RE: Spektrum DX18    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Spektrum DX18
Page: <<   < prev  14 15 16 17 18 19 20 [21] 22 23   next >   >>
Login
RE: Spektrum DX18 - 9/13/2012 3:59 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
its s smorgasbord radio.. my setup is Basically the same as 12X..I use E for smoke, because it was Aux2 on the 12x and learned it that way.. some guys use sliders or B or the button for smoke.. Its cool that you can do it anyway you want... Make it like you learned your old one because you will have less chance for a switch error at a critical time.With the 12chan, it doesn't matter what channelization you use.. The pain of setting it up helps you learn it and learn what you want..
As far as throttle trim, you can use the digital trim and the kill button, or the slider.. I prefer the slider..because the kill button is also the trainer button... , which is also why its not smoke or brakes...
I put my gyro and smoke on 11/12 because i dont look at them in the monitor .. the first 10 show on the first monitor page...11+ show on the Xplus page..
Once you get a baseline model setup, then just copy it over and over and change the config... do that before you bind to a new model because if you change wing config, it will steal channels...it takes some trial and error to get it done...
_____________________________
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to alasdair)
       Post #: 501
RE: Spektrum DX18 - 9/13/2012 5:43 PM
madmodelman
Score: 110
Last Login: 5/25/2013
Status: offline
I suggest you use H for throttle cut, easier to find in a panic situation!
Gary.
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
       Post #: 502
RE: Spektrum DX18 - 9/13/2012 8:05 PM
Gordon W
Score: 105
Last Login: 5/24/2013
Status: offline
Has anyone used the TM1000 telemetry module to check out their Rx's minimum input voltage reached during a flight?
I had nine 7-8 minute flights today and after every flight I found that my so-called voltage-stabilized Powerbox Sensor switch showed a minimum voltage of 5.4V compared with the resting voltage of 5.8V. Evidently the current draw of the servos was sufficient to pull down both linear regulator voltages by 0.4V each, which suggests to me that the max current capacity of the regulators was being approached. There is no mention of any voltage drop to be expected under load in the Sensor Switch user manual. The provided Sensor output leads connect directly into the Rx so there's no extra resistance in circuit.
Since I was only wringing out a li'l Wren 44 Gold powered Boomerang Nano for which I wouldn't expect the servo current draw to be particularly heavy, I'm wondering if my Sensor Switch is somewhat below par. Or perhaps this voltage drop is simply a feature of linear regulators under any sort of load.
The flight log data showed only minimal numbers of fades on the AR9000 and two remotes and no frame losses or holds, so it was good to confirm that the radio link was secure at all times.
Gordon
Hide Signatures
(in reply to madmodelman)
       Post #: 503
RE: Spektrum DX18 - 9/13/2012 8:59 PM
Colin_Mc
Score: 100
Last Login: 11/11/2012
Status: offline
Alisdair,
If you think of the channels as 1 to X and stick them in where you logically want them to go then you'll get along much better.  Then in the system menu you assign the channels to the functions you have connected them as.
The only exception to this rule is the inbuilt mixes, such as flaperon or 4 chan aileron etc as these have specific channel assignments.
Cheers,
Colin
Hide Signatures
       Post #: 504
RE: Spektrum DX18 - 9/13/2012 9:04 PM
alasdair
Score: 113
Status: offline
Hi Colin,
Are you home at the moment?
What aircraft have you installed on the DX18?  And which Rx?
Hide Signatures
(in reply to Colin_Mc)
       Post #: 505
RE: Spektrum DX18 - 9/13/2012 9:08 PM
Colin_Mc
Score: 100
Status: offline
 Gordon,
A linear reg is basically a variable resistor with heat being the  waste product so I'm guessing that  coupled with the fact that they are not very efficient might explain the 0.4v drop when under load?
Hide Signatures
(in reply to Gordon W)
       Post #: 506
RE: Spektrum DX18 - 9/13/2012 9:31 PM
Colin_Mc
Score: 100
Status: offline
Alasdair,
Back from France tomorrow (Fri) and I have all aircraft that i own on the DX18, including viperjet, boomer and my 110cc ultimate with smoke.
Give me a phone/pm if you have any questions.
Colin
Hide Signatures
       Post #: 507
RE: Spektrum DX18 - 9/14/2012 7:08 PM
gooseF22
Score: 103
Status: offline
.4 is actually alot for a Nano, for regulator drop.. hook up an ammeter and check all your surfaces and gear/brake servos.. the most common culprit is the gear servo being not set right..
Goose
Hide Signatures
       Post #: 508
RE: Spektrum DX18 - 9/15/2012 9:56 PM
Gordon W
Score: 105
Status: offline
The 0.4V is more than I expected. With this telemetry system it's necessary to reset the min Rx volts reading after switch-on and before flight as otherwise it will read low to begin with. The micro retract servo only operates a Clippard SMTV-3 air switch and there's no binding at servo endpoints. I remember seeing a servo current ammeter advertised somewhere but can't remember where.
