Anyone building TF p47 60 size?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Anyone building TF p47 60 size?
Page: [1] 2   next >   >>
Login
Anyone building TF p47 60 size? - 2/6/2012 5:08 PM
charlesp
Score: 100
Last Login: 5/6/2013
Status: offline
my woman bought me a TF P47 60size GE and I was wondering if anyone else is building one I would love to talk with someone else building one while I am building mine
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
fly high and land soft
Hide Signatures
       Post #: 1
RE: Anyone building TF p47 60 size? - 2/6/2012 5:50 PM
Walt Thyng
Score: 105
Last Login: 5/14/2013
Status: offline
Built mine several years ago. Bashed it to "N" model. Easy build. Terrific flier!
Walt
WT in Illinois
Hide Signatures
(in reply to charlesp)
       Post #: 2
RE: Anyone building TF p47 60 size? - 2/6/2012 7:05 PM
aymodeler
Score: 100
Last Login: 5/21/2013
Status: offline
Hi charelsp,
Looks like your well on your way!
There are a couple of posting over on this thread in the Kit Building forum: www.rcuniverse.com/forum/m_10757077/mpage_1/key_/tm.htm I'm plodding along slowly there, but another poster (raptureboy) is moving along quickly withi his build.
You can also checl out my blog site where I'm detailing out my "adventure" with this project at: arcplane.wordpress.com/.
Looking forward to comparing notes!
Please check out my rc airplane blog at http://arcplane.wordpress.com
Hide Signatures
       Post #: 3
RE: Anyone building TF p47 60 size? - 2/6/2012 7:13 PM
aymodeler
Score: 100
Status: offline
The shots showing the fuse formers (without the top sheeting in place) look quite a bit differnt than the TF kit I have been building. Is that a different edition?
Hide Signatures
       Post #: 4
RE: Anyone building TF p47 60 size? - 2/6/2012 8:07 PM
charlesp
Score: 100
Status: offline
its a P-47d thunderbolt gold edition 60 size and I am building the razorback version
Hide Signatures
(in reply to aymodeler)
       Post #: 5
RE: Anyone building TF p47 60 size? - 2/7/2012 2:05 AM
DavidAgar
Score: 146
Status: offline
I am building one as we speak. My fuselage is about done and I am working on the wing. Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
       Post #: 6
RE: Anyone building TF p47 60 size? - 2/7/2012 4:37 PM
edbu1
Score: 100
Last Login: 5/20/2013
Status: offline
I just finished building the bubble top version from the TF GE kit. Took over a year as I did many modifications. Used electric retracts and installed them at an angle back to be more scale like, instead of parallel to the leading edge of the wing. I could fit the more scale-like 4 inch Robart diamond tread wheels, but alas, no room to angle the wheels so that they track straight. The wheel is so thick that when extended, the they have too much toe-in. The right amount of toe-in causes them to not fully retract into the wing. So I switched to 3-1/2 inch, skinnier wheels. Full wheel doors, including the inner doors, and operating doors on the retractable tail wheel as well. Fiberglassed with 0.5 ounce cloth and Minwax Polycrylic. Automotive type lacquer primer. Warbird colors paints. I didn't want to invest in decent paint spray equipment, so I brushed it on and have been very pleased with how it looks. No brush marks. Very nice. Recommend you paint all of the markings, and avoid using any decals. They are very thick. I painted on the stars and bars. Used some of the tiny enamel Testor's bottles to paint the dummy radial engine and the cockpit kit details. Used Modern Masters metallic silver for the natural metal finish where needed. Couple of coats of Top Flite Lustrekote over the whole thing. All up weight is 10 pounds, 6 ounces. Magnum .91 4 cycle nitro engine.
My build is finished, but I'm still checking it out fully. Hope to do some high speed taxiing very soon.
Ask specific questions, and I'll be glad to tell you what I did. Good luck!
Ed
Hide Signatures
(in reply to DavidAgar)
       Post #: 7
RE: Anyone building TF p47 60 size? - 2/7/2012 4:44 PM
charlesp
Score: 100
Status: offline
welcome Dsvidagar would love to see updates as to were you are
Hide Signatures
       Post #: 8
RE: Anyone building TF p47 60 size? - 2/12/2012 11:58 PM
charlesp
Score: 100
Status: offline
got more done have the flaps sanded down and ready to be instaled but had to take a break enjoy
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Anyone building TF p47 60 size? - 2/13/2012 4:15 AM
Boomerang1
Score: 120
Status: offline
Sorry, you are about 13 years too late! My P-47 is still going strong though. - John.
Click for fullsize
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 10
RE: Anyone building TF p47 60 size? - 2/13/2012 8:43 AM
bigtim
Score: 132
Last Login: 5/17/2013
Status: offline
did alot of posting here when I built mine http://www.rcuniverse.com/forum/m_4868696/anchors_4868696/mpage_1/key_/anchor/tm.htm#4868696
Hide Signatures
(in reply to Boomerang1)
       Post #: 11
RE: Anyone building TF p47 60 size? - 2/15/2012 2:42 AM
tuskegee
Score: 105
Last Login: 5/10/2013
Status: offline
Well, Hello to all. Yea I just started this build and it is comming along fine. I some times find myself not looking at the booklet and doing a plan build....sooooo I have to back up. I put my air tank in the space in back of the cockpit...dead space. I put in the cockpit kit, that way I will work around it as to servos and items. It is bad doing everything then having to cut away things just to get the cockpit in. I will be running a 20cc. Made a new hatch for my air/off-on switch. the one in the pic was right where the canopy will sit. will post more pic's soon.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Tuskegee
U.S.Army(ret.)
