RE: NSRCA Candidate Rules Proposal Survey is available    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: NSRCA Candidate Rules Proposal Survey is available Page: <<   < prev  3 4 5 6 [7] 8 9 10 11 12   next >   >>
Login
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 6:20 PM
smcharg
Score: 110
Last Login: 6/19/2013
Status: offline
With a passing vote of the NSRCA BoD, we respectfully submit to you the new Safety Proposal.  Essentially, the Safety Proposal that is currently with the AMA is being retracted and two new proposals put in its place.  The first one is simply the Fail-safe proposal that was part of the submitted Safety Proposal.  Then, the second new proposal will replace 6.9(a) as 6.9.1 and directly quoted and out of the current FAI Sporting Code.  The referred section is on page 16 in 5.1.11 of the FAI Sporting Code for 2012.  Please note that in FAI, in order to follow the rule, the disconnect must happen right after landing before the helper picks up the plane.  A disarm plug is NOT allowed to demonstrate a disconnect - there has to be a physical disconnect of the wiring and must be seen by an official.  Interesting huh!
Before anyone says it, I disagree that the arming plug does not constitute a physical break in the wiring.  Through some consideration and advice from people that have run the Worlds, the plug is external and does not constitute proof that the physical connection internally has happened.  That's the FAI rule.  As submitted, that part is not written into the proposal.  It is simply the direct quote from the FAI Sporting Code.  Here is the exact verbiage of the new proposals as submitted to the AMA.  I don't know when AMA will get the physical proposals up on their site.
New Proposal for 6.9
6.9 – Propeller safety - All contestants using radio equipment with a failsafe function shall be able to demonstrate that propeller rotation will either stop or reduce to an idle RPM when the transmitter is powered down while the aircraft receiver system is powered on.  Idle RPM for this purpose is defined as an RPM during which the model will remain stationary when already motionless.
New Proposal for 6.9.1
6.9.1 – For electric powered models, the electric power circuit(s) must not be physically connected, before the starting time is begun and must be physically disconnected immediately after landing.
_____________________________
Scott McHarg
Hide Signatures
(in reply to smcharg)
       Post #: 151
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 6:28 PM
ROOKIE PILOT
Score: 100
Status: offline
I would like to thank Scott and the NSRCA board of directors for doing a great job. I was going to remain silent on this issue because I don't fly electric, and then I thought, myself or my plane could be involved in a bad situation should one of these planes be accidentally turned on. So it does involve me. If this were a gun we were talking about the only way it could be safely handled by the group is by the chamber being open so all can see that it is not loaded. Common sense tells me that the plane should not be armed until it is ready to take off. People don't always use common sense, this is why people get shot with unloaded guns. I would like to see proof that the plane is unarmed. I really can't understand the big problem here. If you approve this new rule I encourage you to post here or contact your district VP to let your voice be heard also. It seems that the ones against something are the only ones you read about on this site. Maybe I can help change that and truly the changes that are best for the organization will be made.
Thanks, Randy Hicks
District 6 int. pilot
Designer of the Talon and soon to be Talon extreme
Hide Signatures
       Post #: 152
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 7:50 PM
pattratt
Score: 100
Last Login: 6/18/2013
Status: offline
Scott and the NSRCA BoD
You all deserve a great deal of thanks from the entire NSRCA membership for having the capacity and courage to listen to it's membership and then take action. With this new proposal you resolved every saftey issue and resolved the differences between AMA and FAI SAFTEY RULES! Great, Great effort by ALL involved!!
I personally want to thank Scott as he was the one taking all the fire over this issue and not once did he respond in other than the most professional and respectful manner. You are the "MAN"!!
Dick
Hide Signatures
       Post #: 153
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 8:24 PM
J Lachowski
Score: 100
Status: offline
Immediately after landing? Is that immediately at the point where the helper retrieves the airplane on the runway or is that immediately after it is removed from the runway and brought back behind the flightline. Immediately after being brought back behind the flight line seems the smart way to go.
The connecting part is the way we have been running things at the Nats for a number of years and should be no issue.
