RE: Spektrum DX18    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Spektrum DX18
Page: <<   < prev  14 15 16 17 18 19 20 21 [22] 23   next >   >>
Login
RE: Spektrum DX18 - 9/26/2012 1:15 PM
bcovish
Score: 1018
Last Login: 5/24/2013
Status: offline
When I finally figured out that the DX18 was smarter than I am, we got along just fine.
_____________________________
Bob-O
Austin TX
Hide Signatures
(in reply to Mr_Grump)
       Post #: 526
RE: Spektrum DX18 - 9/26/2012 8:24 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: Xantos
 Hi guys,
im setting up a Bobcat with the Spektrum 18X and a  Spektrum12020 receiver, TM1000
power supply is thru a Powerbox Gemini with 2 x 2300 mA LiFe packs.
ive plugged the TM1000 telemetry module into the data/bind port and batt 1 into batt port and batt2 into the srxl port
Ive selected the Powerbox option on the transmitter telemetry menu , but I get only a single battery voltage readout.
there is a single Rx batt voltage option with alarm options which I can't ddisable how do I get both pack voltages on my Tx ?
you cant.. its nominal bus voltage... you can hook separate volt wire to a separate source like turbine batt.
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Xantos)
       Post #: 527
RE: Spektrum DX18 - 9/26/2012 8:26 PM
gooseF22
Score: 103
Status: offline
We will all get thru the programming woes as we learn.. just remember the twin polarity link.. that alone is worth the price of the upgrade.. I am not looking back.. my numbers have improved dramatically on my receivers..
Dustin has begin to put together a categorical listing of DX18 topics here.. check it out....
http://www.rcjetaddiction.com/forum/categories/spektrum-dx-18-programming-and-more/listForCategory
< Message edited by gooseF22 -- 9/27/2012 12:44 PM >
Goose
Hide Signatures
(in reply to gooseF22)
       Post #: 528
RE: Spektrum DX18 - 9/28/2012 6:03 PM
marquisvns
Score: 115
Status: offline
Maidened the 18 yesterday on a battle tested 50cc Spitfire, and unintentionally having to range check it in the air,
I must say, love this radio.
Thanks again for all the help,
Cheers,
Barry
www.kingtechturbines.com
kingtechturbines@gmail.com
Hide Signatures
       Post #: 529
RE: Spektrum DX18 - 11/12/2012 1:33 PM
chamma
Score: 100
Status: offline
Guys,
i am looking for a new radio, since i will start flying jets soon.
I have an old jr 9303 2.4 and 6-7 RX, but want somthing new.
I really liked the dx 18, since i can use my Rx. with it, but i saw, somewhere, that it may has some range problems and some glitches in the screen.
Do you have any issues with it?
Should i go with it, or maybe get a 12x?
I don't want to start a brad war here, just wanna know what is better for me and for my $$ jets.
Thanks.
Hide Signatures
(in reply to marquisvns)
       Post #: 530
RE: Spektrum DX18 - 11/12/2012 1:42 PM
madmodelman
Score: 110
Status: offline
Been using one for some time now, great piece of kit,
Gary.
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
(in reply to chamma)
       Post #: 531
RE: Spektrum DX18 - 11/12/2012 1:55 PM
w4sm
Score: 100
Last Login: 5/5/2013
Status: offline
quote:
ORIGINAL: chamma
Guys,
Thanks.
Go with the DX-18. I'm not aware of any screen glitches.
The 12x is an excellent transmitter but it is beginning to show its age in terms of features. It doesn't have a lot of the things found on the DX-18 like a memory card, and on-line firmware upgrades to name just a couple.
The DX-18 has the best range of any spread spectrum Tx that I've seen. The crossed antennas on the transmitter really cut down on signal fades. The standard Spektrum/JR DSM2/DSMX transmitters have excellent range due to the signal processing gain from the DSSS processing algorithm, but the DX-18 with the crossed Tx antennas is even better. Many folks with DataLoggers have noted this.
(PS. I'm not affiliated with JR/Horizon/Spektrum in any way and also am not interested in starting a brand war. If you like Futaba stuff, stick with it.)