Hide Signatures
(in reply to bigtim)
       Post #: 12
RE: Anyone building TF p47 60 size? - 2/15/2012 12:20 PM
TomCrump
Score: 116
Status: online
There's a current build, here: http://www.rcgroups.com/forums/showthread.php?t=1575020
Tom C
Hide Signatures
(in reply to tuskegee)
       Post #: 13
RE: Anyone building TF p47 60 size? - 2/16/2012 5:42 AM
tuskegee
Score: 105
Status: offline
Yes I know. it was started in 2009 I think. But they are doing mostly an ARF mod. So I will post some of my build for charlesp.
Tuskegee
U.S.Army(ret.)
Hide Signatures
(in reply to TomCrump)
       Post #: 14
RE: Anyone building TF p47 60 size? - 2/16/2012 11:18 AM
TomCrump
Score: 116
Status: online
quote:
ORIGINAL: tuskegee
Post # 1 was Jan,15, 2012. It's a build just like the OP is asking about.
Tom C
Hide Signatures
       Post #: 15
RE: Anyone building TF p47 60 size? - 2/16/2012 6:20 PM
tuskegee
Score: 105
Status: offline
Sorry, I was looking at some other one. But it is all good. some times we need new eyes.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Tuskegee
U.S.Army(ret.)
Hide Signatures
       Post #: 16
RE: Anyone building TF p47 60 size? - 2/16/2012 11:42 PM
ESSAR
Score: 100
Last Login: 4/14/2013
Status: offline
Hello,
I am currently building one. I am now nearing the end of the build. It took me just over a year to get to get to this point. I have just started paint weathering and scale details.
Mine is covered in solartex fabric to keep the weight down and will be powered by an os 1.20 surpass.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: Anyone building TF p47 60 size? - 2/17/2012 12:02 AM
ESSAR
Score: 100
Status: offline
Here are a couple more photos.
p.s tuskegee your build is looking very nice, I especially like your access doors.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ESSAR -- 2/17/2012 2:30 AM >
Hide Signatures
(in reply to ESSAR)
       Post #: 18
RE: Anyone building TF p47 60 size? - 2/17/2012 11:39 PM
tuskegee
Score: 105
Status: offline
Thanks Essar,
 Yea, I had this unit laying around in my war room for a year or so and then.....a friend asked me when was I planning to get on it. so....I get started. I have three other
units in line T-28, L-19, and an aero works P-51B (Tuskegee)1/5 scale.
Your bird is looking great. I will be putting a 20cc in mine and it will be glassed. What retracts are you using? I have CJM. As you can se I placed the air up top.
Click for fullsize
Tuskegee
U.S.Army(ret.)
Hide Signatures
(in reply to ESSAR)
       Post #: 19
RE: Anyone building TF p47 60 size? - 2/17/2012 11:48 PM
tuskegee
Score: 105
Status: offline
I forgot to say.. in the dash I put the light to my kill switch. In my P-40 I put a light in the dash and that looks cool for my onboard starter. My son did send me some light for the wings and main light.
Tuskegee
U.S.Army(ret.)
Hide Signatures
       Post #: 20
RE: Anyone building TF p47 60 size? - 2/18/2012 12:17 AM
ESSAR
Score: 100
Status: offline
Thanks Tuskegee. I am using eflite electric retracts. The cjm's are sweet!
I like your idea of putting the light in the dash that should look neat, I put my volt meter on the dash of my corsair, it looked cool,  you can see the lights on a low pass!
I was going to do a light kit but I couldn't find one I liked and then the build got too far to add them.
I heard these aircraft balance tail heavy and need quite a bit of nose weight. Have you or anyone heard anything about that?
< Message edited by ESSAR -- 2/18/2012 4:19 AM >
Hide Signatures
       Post #: 21
RE: Anyone building TF p47 60 size? - 2/18/2012 7:45 PM
redbiscuits
Score: 130
Status: offline
Finished mine about a year ago, a little inspiration if I may.
http://www.youtube.com/watch?v=hAcfJ3ALrM0&list=PL7CA24AD7590B80D1&index=1&feature=plpp_video
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to ESSAR)
       Post #: 22
RE: Anyone building TF p47 60 size? - 2/18/2012 10:30 PM
charlesp
Score: 100
Status: offline
I just got my DLE20 yesterday and have ben working on flaps i will be posting pics soon
Hide Signatures
(in reply to redbiscuits)
       Post #: 23
RE: Anyone building TF p47 60 size? - 2/19/2012 1:34 AM
bigtim
Score: 132
Status: offline
quote:
ORIGINAL: charlesp
look forward to seeing how well the DLE20 fits in the cowl I have a OS120 pumped for mine and I still needed a tiny bit of lead for it to balance out
Hide Signatures
       Post #: 24
RE: Anyone building TF p47 60 size? - 2/19/2012 7:25 PM
tuskegee
Score: 105
Status: offline
 Essar,  I have been told that by friends that run a glow system.even with all rec, servos, batts moved forward. I try not to cut the fuse or cowl if I don't have to. that keeps it clean and scale. As to paint, I like Klass Kote.
charlesp, The 20cc should work well as to the fit. What muffler will you be using?
Red, I had to put on my glasses to see your 47.....When it comes back the way it went up...its all good.
Tuskegee
U.S.Army(ret.)
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.657RCU1