Joe Lachowski
NSRCA 330
Hide Signatures
(in reply to pattratt)
       Post #: 154
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 8:52 PM
burtona
Score: 100
Status: online
Wonder if the NSRCA board communicated with anyone at AMA about this proposal? Seems to me if there is a problem needing a solution that it should be a part of the AMA safety code and not included in the Pattern rules and should apply to all propeller flying.
Dave
Hide Signatures
(in reply to J Lachowski)
       Post #: 155
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 9:00 PM
smcharg
Score: 110
Status: offline
Dave,
   In fact we have.  The process is this gets submitted to Greg Hahn at AMA.  Greg then sends these proposals to the appropriate chair person on the appropriate committee.  If the Rules Committee decides that this is not a rule to be enforced as such or requests AMA HQ to get involved, it then gets sent to the AMA Safety Committee and then, it is left up to them to decide.  It is possible that this gets indoctrinated into pattern and the AMA Safety Committee proceeds to adopt it to their guidelines.
   This is what I've been explained.  I have no proof of this but this is how the process works from the explanation given to me from AMA.
Scott McHarg
Hide Signatures
(in reply to burtona)
       Post #: 156
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 10:00 PM
TonyF
Score: 108
Status: offline
I am very glad I made that phone call to Jon Carter last night and made the recommendation that the NSRCA proposal adopt the wording of the FAI F3A Sporting Code. I sent him the wording and he looked at it then emailed the rest of the NSRCA BOD that he recommended adopting their wording. They obviously agreed. Glad it has worked out.
TonyF - Team Horizon, Team BJ Craft, Team Contra Drive, Neu Motors
2010,2009 US Masters Champion,2011 Masters Also-Ran
Hide Signatures
       Post #: 157
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 10:02 PM
TonyF
Score: 108
Status: offline
I am assuming that what Scott has been referring to as the Rules Committee he is referring to the AMA R/C Precision Aerobatics Contest Board? Is that correct?
Hide Signatures
(in reply to TonyF)
       Post #: 158
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 10:11 PM
smcharg
Score: 110
Status: offline
Yes Tony, that is correct.  I am speaking of the official name "Academy of Model Aeronautics Radio Controlled Precision Aerobatics Contest Board".  Once again....my apologies to all for not saying it correctly.
Scott McHarg
Hide Signatures
(in reply to TonyF)
       Post #: 159
RE: NSRCA Candidate Rules Proposal Survey is available - 3/15/2012 11:25 PM
Mastertech
Score: 108
Status: offline
Ok so these rule proposals bring us right back to what we're doing already. Common sense seems to have prevailed. These rules will just put it in writing.
Thanks Scott,Tony and all involved.
Now can we get back to our normally scheduled Snap and Spin entry argument?
Tim
Be a kid forever, fly models.
Hide Signatures
       Post #: 160
RE: NSRCA Candidate Rules Proposal Survey is available - 3/16/2012 12:20 AM
gaRCfield
Score: 156
Status: offline
quote:
ORIGINAL: CLRD2LAND
quote:
ORIGINAL: gaRCfield
Well this is funny - I registered for NSRCA site so I could do the poll, but it never worked, so I never voted. I would have voted NO on the safety proposal. I would need discussion and some clarification before voting yes.
Hi Joe,
   We did have a problem on the ''back-end'' with some survey takers being able to log in and take the survey.  At first, we had it locked down to being able to take the survey only once.  In order to let these folks take the survey, our webteam opened it open competely so that anyone could go in and take the survey.  Those 3 individuals that decided it would be ''funny'' to take the survey multiple times simply had their second through {insert a 2-digit number here} results deleted without looking at the results.  These results were deleted based on user id, ip address and time stamps.
  Did you have any luck with emailing any of the email addresses for the BoD or the webteam when you couldn't take the survey?  I'm sure we would have been able to help you.  Secondly, DUE, in part to the results of the survey and discussions here and on the NSRCA Discussion list on Safety, the original Safety Proposal was thrown out and a new one was developed.  Did we get the 2nd proposal in the survey?  Due to time restraints, we did not.  At the time, the major point that was discussed thoroughly here and on the NSRCA Discussion list was the inclusion of the arming plug.  Although the survey was 50/50 even at the end, that candidate proposal was still dropped and the one submitted to the AMA was put in it's place.  The new one, as you've seen, leaves the option of how in all cases to the competitor.  Now, the complaint is different.  As you can see from my previous post, we are still working even now to make sure we are doing the right thing.  So, with that being said, your ''no'' vote succeeded without submission because the candidate proposal in the survey was removed and although not defeated, subsequently changed.  In essense, the point is moot.
