New Tornado S30 Owner Needs Help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> New Tornado S30 Owner Needs Help
Page: [1]
Login
New Tornado S30 Owner Needs Help - 2/2/2012 7:32 PM
stxhornfan
Score: 100
Last Login: 2/3/2012
Status: offline
Recently purchased my first RC car  for my son and my self.  Question is, during break in period I noticed my car "pulled" to one side as i was driving.  later when cleaning it I noticed that when I turn both the rear wheels only one front wheel turned.  Causes, soultions? Thanks
Hide Signatures
       Post #: 1
RE: New Tornado S30 Owner Needs Help - 2/2/2012 7:58 PM
nitrosportsandrunner
Score: 296
Last Login: 5/19/2013
Status: offline
when you turn 1 rear wheel...the other one should turn alittle in the opposite direction.
You could have a broken dogbone (driveshaft) but if that were the case then the rear wouldnt get any real power from the motor as the diff is open(and power will go to the side with no driveshaft)
Have you checked the steering trim on your radio?
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to stxhornfan)
       Post #: 2
RE: New Tornado S30 Owner Needs Help - 2/2/2012 10:30 PM
stxhornfan
Score: 100
Status: offline
No I have not checked the steering trim, but I will.  its when I turn both back wheels at once only one front wheel turns, the other acts like it wants to, kinda "bumps" if that makes any sense, but like you said if I turn one front wheel the other goes opposite, same for the rear.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: New Tornado S30 Owner Needs Help - 2/3/2012 12:09 AM
rchobbyunlimited
Score: 100
Last Login: 5/18/2013
Status: offline
Have you checked to see if the dog bone is in the one wheel that does not turn? If you turn the one front wheel that does not turn does the other front wheel turn?
Team Anaconda R/C Racing
http://www.teamanaconda.com/
Hide Signatures
       Post #: 4
RE: New Tornado S30 Owner Needs Help - 2/3/2012 1:26 AM
Score: 296
Status: offline
OK, sounds like your drivetrain is fine. the diffs are open, so if you turn both rear, then power will go to the front and turn the tire thats easiest to turn.
My guess is that either 1 wheel has some binding or the steering trim is off.
See if adjusting the steering trim helps...
and turn each wheel by hand and see if any of them is harder to turn.
On a tamiya buggy I had, you could over-tighten the wheel nut and make the wheel just alittle hard to turn. I would have to tighten the nut all the way, then back off 1/2 turn.
Hide Signatures
(in reply to rchobbyunlimited)
       Post #: 5
RE: New Tornado S30 Owner Needs Help - 2/3/2012 2:55 AM
Dads like rc too
Score: 540
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
 My Tornado is like this.  If you crank the wheels down they will bind.  Also a steering issue I had was over-tightening the lock nut that holds the screws into the steering knuckles.  These are the screws that hold the steering knuckle to the control arms.  If the lock nut is too tight, the steering will bind.
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
       Post #: 6
RE: New Tornado S30 Owner Needs Help - 2/3/2012 2:10 PM
stxhornfan
Score: 100
Status: offline
Great advice, thank y'all very much.  I'll check out all the suggetions this weekend when I install an electric start on my sons car.  Thanks again
Hide Signatures
(in reply to Dads like rc too)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