Stacey E. (Chuck) Mills
Charlottesville, VA.
Hide Signatures
       Post #: 532
RE: Spektrum DX18 - 11/12/2012 2:09 PM
chamma
Score: 100
Status: offline
w4sm Thanks for the answer, it was very hopeful.
This is what i am looking here, pro and cons from this brands, without a war.
I didn`t know that the dx 18 has the best range, even better then the new jr xg11?
Hide Signatures
(in reply to w4sm)
       Post #: 533
RE: Spektrum DX18 - 11/12/2012 3:14 PM
madmodelman
Score: 110
Status: offline
Sorry I bothered then.
Hide Signatures
       Post #: 534
RE: Spektrum DX18 - 11/12/2012 4:32 PM
w4sm
Score: 100
Status: offline
quote:
ORIGINAL: chamma
I don't know much about the new JR XG series. As best I can tell their modulation system (DMSS) is very similar to DSMX but is not compatible with it. If you have a lot of Spektrum receivers, old JR DSM2/DSMX receivers, or Horizon/Parkzone bind and fly models, none of these will be compatible with the new JR XG (DMSS) radios. The only other issue is that JR cannot use separate remote receivers as Spekrum holds the patent on these. That's probably not a big problem. Again, I'm not trying to start an argument here. Futaba seems to work OK without remote receivers, but I'm personally a fan of them, especially in planes with a lot of internal metal, like turbines.
Frankly, I'm at a loss for why JR has abandoned DSMX, at least in the U.S. Because of the huge micro bind and fly Horizon market and the large amount of Spektrum 2.4 GHz equipment already in use (and incompatible with the new JR systems), this is REALLY going to affect their U.S. sales. I'm sure there's a story there between Horizon and JR, but we'll probably never know the details. I could GUESS that on one hand JR was tired of paying Horizon royalties to use DSMX and on the other hand, Horizon was tired of JR's reluctance to meet their requests for new features....
Hide Signatures
       Post #: 535
RE: Spektrum DX18 - 11/16/2012 12:22 PM
Robrow
Score: 100
Status: offline
Anyone know if when using a 12 channel 2048 resolution receiver whether you get the full 2048 resolution through channels 11 & 12 or do you just get basic 512?
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
(in reply to w4sm)
       Post #: 536
RE: Spektrum DX18 - 11/16/2012 12:53 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: w4sm
I The only other issue is that JR cannot use separate remote receivers as Spekrum holds the patent on these. That's probably not a big problem. Again, I'm not trying to start an argument here.
Where does this information come from? A patent? Many systems allow you to link multiple receivers, would this not infringe on Speks "patent"
Mike
Hide Signatures
(in reply to w4sm)
       Post #: 537
RE: Spektrum DX18 - 11/16/2012 1:01 PM
snobird
Score: 100
Last Login: 5/23/2013
Status: offline
Hey how about. DX18qq
Hide Signatures
(in reply to luv2flyrc)
       Post #: 538
RE: Spektrum DX18 - 11/16/2012 1:40 PM
DominicM
Score: 101
Status: offline
Slightly irritating an updated DX18 comes out 3 months after I got this one. Not bothered by the QQ labelling all over it...I can live without that but I read there are improved ergonomics and programming. Sucks if we can't upgrade DX18 to those. e.g. 3 servo per wing matching?
Hide Signatures
(in reply to snobird)
       Post #: 539
RE: Spektrum DX18 - 11/16/2012 1:43 PM
John Redman
Score: 117
Status: offline
@ Rob, you get 22 ms or 2048 resolution when using 12 channels on a 12 channel receiver.
No improved ergonomics on the 18QQ transmitter. Same case and special programming.
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
(in reply to DominicM)
       Post #: 540
RE: Spektrum DX18 - 11/16/2012 1:55 PM
DavidR
Score: 110
Status: offline
quote:
ORIGINAL: John Redman
Johnny,
What about that special programming, we were all sold on the fact that the DX18 would be software updatable. Even if the software was a small fee I don't think that so many of us would be feeling a little violated right now....