Thanks Scott -I too appreciate everything y'all are doing
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 161
RE: NSRCA Candidate Rules Proposal Survey is available - 3/16/2012 1:03 AM
nonstoprc
Score: 110
Status: offline
This proposal is much better, a good requirement specification and is quite achievable.
My remaining concern is with the weight increase proposals currently on the table, which is kind of arbitrary. I would bet that if a survey were conducted, the mean increase would be around 100-150 grams.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to gaRCfield)
       Post #: 162
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 6:37 AM
mjfrederick
Score: 101
Last Login: 6/12/2013
Status: offline
First and foremost, I would like to thank Scott and the rest of the NSRCA board for their volunteering to do what is, for the most part, a thankless job.
That being said, the whole rules proposal cycle this year was done bass-ackwards. Now that I have decided to become a full-fledged NSRCA member again I don't have to hold back letting the board know when they did something wrong. It is not the job of the board to provide a solution to a problem that has not been clearly defined. This year a committee was formed and they came up with rules proposals based on grumblings at the field, or complaining here on RCU or other online forums or mailing lists. None of that constitutes a problem. If the NSRCA board thinks a problem exists the first thing they need to do is poll its membership directly. Unfortunately the polls should not be open to just anyone at all because then we'll have the problem of people who don't fly pattern at all or don't fly in the USA participating. Their opinions are irrelevant, and the only way the NSRCA can filter them out is to keep it to active membership. The content of this poll should not be specific rules proposals, but simple questions regarding how people feel about the rules that are being called into question: Do you think the weight limit should be changed in pattern? (YES/NO) If you think the weight limit should be changed should it go up or down? How much do you feel it should go up or down? Once the polling is completed the data should be crunched to see how many people actually think something needs to be done. I've seen in the past it took a 60% affirmative before the Board would push a proposal through to the AMA. This year simple majority was used. Frankly, given the long-lasting ramifications of making rules changes it should require a 2/3 majority before any rules are even looked into. Once it is verified there is a problem, the detail questions on each "issue" could then direct the committee on how to word the proposal with their members' interests in mind. Finally, the proposals should be presented to the membership for discussion, re-working if needed, and a final poll done to make sure 2/3 of the community actually wants the change proposed.
While I appreciate the board's work, I do not appreciate the product they produced this year. Frankly, they should ask the AMA Contest Board to ignore all proposals from the NSRCA this year and gear up now for the next rules cycle.
mjfrederick AMA 275874 NSRCA 4134
Hebert Competition Designs
Hide Signatures
(in reply to nonstoprc)
       Post #: 163
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 6:49 AM
mjfrederick
Score: 101
Status: offline
quote:
ORIGINAL: nonstoprc
The problem with statistics is that 92.357% of them are made-up on the spot. Your assertion that the mean would be 100-150 grams might be true amoung those that want a specific increase. That means nothing given probably 45 - 50% (perhaps more) don't want a weight increase at all, and maybe 25 - 35% want the weight limit removed altogether. That being said, up to 85% of pattern pilots don't fall into the category of wanting a 100 - 150 gram increase in the weight allowance.
See how much fun it can be to make up statistics?
Hide Signatures
       Post #: 164
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 3:06 PM
nonstoprc
Score: 110
Status: offline
quote:
ORIGINAL: mjfrederick
quote:
ORIGINAL: nonstoprc
Well, what you described is one possibility statistics outcome. But I disagree the assertion that 92.37% is made up on the spot. More than likely one would provide a number based on his situation: what extra weight allowance will take to go to Nats. Of course, he could say 0 grams if his plane can meet the current weight limit requirement.
That kind of data is more convincing, in my opinion.
If you looked at the survey on weight increase proposal, a high percentage voted yes. But we do not know what is individual's target increase number. Seems a link is missing even for AMA to decide the actual increase number.
