MVVS 35cc ICU - L magnetic sensor wire damage?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 35cc ICU - L magnetic sensor wire damage?
Page: [1]
Login
MVVS 35cc ICU - L magnetic sensor wire damage? - 2/13/2012 4:12 PM
BobV1700
Score: 100
Last Login: 12/22/2012
Status: offline
 Ive managed to damage the magnet sensor lead on my MVVS 35cc ICU - L by allowing it come into contact with the hot exhaust (yep, stupid I know). It still works OK but will require repair sooner or later. The wire leads directly into the black box which does not appear to be simple to open, presumably I can repair the wire by cutting out the heat damaged section and rejoining ie soldering, heat shrink, and a little more care!.
Thanks in advance,
Bob V
Hide Signatures
       Post #: 1
RE: MVVS 35cc ICU - L magnetic sensor wire damage? - 2/13/2012 4:24 PM
Meesh
Score: 100
Last Login: 5/17/2013
Status: offline
Yes, just cut out the damaged section and solder new wire in. This will give you a chance to extend the leads if necessary.
Bob
_____________________________
If it''s worth doing, it''s worth doing it right.
AMA 779352, JPO 1965, IMAA 40337
Hide Signatures
(in reply to BobV1700)
       Post #: 2
RE: MVVS 35cc ICU - L magnetic sensor wire damage? - 2/14/2012 2:20 PM
BobV1700
Score: 100
Status: offline
Meesh ........
Thanks for that, is the wire 3 core or two core? anything special required?
Bob
Hide Signatures
(in reply to Meesh)
       Post #: 3
RE: MVVS 35cc ICU - L magnetic sensor wire damage? - 2/14/2012 2:43 PM
Meesh
Score: 100
Status: offline
I'm not sure but any type wire of similar gage will work.
Hide Signatures
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 35cc ICU - L magnetic sensor wire damage?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
