dx6i    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> dx6i
Page: [1]
Login
dx6i - 2/10/2012 12:03 AM
shaunie
Score: 100
Last Login: 4/29/2012
Status: offline
need some advise please
i'm new to this hobby and brought a tiger trainer 2 with a dx6i , i havent flew the plane yet as i dont want to rush into it and end up killing it , but i tested the controls with the dx6i and worked fine but now when i try it i get nothing at all no response from the plane , all batterys are fine and charged ,
Hide Signatures
       Post #: 1
RE: dx6i - 2/10/2012 10:59 AM
fishycomics
Score: 100
Last Login: 4/18/2013
Status: offline
did you lose bind. tx always goes on first , then battery second try rebinding. batt plugged in then with TX off hold trainer, still hold it, turn on tx wait three secs let go trainer
wait ten secs. see if anything moves. if needa binding plugto the rx you need to put that in one time then remove
Hide Signatures
(in reply to shaunie)
       Post #: 2
RE: dx6i - 2/10/2012 3:05 PM
jester_s1
Score: 233
Last Login: 5/24/2013
Status: offline
If rebinding doesn't fix it, then you probably have a bad battery connection or a switch problem.
_____________________________
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to fishycomics)
       Post #: 3
RE: dx6i - 2/12/2012 3:35 AM
kiwibob72
Score: 110
Status: offline
I'm going to guess that your on the as supplied with the Dx6i 'AR6200' receiver - if so, what are the lights on your receiver doing when you switch the plane on?, no lights, no power, flashing, no bind, solid, power and bound.
Also, any chance you changed models on your TX settings? (like if you had a Sim setup and forgot to switch back to the plane in question - done that myself - nothing works!)
Raptor 50 Nitro heli - OS50 Hyper
56" Yak54 w/ ASP.61 2 stroke, H9 P51 blue nose in progress (with DLE20)
Hide Signatures
(in reply to jester_s1)
       Post #: 4
RE: dx6i - 2/12/2012 4:58 PM
shaunie
Score: 100
Status: offline
all i get when i switch plane on is a quick flash of the lights and thats it nothing else , but i can hear a slight buzzing sound coming from the plane but only slight
Hide Signatures
(in reply to kiwibob72)
       Post #: 5
RE: dx6i - 2/12/2012 5:22 PM
snuts
Score: 100
Last Login: 5/23/2013
Status: offline
Did you get the manual with the radio? I asume it was a used package. Acting like it is waiting to get a bind, or rebind in this case. Here is the manual if you need it.
Hope this helps.
-Snuts-
http://www.spektrumrc.com/ProdInfo/Files/SPM6600-Manual_DX6i.pdf
Hide Signatures
       Post #: 6
RE: dx6i - 2/12/2012 5:53 PM
jaka
Score: 158
Status: offline
Hi!
You have to "bind" the transmitter to the receiver...Did you do that first???
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 7
RE: dx6i - 2/12/2012 8:46 PM
shaunie
Score: 100
Status: offline
hi i got manual and bind plugs, it was all working now its doing nothing .....................strange
Hide Signatures
(in reply to jaka)
       Post #: 8
RE: dx6i - 2/12/2012 9:51 PM
jester_s1
Score: 233
Status: offline
My bet would be a bad battery or switch. A cheap multimeter comes in really handy in these situations. You can use an aileron extension to check the voltage getting to your receiver to eliminate that as a cause for your problem. It also comes in handy for making sure you don't have servos binding anywhere in their travel.
Hide Signatures
       Post #: 9
RE: dx6i - 2/17/2012 12:42 AM
shaunie
Score: 100
Status: offline
still no joy   any ideas anyone ? i going bold pulling my hair out lol
Hide Signatures
       Post #: 10
RE: dx6i - 2/17/2012 5:45 AM
jester_s1
Score: 233
Status: offline
You've checked your battery and connections? You've verified that you're getting proper voltage to the receiver? If that's the case then binding is the only other issue I can think of. You didn't say you've tried rebinding, so if you haven't, go ahead and try it. If that doesn't work, maybe you can get with someone who flies Spektrum/JR gear and see if your receiver will bind to another transmitter.
Hide Signatures
       Post #: 11
RE: dx6i - 2/22/2012 12:53 AM
KitBuilder
Score: 131
Last Login: 5/22/2013
Status: offline
He hears a very slight buzzing which are the servos so there is some kind of juice getting through.. may not be enough for the receiver to work. I;m going to assume its a 4.8 volt battery.. even if he lost a cell there should still be some eratic movement at 3.6 volts which may or may not correspond to stick movments. Losing two cells at once would be strange. Borrow a battery and see if you dont have any sort of meter.. sounds like its a batt issue as others have stated. Nicd / NIMH will go without warning.
Also is it charged.. when mine went dead.. they wouldn't hold a charge beyong 10 minutes. I wonder if the seller knew there was a battery issue and charged it up before the purchase and all was well.. next day the batt was dead or close to it... again since you hear the slight buzzing. .that is your servo(s) clinging to life.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 12
RE: dx6i - 2/22/2012 12:54 AM
KitBuilder
Score: 131
Status: offline
My dx6i did the same thing.. I have since switched to 3 cell lipos and regulator.. can fly all day long.
Mike -
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