Hide Signatures
(in reply to mjfrederick)
       Post #: 165
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 3:07 PM
smcharg
Score: 110
Status: offline
Hi Matt,
  Since you have just rejoined (and I'm very happy about that), let me give you a little insight into a few items.  The NSRCA is the special interest group to the AMA for precision aerobatics.  That means that, regardless of affiliation, the NSRCA is responsible not only to its members, but to the whole pattern community as well.  It is our position to take everyone in the community into account and not just its member as everyone should be heard.  When the results of the poll were submitted to the NSRCA BoD, there were both numbers given; those of just current 2011-2012 NSRCA members and all persons who decided to take the poll regardless of affiliation.  12 non-members took the survey and 95 were NSRCA members.
  Secondly, you are absolutely right about what should have been done.  This committee was put together at the end of January, suggestions submitted to the BoD at the beginning of February, candidate proposals drafted, survey set up and results given to the BoD the first week of March and results of the BoD decision submitted to AMA by March 15.  As I'm sure you are aware, we were changing our submissions to more fit the needs of the pattern community in the 11th hour of the deadline.  This year, it is the board's intention to rewrite the By-Laws and set specific time frames when any of these committees shall be formed and processes started so that the perceived "rush" does not happen again.  You, of course, are entitled to your opinion just like everyone else.  Jim Quinn, Don Atwood, John Gayer and myself went back through years of BoD Minutes and could not find anything that constituted a 60% rule or a 2/3 majority in order to pass.  We also contacted Derek Koopowitz who sat on the board from 1999-2010 and he was not aware of any rule like that either.  If we were to have found that, we would have pulled those proposals that did not fall within those limits.  There are many conversations that happen behind the scenes, that was one of them.  Each of the 8 DVPs had a vote and that vote should be in line with his/her district member's desires.  All DVP's, save one, voted in favor of these proposals.  The Executive Officers shall vote with all persons in mind and should side with the majority as well as the DVPs personal opinions in mind.  There should definitely be a distinction between a DVPs personal opinion and his/her constituents wishes and we feel confident that each of the DVPs voted with their district's opinions in mind as a whole.
  Lastly, the NSRCA does not make the rules, the AMA Precision Aerobatics Contest Board takes care of that.  The NSRCA merely submits its findings and suggestions to the AMA Precision Aerobatics Contest Board.  On that board, sits a member from each district of AMA.  Your representative is Lance Von Nostrand.  These individuals are appointed by the AMA's District Vice President to hold a seat on the board.  The board's chair is John Fuqua.  There are also other proposals submitted by other individuals whether they are NSRCA members or not.  The AMA Precision Aerobatics Contest Board will now take all submitted proposals and go through them, contacting the authors of the proposal to first, try to take similar proposals and come to a consensus and see if they can be "merged", and then proceed with the process.
  Although there have been a couple of suggestions (meaning two, both of which submitted here and not through official means of communication) to the NSRCA to remove the submitted proposals, the BoD feels confident that the proposals submitted support the pattern community and are looking out for the betterment of our sport.  It is quite obvious that "status-quo" is doing nothing to improve attendance at competitions or to help our community grow.  This can be seen not only in attendence, but how many different manufacturers are building items for pattern and how few of them are gearing advertising dollars to pattern.  In actuality, I feel the job of the NSRCA is to promote pattern and look out for the betterment of our sport.  Resistance to change is not always the right thing to do.  In my opinion, the NSRCA Rules Committee, as well as the NSRCA BoD, did a great job with these proposals and now it is in the hands of the AMA R/C Precision Aerobatics Contest Board to take our suggestions and move forward by means set forth in the instructions of the AMA itself.
