
