RE: zigsaw Atlanta    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: zigsaw Atlanta
Page: <<   < prev  1 [2]
Login
RE: zigsaw Atlanta - 2/17/2012 11:18 PM
boomerik
Score: 100
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: MTK
quote:
ORIGINAL: boomerik
Ah ok, well i haven`t glassed or did anything else to the wing yet but glue it together with PU glue so i can still cut it apart with a new/sharp blade i think and re-glue it using the 6 mm dihedral it would be a pitty to build it in a way that makes it not fly as it should i think.
I also have the golden gate manual but also the zigsaw manual/pamflet says 14 mm but if from experience you say somewere between 6 and 8 mm makes it fly much better then i`ll redo it i think .
Erik
Place the assembled wing halves upside down on your flat bench. Raise the center at it's highest point, 1/4''(6mm). Make certain your TE and LE are equidistant from your bench top; block as required. That will get you what you want. Atlanta's flew well, with minimal couple, setup that way
I did that on Paul`s advice i reglued the wing at 6 mm
Erik
_____________________________
Don`t worry planes ALWAYS come down
Hide Signatures
(in reply to MTK)
       Post #: 26
RE: zigsaw Atlanta - 2/18/2012 1:59 AM
pitstop000
Score: 105
Last Login: 6/16/2013
Status: offline
Erik, I wouldn’t place the servo that far out, keeping it close in will be better for flight performance.
Locating it close to the retract works well. You want to keep the weight closer to the center of the wings.
You might want to look at this thread that I started when you have a chance.
quote:
ORIGINAL: boomerik
Hi Paul,
Yeah i did make location for the retract rods before joining and i kinda joined the wing coz i thought of going with one servo at first but 2 might seem better i was thinking of placing the servo in the middle of the aileron might be a bit of a tricky thing to do now but not impossible
and i think i`ll taper the flaps into the ailerons (looks nicer i think ) and i`m not gonna use the flaps i got plenty of space and all my planes are without flaps and it`s fine i think.
Erik
Click to see fullsize image.
Click for fullsize
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
(in reply to boomerik)
       Post #: 27
RE: zigsaw Atlanta - 2/18/2012 8:33 PM
boomerik
Score: 100
Status: offline
I`ll put the servo`s there but on their side so i can put a cover over them because the way in the picture is butt ugly i think . So i`ll put them like i laid the servo on the wing .
Click for fullsize
Hide Signatures
(in reply to pitstop000)
       Post #: 28
RE: zigsaw Atlanta - 2/18/2012 8:40 PM
stuntflyr
Score: 137
Last Login: 6/19/2013
Status: offline
That will look nice.
Chris...
Hide Signatures
       Post #: 29
RE: zigsaw Atlanta - 2/18/2012 10:36 PM
doxilia
Score: 136
Status: offline
Erik,
do you plan to make a notch in the bottom of the wing sheeting and foam to run the servo leads? Sounds like it might be the best approach now that your wing is joined. ZigZaw did some nice retract installation work.
David
Hide Signatures
(in reply to stuntflyr)
       Post #: 30
RE: zigsaw Atlanta - 2/18/2012 10:49 PM
boomerik
Score: 100
Status: offline
Hi David,
No i allready made place for the servo leads. I drew a line paralell to the trailing edge from the box in the center of the wing (were the retract servo comes) to the box of the aileron servo and extended that line onto the other wing half and the with a brass pipe with a sharp end and some filed edges i hand "drilled" a hole in the foam from the center to the aileron servo using the line on the other wing half as guidance to end up at the correct place .
I`ll take some pictures tomorrow when i do the other wing half.
Erik
Hide Signatures
(in reply to doxilia)
       Post #: 31
RE: zigsaw Atlanta - 2/18/2012 10:55 PM
doxilia
Score: 136
Status: offline
Cool!
Not clear how you got a brass tube in the wing core with the panels joined but I'm eager to see how!
David
Hide Signatures
       Post #: 32
RE: zigsaw Atlanta - 2/19/2012 12:57 PM
boomerik
Score: 100
Status: offline
So did the other wing half this morning making the hole/tube for the servo leads . Took some pictures this time i think they explain themsleves , used the pencil line on the opposite wing half to stay on course to end up at the aileron servo box and not drill through the wheel wells
Erik
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 33
RE: zigsaw Atlanta - 2/19/2012 3:37 PM
boomerik
Score: 100
Status: offline
Glued the sides in the center box and filled it up to height with some foam and glued the plywood plate on top to put the retract servo in
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 34
RE: zigsaw Atlanta - 2/19/2012 4:41 PM
doxilia
Score: 136
Status: offline
Ah.... smart. I didn't think of leads without connectors!
