Need new propeller - what kind should I buy?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Need new propeller - what kind should I buy?
Page: [1]
Login
Need new propeller - what kind should I buy? - 2/3/2012 11:36 PM
Veraster
Score: 100
Last Login: 6/25/2012
Status: offline
Hi guys.
So, I need a new propeller. The one I have is a 10 x 6. Would it help to get a propeller with a different pitch? And should I get a two bladed one or one with more blades?
Also, is there a way to buy metal ones? That way I wont break it every noob landing I have
EDIT: Yeah about the pitch and everything I had done enough research to understand what the second number meant and I changed it literally 15 seconds before you posted.
< Message edited by Veraster -- 2/3/2012 11:57 PM >
Hide Signatures
       Post #: 1
RE: Need new propeller - what kind should I buy? - 2/3/2012 11:52 PM
jetmech05
Score: 133
Last Login: 5/19/2013
Status: offline
You don't say what engine you're needing the prop for....anyway the 1st number is the length and the second number is the degrees of pitch....seeing as you had a 10 in prop I'm gonna guess you have a .40 or .46 engine.....if it's a 40 I'd go with a 10X6 or 10X7...if it's a .46 then I'd go with an 11X7....I don't like wood props on smaller glow engines I like APC props......
Hide Signatures
(in reply to Veraster)
       Post #: 2
RE: Need new propeller - what kind should I buy? - 2/4/2012 12:01 AM
Veraster
Score: 100
Status: offline
My engine is a .40. I dont know what that means mechanicly but thats what it says on the side.
Hide Signatures
(in reply to jetmech05)
       Post #: 3
RE: Need new propeller - what kind should I buy? - 2/4/2012 12:55 AM
Crash-RCU
Score: 101
Last Login: 9/17/2012
Status: offline
Use Master Airscrew 10x6 or 10x7 as stated in other post, The master airscrew props flex more than the APC props, so they don't break as easily. They don't make metal props, just think whirling knife blades.
_____________________________
Garry J
Hide Signatures
       Post #: 4
RE: Need new propeller - what kind should I buy? - 2/4/2012 2:08 AM
JohnBuckner
Score: 342
Status: offline
Not enough information as to what size/type engine and what type airplane to many any recommendations.
Actually not only are metal props not made as mentioned but use of metal props is specifically outlawed in the AMA safety code.
Master Airscrew props are the most useful for new folks and these will take the most ground strike punishment.
John
"Keep your controllines tight"
Hide Signatures
(in reply to Crash-RCU)
       Post #: 5
RE: Need new propeller - what kind should I buy? - 2/4/2012 4:55 AM
HighPlains
Score: 152
Last Login: 5/18/2013
Status: offline
I thought so too John, but they are only banned from competition.
- Supplementary insipid innocuous inane vacuous proclamation
Hide Signatures
(in reply to JohnBuckner)
       Post #: 6
RE: Need new propeller - what kind should I buy? - 2/4/2012 12:50 PM
JohnBuckner
Score: 342
Status: offline
quote:
ORIGINAL: HighPlains
Yup did some double checking and your are correct. Funny how those things become ingrained in ones mind
Hide Signatures
(in reply to HighPlains)
       Post #: 7
RE: Need new propeller - what kind should I buy? - 2/4/2012 12:57 PM
jaka
Score: 158
Status: online
Hi!
.40 engine means its capacity is.40 cubic inches or 6,5 cubic centimeter in the metric world!
For a high winged trainer a 11x5, 11x6 or 12x4 " prop are much better than a 10x6 . Best prop brands are RAM, APC and Graupner Cam-prop or the new Graupner G-Sonic props!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 8
RE: Need new propeller - what kind should I buy? - 2/4/2012 2:04 PM
Villa
Score: 133
Status: offline
In a crash a metal prop might survive, but it may destroy the engine.
Hide Signatures
(in reply to jaka)
       Post #: 9
RE: Need new propeller - what kind should I buy? - 2/6/2012 6:20 PM
airraptor
Score: 130
Status: offline
a metal prop will not survive a crash.
What is the brand of prop you have/had now.
Do not run a 11x7 on a 46 lol way to much prop. yes it will spin it but only around 10,000 rpm.
here are your choices if want to stay with a 10" prop
APC 10x6
Master Airscrew 10x7 = a 10x5 APC but with more blade area.
For a trainer plane the best is a 11x5 APC
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to Villa)
       Post #: 10
RE: Need new propeller - what kind should I buy? - 2/10/2012 12:20 AM
j.duncker
Score: 121
Status: offline
Graupner 10 x 6 is good if you tend to clip the ground.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to airraptor)
       Post #: 11
RE: Need new propeller - what kind should I buy? - 2/10/2012 7:29 PM
gaRCfield
Score: 156
Status: offline
quote:
ORIGINAL: JohnBuckner
...probably because they should be.
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 12
RE: Need new propeller - what kind should I buy? - 2/11/2012 3:10 AM
sebo
Score: 111
Status: offline
Breaking props is part of the r/c hobby........just like hitting golf balls into the pond is part of golfing.
I wish I had a dollar for every prop that I have broken in the last 30 years...I try all different kinds......still like wood the best.
Hide Signatures
       Post #: 13
RE: Need new propeller - what kind should I buy? - 2/11/2012 10:53 PM
sebo
Score: 111
Status: offline
What manufacturer makes 3 bladed props in these sizes?
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