Scott McHarg
Hide Signatures
       Post #: 166
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 5:36 PM
mjfrederick
Score: 101
Status: offline
quote:
ORIGINAL: CLRD2LAND
Unfortunately the NSRCA should not be polling anyone but its members. I understand the position that you represent pattern as a whole, but that's only partially true. While the NSRCA is the recognized SIG for pattern, the organization should not promote rules proposals that come from or are supported by a non-member majority. I'm not saying that's the case here, I'm speaking in generalities to fix the process for the future. Those who chose not to join NSRCA have other avenues to voice their opinion (as you pointed out), but the NSRCA should not make it their business to seek their opinions because they didn't pay for the ability to be heard within the group. As in any rule-making process (even real laws) special interest groups are formed by like-minded people to have one loud voice instead of a small voice.
quote:
ORIGINAL: CLRD2LAND
I'm aware there is no hard-and-fast "rule." The 2/3 majority was my recommendation for what the rule should be due to the long-lasting ramifications of rules changes.
quote:
ORIGINAL: CLRD2LAND
I'm aware of that, and this is the avenue for those who are not members, and those member who disagree with what the NSRCA chooses to do as a whole.
quote:
ORIGINAL: CLRD2LAND
 It is quite obvious that ''status-quo'' is doing nothing to improve attendance at competitions or to help our community grow.  This can be seen not only in attendence, but how many different manufacturers are building items for pattern and how few of them are gearing advertising dollars to pattern.  In actuality, I feel the job of the NSRCA is to promote pattern and look out for the betterment of our sport.  Resistance to change is not always the right thing to do.
Well, change just for the sake of change isn't always the right thing either.
quote:
ORIGINAL: CLRD2LAND
To quote J. Peterman from Seinfeld, "Congradulations on a job... done." Like I said previously, I appreciate the efforts, but given the way we ended up with the proposals, we would have been much better served by the NSRCA if they had just sat out this rules cycle.
Hide Signatures
       Post #: 167
RE: NSRCA Candidate Rules Proposal Survey is available - 3/19/2012 5:52 PM
mjfrederick
Score: 101
Status: offline
quote:
ORIGINAL: nonstoprc
Well, every time I make that statement I increase the percentage a little bit, but once I hit 99.99% I go ahead and drop back down to about 75%, doesn't matter since it's made up anyway. Fun part is, the more I make that statement, the more true it becomes. Nothing like a self-fulfilling prophecy (or statistic in this case) to really get the juices pumping on a Monday.
Hide Signatures
       Post #: 168
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 3:24 AM
grcourtney
Score: 115
Status: offline
I'm with you Matt. Doesn't feel like anyone is home.With the % that voted for the proposals on the survey verses the number of members in the NSRCA. Contact Lance and voice your opinion. I will get to see Jon at the next contest and get to voice mine but I'm sure he knows it already. Mc harg's statement says to me the numbers do not add up for backing of the board on these proposals. I understand the frustration I wish I had not handed over the the VP job maybe I could have prevented this nonsense of the board backing proposals that does not have a clear majority or even close to 50% backing of the membership. But alas hindsight is 20/20.
Gary
Hide Signatures
       Post #: 169
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 4:29 AM
mjfrederick
Score: 101
Status: offline
quote:
ORIGINAL: nonstoprc
Oh, and I had time to go back and check your assertion that a "high percentage" voted yes, and if by "high percentage" you mean 51.4% of the survey respondents, then yes, that is a very convincing majority. Pretty sure that's a statistical dead heat considering the margin of error is probably +/- 8%.
Stats are so much fun.
OK, time for bed.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 170
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 4:30 AM
nonstoprc
Score: 110
Status: offline
quote:
ORIGINAL: nonstoprc
Human mind thinks differently and randomly :-).
Hide Signatures
       Post #: 171
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 5:58 PM
rileyf3a
Score: 100
Last Login: 3/22/2012
Status: offline
OK, time for bed.
Mr. Matt, I am not understanding your logic.  First, you speak of not looking at the results of everyone, that you should just look at the results of the membership of the NSRCA.  You contradict yourself by this statement by saying 51.4% as this is the number for all that took the survey.  If you were to simply do as you suggest in the first place, the percentage is actually 52.6%.  I am of knowledge that the 1.2% increase is not significant in itself but you neglect to give the whole story regardless of the number you choose to use.  The more important difference in the results is the percentage of individuals who voted against.  In only the members of the NSRCA, that percentage is 43.2% and as a whole group, the number is only slightly higher at 44.9%.  I think that you are not looking at the whole picture regardless of how you say the survey is flawed.  You seem to use numbers that are to your convenience and do not state the entire truth.