Hide Signatures
(in reply to John Redman)
       Post #: 541
RE: Spektrum DX18 - 11/16/2012 2:56 PM
DominicM
Score: 101
Status: offline
OK. Take your word for it John. I mis-interpreted this then "The Special, limited edition DX18QQ Somenzini radio from Spektrum takes the already acclaimed DX18 platform to new heights, offering R/C pilots the very best in control, ergonomics and features as specified and tuned by Quique himself."
Wouldn't mind one of those "Sol de Mayo Transmitter Case"? Can we get those separatley? The regular Spektrum stand up cases don't accomodate the height of the DX18.
Hide Signatures
       Post #: 542
RE: Spektrum DX18 - 11/16/2012 7:16 PM
kevin
Score: 100
Status: online
The dx18 fits in this stand up case just fine ... i cut down the dual transmitter foam insert and now i can use two stand up transmitters in it.
http://www.horizonhobby.com/products/spektrum-single-stand-up-transmitter-case-SPM6708
http://www.horizonhobby.com/products/jr-dsm-double-pro-transmitter-case-foam-set-JRPA710F
I really hope we can atleast get a version of the software that lets you cycle back to the main setup screen without turning the transmitter off and on. John?
Hide Signatures
       Post #: 543
RE: Spektrum DX18 - 11/17/2012 1:00 AM
booker-RCU
Score: 100
Status: offline
I found this case on the Maxford USA web site. http://www.maxfordusa.com/otheritems.aspx
For $34.00 It is an excellent case. The Spektrom decals came with the TX from Horizon.
Galen
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to kevin)
       Post #: 544
RE: Spektrum DX18 - 11/17/2012 6:00 PM
Tom Antlfinger
Score: 101
Last Login: 5/22/2013
Status: offline
Question for John R........
Are you able to transfer models to the QQ using an SD export/import from my naked 18 or is there an incompatibility associated with software differences on the QQ......hope so as I just completed moving 8 planes from my 12 X.....a bit of a PITA..
TIA.....Tom
< Message edited by Tom Antlfinger -- 11/17/2012 11:48 PM >
Hide Signatures
(in reply to booker-RCU)
       Post #: 545
RE: Spektrum DX18 - 11/17/2012 6:04 PM
Tom Antlfinger
Score: 101
Status: offline
Harbor Freight makes a very nice case package, actually 1 for my 18 and a smaller one for all my charging plug adapters....got the package for 29.99 on sale couple of months ago......
Hide Signatures
(in reply to Tom Antlfinger)
       Post #: 546
RE: Spektrum DX18 - 11/18/2012 2:57 AM
gooseF22
Score: 103
Status: offline
while we are talking programming.. V1.03 is out for a bit now.. with V1.02, I began to see improvement to antenna counts.. of course hard to quantify, but it seemed to improve a bit on both modulations.. There must have been a small RF tweak to it over V1.01.
Goose
Hide Signatures
       Post #: 547
RE: Spektrum DX18 - 11/18/2012 3:01 AM
gooseF22
Score: 103
Status: offline
Im not so sure I would want to go the system menu with a double button push IF... it stops transmitting... remember when the system menu is up, its not transmitting.... however if you hit the back/clear from the normal menu to switch models, it keeps transmitting... I wouldn't want to have a switch combo that could cause me to kill it, other than hitting the power switch.. I use the Back button as a trainer button..
Goose
Hide Signatures
       Post #: 548
RE: Spektrum DX18 - 11/18/2012 10:39 AM
Mr_Grump
Score: 105
Status: offline
Hey Kevin
Would you be a little more specific about how you cut down the insert? Maybe even a photo of two TX's in the case? I have the 18 and an 8 I carry to the field for buddy box purposes. It would be nice to carry them in one box.
Mr G
Mr G
Hide Signatures
(in reply to kevin)
       Post #: 549
RE: Spektrum DX18 - 11/18/2012 1:40 PM
gooseF22
Score: 103
Status: offline
I have one too.. you measure the case and trim off about 1/2 inch from all 4 sides with a flat saw or band saw.. then 45 degree the bottom corners..
Goose
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
