tinwakr
Joined: 10/18/2002 From: Waterloo, ON, Status: offline
Sunil, The new wing is finished! I have made the airfoil a bit thicker and I have put the main spars inline so I can put shear web between them as in "I" beam construction. I also added tabs on the ribs. I also created a template for the cut out in the fuse for the wing. Are you fabricating the cowl and canopy or are you using another manufacturer? Can I get your e-mail address to send the new drawings? BTW, if anyone wants them I can send. Chuck