Hide Signatures
(in reply to gooseF22)
       Post #: 509
RE: Spektrum DX18 - 9/16/2012 9:53 PM
gooseF22
Score: 103
Status: offline
You can use a watt meter, just plug between battery and reg.. might have to make some adapters.... I just use my watt meter most of the time and do trial and error.. just to make sure.. most jets are around .2 to .6 amps at idle. depending if there are gyros and such.. Flaps are also a common culprit at the full up, there is often high current if the settings are over driven to the stops.. brakes too.. just cycle everything and eliminate that from the equation and then you will also know the idle current..
Story: I was helping a buddy set up a jet with 1 A123 2300. on a fully charged battery, we set up all the flight controls, but I assumed the other stuff was set.. the jet wasn't buzzing or anything.. we had it on for a bit... we went and flew it once.. all well... After that, we charged it and the battery held 2000mah.. we were about to lose the jet.. culprit: binding servo, but not enough to buzz.. idle amperage was 2.4 amps... we were lucky.. keep troubleshooting.. you will find it..
Additionally, I would recommend you plug a Cricket into the Box.. it has a voltage tell tale and its really accurate..cheap.. fromeco.org... I use the cricket on most new jets.. it blinks at the lowest voltage seen... I have seen descrepancies between the telemetry min V and the cricket.. I believe the cricket...
Goose
Hide Signatures
       Post #: 510
RE: Spektrum DX18 - 9/17/2012 7:12 PM
Gordon W
Score: 105
Status: offline
Thanks Goose. I've used a Super Whattmeter for years for electric flight but never thought that it'd be particularly accurate for low currents. Looking at the specs on the Astroflight website I see the resolution is 10mA, so it should give a worthwhile estimate of current draw and I'll give it a try.
Best regards
Gordon
Hide Signatures
       Post #: 511
RE: Spektrum DX18 - 9/19/2012 11:11 PM
Gordon W
Score: 105
Status: offline
Still talking about PB regulators, the Gemini in this instance, I flew my GP Ultimate 160 today with telemetry installed for the first time. The plane has a pair of 2S 2200 lipos into the Gemini and it has seven 20kg servos on the surfaces (overkill I know and not overworked in this plane with a Saito FG-36 gas engine, but I wanted titanium gears) and a low-power digital on throttle. After all three of the flights during which it was aerobatted quite hard, the telemetry indicated that there had been a 0.4V voltage drop on load during each flight. No more than 0.4V, and no less either.
So its beginning to look as if the 0.4V volts drop on load is a feature of the PB circuitry.
I'm really liking the telemetry. It told me that even with the flea-power of the Saito compared with the 50cc 2-strokes most guys fit in this plane, it would perform a 600ft vertical climb, and I was astounded at the way the plane kept on clawing its way upwards.
I have the airspeed sensor and will try that on my 44-Gold powered Nano and Hawk .
Good ol' Spektrum!
Hide Signatures
       Post #: 512
RE: Spektrum DX18 - 9/25/2012 12:30 AM
marquisvns
Score: 115
Status: offline
Couldn't resist, got myself one of these last week
For some reason, in one of the models, I don't have "gear" selection (from wheel to everything else) in Gear channel under Channel Assignment within System menu, what am I doing wrong? I don't have any program mix associated with that channel either.
Thank in advance,
Barry
www.kingtechturbines.com
kingtechturbines@gmail.com
Hide Signatures
       Post #: 513
RE: Spektrum DX18 - 9/25/2012 12:54 AM
booker-RCU
Score: 100
Status: offline
quote:
ORIGINAL: marquisvns
For some reason, in one of the models, I don't have ''gear'' selection (from wheel to everything else) in Gear channel under Channel Assignment within System menu, what am I doing wrong? I don't have any program mix associated with that channel either.
Thank in advance,
Barry
Barry - I had some what of a simular problem. If you read posts 496 - 499 on this forum It should answer your questions. If not, I'm sure others can chime in and explain it further.
Regards - Galen
Hide Signatures
(in reply to marquisvns)
       Post #: 514
RE: Spektrum DX18 - 9/25/2012 5:17 AM
zonker123
Score: 140
Status: offline
What would be a good voltage low limit to set the RX battery telemetry at for A123 6.6 packs? My past experience has been that A123 will start out at 7.20 volts. I know that they have a flat discharge curve and that A123 don't respond well to load testing but they do drop off some and that around 6.2 volts or so they fall off the cliff really quick. I am thinking that setting the low limit alarm at 6.4 to 6.5 would be adequate.
Any thoughts?
thanks
mike
Jet Central Rabbit, Cheetah, and a Rhino.
Boomerang Jets Gang. Team 2DogR/C
Hide Signatures
(in reply to booker-RCU)
       Post #: 515
RE: Spektrum DX18 - 9/25/2012 5:22 AM
marquisvns
Score: 115
Status: offline
Thanks Galen, but I have confirmed that this has everything to do with my wing type selected with 2 Ail and 2 Flaps, which bumps the Gear and defaults Gear channel as L Flap, without gear selection. Anyone has this problem?
