Drove the wheels off it! Need new wheels!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Drove the wheels off it! Need new wheels!
Page: [1]
Login
Drove the wheels off it! Need new wheels! - 2/12/2012 9:29 PM
RockinEagle
Score: 100
Last Login: 5/10/2012
Status: offline
I finallty put a Lipo in my new Tornado Pro. IT IS FAST!!  Sadly though, the wheels could not take the power.  Two completly ripped off and a 3rd has a chunk missing.  I was cresting a grass hill at top speed and as the buggy got a little light the two right side wheels went flying off....my first thought was that the nuts had come off but alas the wheels were toast.
I found this from "Mickstix".....will these wheels work for electric or just Nitro?.......
"The wheels/tires for the Team Associated B44 will fit the Tornado.. (It's their 4wd buggy) The rear wheels/tires for the B4 (2wd) will also fit.. The rears are the same on the B4 and B44.. (Fronts on the 2wd B4 are thinner than the 4wd B44) Check somewhere like Tower Hobby for the B44 stuff.. Search for "B44 wheels or B44 Tires" You should be able to find plenty of options on there.. If ya want to get real Redcat wheels/tire replacements check out URCHobby.com Kurt will take care of ya! "
THANKS IN ADVANCE!
Now I have to go discharge a completely full Lipo Battery.....bummer.
Hide Signatures
       Post #: 1
RE: Drove the wheels off it! Need new wheels! - 2/12/2012 9:45 PM
pede_187
Score: 100
Last Login: 8/10/2012
Status: offline
I am not entirely sure that they will fit. Reason being that the B4 rear wheels run off of a straight pin, the redcat however uses a 12mm hex. However if you remove the hex and the pin is the same size, you may be able to do it.
Btw, there really is no need to discharge the LiPo and discharging it too far may actually hurt it.
Hide Signatures
(in reply to RockinEagle)
       Post #: 2
RE: Drove the wheels off it! Need new wheels! - 2/12/2012 10:10 PM
RockinEagle
Score: 100
Status: offline
Will do some more research on the wheels.
From what I have read, you are supposed to store a Lipo at 3.8v per cell.
Hide Signatures
(in reply to pede_187)
       Post #: 3
RE: Drove the wheels off it! Need new wheels! - 2/13/2012 3:09 AM
Dads like rc too
Score: 540
Last Login: 5/25/2013
Status: offline
I wouldn't rush to replace your wheels with factory replacements.  I think this is one area where Redcat attempts to keep the price low for customers.  My Tornado S30 wheels lasted about 15 minutes the first time I brought it to the track.  Two of them completely split in half.  The plastic they were made out of was very brittle and unforgiving.  Find some after market rims from Pro-line or other companies.    A  2.2 size rim will fit.  Just make sure they have some offset to them.  Don't get a zero offset rim or they might rub.  After replacing your wheels and tires and tightening everything down, you'll have a lot of fun with that Volcano with very little down time.  My son's Caldera 10E has only broke twice since July of last year.  I've replaced the steering knuckles with aluminum and a spur gear 2 months ago.
_____________________________
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
       Post #: 4
RE: Drove the wheels off it! Need new wheels! - 2/13/2012 3:25 AM
RockinEagle
Score: 100
Status: offline
LXBVMW JConcepts Mono 12mm Rear Wheel White B4.1/RB5 (4)
    Qty Discount Available
  1   $ 12.49 Delete this item
LXBVMU JConcepts Mono 12mm Front Wheel White B4.1/RB5 (4)
  1   $ 10.59 Delete this item
LXUFB0 JConcepts Goose Bumps Rear Buggy Tire Green 2.2 (2)
  1   $ 11.99 Delete this item
LXUFB1 JConcepts Goose Bumps 4WD Front Tire Green 2.2 (2)
  1   $ 10.99
This is my shopping list.....looks like these will work!?!?
Hide Signatures
(in reply to Dads like rc too)
       Post #: 5
RE: Drove the wheels off it! Need new wheels! - 5/25/2013 12:55 AM
SumoRcNoob
Score: 100
Status: offline
hey guys, do u know if these tires will fit my Tornado S30 ??
Tornado S30, Sumo>
Hide Signatures
       Post #: 6
RE: Drove the wheels off it! Need new wheels! - 5/25/2013 1:19 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: online
quote:
ORIGINAL: RockinEagle
fully charged lipos are 4.1 per cell. and there is no reason you cant store them at that voltage. one of the good features of a lipo is that they hold their voltage when stored...unlike nimhs which will slowly lose their voltage when stored over a period of time.
I had traxxas stampede 2.2 rear tires on mine. the fronts requried some trimming on the inside of the wheel.
you want rims who's hex is toward the chassis side of the wheel. if the hex is deep inside the rim, its likely the rim will rub the suspension arm or camber link mount.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