As I have said before, I may be new to America but it is interesting how numbers that are used to fit the argument at hand but the entire picture is not drawn.  I think it is also important to point out that the NSRCA cannot force individuals to take the survey, they can only offer this process in hopes that membership will take advantage of it.  Those of you who are upset with the NSRCA should be upset with those that did not take this survey, not with the company that put it on.  These are the results that they had to work with and if you look at the whole picture, it appears that they have acted in accordance with the results.  Mr. Gary seems to understand how to make the world go around and have all the answers.  Maybe he should be the president.  It is so disrespectful, these actions of no tolerance. I think that this bickering is ridiculous and rather sad.  Some wonder why the population of pattern has decreased.  All I would do if I were new to the precision aerobatics and see all of this action and dissention and realize I would not want to be associated with all this.  I was of the understanding this was for fun.  Some would make it pure misery.  Luckily, I love F3A and just will put in my two cents.  To the new person: Not all have this attitude of dispair and misery and anger.  Come out to the field and understand the grace and beauty of F3A and precision aerobatics.
Riley
Hide Signatures
       Post #: 172
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 11:53 PM
grcourtney
Score: 115
Status: offline
Mr Riley..
What you fail to realize as does the board of the NSRCA we have over 400+ members and as you say 40+ ???something percent voted in favor or even 50 +or - a few percent in favor take the number that voted divide that into the total number of NSRCA members and you will come up with less than 15 or 20+ or- percent in favor .
In the great old US of A.. generally a majority rules some thing that is lost on the board of the NSRCA and possibly yourself in this instance.....
I have served on the board... I have a little insight as to whats going on and insight on a few past opinions on past issues that was also outside the Boards purview of which I have a very strong position on( that's another story that needs to be told at another time though) ...Regardless if the measure passes the AMA .This board is outside its realm on this issue as the majority have not been heard and their data is incomplete as to total membership wishes yet. I pay for the right to be a member therefor I pay for the right to jump up and down and holler and scream like a spoiled rotten child when i strongly disagree with and feel misrepresented by.
Show me a majority of the members of the NSRCA that want these issues passed and I will shut the flock up about the board backing them..
I have great respect for many of the members of the board. people which I have flow against, broken bread with, hoisted a few with and even handed out a few dollar bills at places where you hand out dollar bills at.( For charity purposes only I'm sure)
Join the NSRCA my friend Riley.. Its a good organization... And try to have a voice...
Its about proper representation my friend Riley.. and nothing more..
Gary Courtney
Hide Signatures
(in reply to rileyf3a)
       Post #: 173
RE: NSRCA Candidate Rules Proposal Survey is available - 3/20/2012 11:54 PM
wattsup
Score: 100
Last Login: 12/18/2012
Status: offline
Matt and Gary, I guess that told you! Maybe I'm missing something, is there a sign posted around somewhere stating that this is a public forum and your responses are subject to scrutiny and you run the risk of being taken to task? Just thought I would ask..........BTW Gary, thank you and "You go boy!"
Hide Signatures
       Post #: 174
RE: NSRCA Candidate Rules Proposal Survey is available - 3/21/2012 12:55 AM
rileyf3a
Score: 100
Status: offline
Then Mr. Gary, you must contend that any law passed by American voters is null and void.  No vote has ever been taken in American law that constitutes a majority of its citizens therefore they are all void.  This is illogical and does not stand to reason.  America can only ask for the vote.  It does not go back later and say this vote does not count because there is not a majority of voters.  Similarly, the NSRCA can only act on the information that has received yet you put a lashing on the people.  I do not understand this.  Why not be upset with those that did not give their opinion?  I am not defending their decision, simply stating your rationale is open to conjecture and is flawed.
Riley
quote:
ORIGINAL: grcourtney
Mr Riley..
What you fail to realize as does the board of the NSRCA we have over 400+ mebers and as you say 40+ ???something percent voted in favor or even 50 +or - a few percent in favor take the number that voted divide that into the total number of NSRCA members and you will come up with less than 15 or 20+ or- percent in favor .
Gary Courtney
Hide Signatures
(in reply to grcourtney)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.641RCU1