Nice job.
David
Hide Signatures
       Post #: 35
RE: zigsaw Atlanta - 2/24/2012 10:25 PM
boomerik
Score: 100
Status: offline
Finally had some time again this week to spend on the atlanta so finished up putting the retracts into the wing it`s the first time i installed retracts and allthough i must say the MK ones work really nice it is a bit of a patience tester to get them operating smoothly and the way it should .
Also rough sanded the leading edges and glued on the wing tip blocks tomorrow hopefully finish the servo boxes and glueing on the trailing edge center pieces .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: zigsaw Atlanta - 2/24/2012 11:45 PM
stuntflyr
Score: 137
Status: offline
Nice work, Erik.
Chris...
Hide Signatures
       Post #: 37
RE: zigsaw Atlanta - 2/25/2012 12:27 AM
doxilia
Score: 136
Status: offline
Indeed... Those are some stout looking MK gear!
David
Hide Signatures
       Post #: 38
RE: zigsaw Atlanta - 6/3/2012 6:34 PM
boomerik
Score: 100
Status: offline
Hi all,
Been a while but work and all has been a bit busy got a little bit of free time again so picked up the atlanta again .
Sanded the trailing edges and tips of the wing this afternoon and sanded down the center of the stabilizer and glassed the center,also decided the psition of the nose gear .
I`ll post some pictures tonight or tomorrow and i hope to have some more free time left over coming period so i can finish her and fly it
Grtz Erik
Hide Signatures
       Post #: 39
RE: zigsaw Atlanta - 6/12/2012 8:30 PM
boomerik
Score: 100
Status: offline
As promised (a bit late ) some more pics , attached the wing pan and glued in the horizontal since the last time and am looking a bit were the nose gear should end up .
Erik
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 40
RE: zigsaw Atlanta - 6/13/2012 1:50 AM
stuntflyr
Score: 137
Status: offline
Super job, nice kit.
Chris...
Hide Signatures
       Post #: 41
RE: zigsaw Atlanta - 8/28/2012 6:08 AM
pitstop000
Score: 105
Status: offline
Hey Erik, How’s the Atlanta coming along? I haven’t seen or heard anything lately.
www.NECPO.org
Hide Signatures
       Post #: 42
RE: zigsaw Atlanta - 8/28/2012 6:17 AM
boomerik
Score: 100
Status: offline
Hi Paul,
Sadly enough it`s still in the same state for all kinda reasons all of them ending in a lack of time i should be able to continue with it in about a week or 2 though as soon as i continue i`ll take pictures again and keep you updated.
Erik
Hide Signatures
       Post #: 43
RE: zigsaw Atlanta - 10/7/2012 8:19 AM
boomerik
Score: 100
Status: offline
Hi,
Been struggeling a bit with putting the nosegear in place and getting the controls to it in a decent way since it is the first time installing retracts i was wondering if some of you that own an atlanta could post some pics of the nosegear so i can have a bit of a look to see how it should be installed . thank you
Erik
Hide Signatures
       Post #: 44
RE: zigsaw Atlanta - 10/8/2012 4:12 AM
rcacro
Score: 100
Status: offline
I had two Atlantas, well actually 1 1/2. The first had a single retract servo in the wing. It was difficult to adjust all the linkage so that operation was reliable. The other problem was hooking up the nose gear link while mounting the wing on the fuse.Finally solved the reliability problem by installing a second retract servo with the servo output shaft and arm protruding through the sheeting on the bottom of the wing. A short direct pushrod was easy to hook up after the wing was mounted. There was a small increase in weight but that was a minor penalty to pay for reliable operation and ease of installation.
Sorry no pictures are left in my files.
John W.
Scottsdale, Az.
Hide Signatures
       Post #: 45
RE: zigsaw Atlanta - 10/8/2012 4:31 AM
impactiq
Score: 110
Status: offline
There is a good thread here: http://www.rcgroups.com/forums/showthread.php?t=1405881&highlight=atlanta Has some pictures too.
Hide Signatures
       Post #: 46
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