Hide Signatures
       Post #: 516
RE: Spektrum DX18 - 9/25/2012 7:40 AM
TimWatson
Score: 105
Last Login: 10/1/2012
Status: offline
Reading these posts I am wondering if this radio has issues or whether it is just people learning a new system with lots of channels etc ?
And so it is agreed. Whoever wins takes the horse 29716122118219
Hide Signatures
       Post #: 517
RE: Spektrum DX18 - 9/25/2012 9:00 AM
bcovish
Score: 1018
Status: offline
Like you I'm using the 2 ail and 2 flap which uses the gear channel as L flap. For the gear I plugged the retract servo into Aux 4 and assigned switch A to operate that channel. To get the where you assign which switch, go to Channel Assign in the setup menu, scroll to next, then in my case scroll down to aux 4 assign it to switch A.
Bob-O
Austin TX
Hide Signatures
       Post #: 518
RE: Spektrum DX18 - 9/25/2012 9:07 AM
bcovish
Score: 1018
Status: offline
quote:
ORIGINAL: TimWatson
In my case it was learning that all switches are assignable and you can assign any switch to do anything. Example, I don't like the digital trim on the throttle channel so I assigned the left slider as the throttle trimmer.
Bob-O
Austin TX
Hide Signatures
(in reply to TimWatson)
       Post #: 519
RE: Spektrum DX18 - 9/25/2012 9:11 AM
madmodelman
Score: 110
Status: offline
Barry, it's not a problem. If you select a wing type other than normal the tx automatically assigns the necessary channels and mixes needed.
Gear gets booted further down the line as the flight surfaces get priority. When all is said and done gear is not even a proportional channel so does not take priority.
Simply assign gear to a spare aux channel and the switch of your choice.
The whole idea is that the tx sorts it out for you when you tell it your wing set up, this can be appreciated more when things start getting really complex, I.e. multiple servos per surface etc.
Hide Signatures
       Post #: 520
RE: Spektrum DX18 - 9/25/2012 2:11 PM
rcavi8ter
Score: 100
Status: offline
Barry, If you activate dual aileron and dual flap it will use the gear channel. You can go into the channel assign under System set up. The first screen that comes up is RX port Assignments. In the lower right corner is next. The next screen is Channel Input config. You can assign one of the unused channels to switch A which is the typical gear switch. I hope this helps you out.
Chris Puckett
Horizon Hobby
Hide Signatures
       Post #: 521
RE: Spektrum DX18 - 9/25/2012 5:14 PM
Xantos
Score: 100
Status: offline
 Hi guys,
im setting up a Bobcat with the Spektrum 18X and a  Spektrum12020 receiver, TM1000
power supply is thru a Powerbox Gemini with 2 x 2300 mA LiFe packs.
ive plugged the TM1000 telemetry module into the data/bind port and batt 1 into batt port and batt2 into the srxl port
Ive selected the Powerbox option on the transmitter telemetry menu , but I get only a single battery voltage readout.
there is a single Rx batt voltage option with alarm options which I can't ddisable how do I get both pack voltages on my Tx ?
Xantos
Hide Signatures
(in reply to rcavi8ter)
       Post #: 522
RE: Spektrum DX18 - 9/26/2012 2:00 AM
marquisvns
Score: 115
Status: offline
Thank you all so much, your answers helped out a great deal. I have just started getting the gist behind it. It's probably easier to start anew from the rx, rather then what I was doing, trying to minimize alteration in the set up, just in case if I decide to go back to the 12x. But after playing with it some more, I think I'm liking the 18 pretty good and probably wouldn't worry about going back.
Cheers,
Barry
Hide Signatures
(in reply to Xantos)
       Post #: 523
RE: Spektrum DX18 - 9/26/2012 9:14 AM
madmodelman
Score: 110
Status: offline
Barry, I know exactly what you mean, I admit to thinking like you were, I was a bit annoyed that the thing was swiping my gear channel, how dare it!
Eventually the logic dawns and you suddenly realise that this is a really clever bit of kit left to it's own devices, it took me time.
It can be disconcerting when you are reprogramming your fleet of finely honed complex jets to a new system but of course you always have your base settings, throws etc. to copy from your old transmitter.
I found it a learning curve well worthwhile pursuing, I'm sure you will also, glad you feel happier.
Gary.
Hide Signatures
       Post #: 524
RE: Spektrum DX18 - 9/26/2012 1:11 PM
Mr_Grump
Score: 105
Last Login: 5/22/2013
Status: offline
Hey Gents
There's a wealth of information being passed in this thread. For those of you who do a lot of programming, most of this makes sense. For guys like me, I struggle. You all know how difficult searching threads and finding what you read some time ago can be.
One of you take the initiative and create an ebook. Maybe even make it a collaborative effort. I know at least one who would get one for his Kindle. I'm sure many more would. The information could be used to help DX8 users as well and I'd be happy to pay for it.
Mr G
Mr G
Hide Signatures
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
