Heli-coil    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Heli-coil
Page: [1]
Login
Heli-coil - 2/15/2012 2:34 AM
telejojo
Score: 130
Last Login: 5/22/2013
Status: offline
I bought a used Saito 1.20 on flea bay and the guy forgot to tell me the glow plug was stripped out,what size is the glow plug and where's a good place to get a heli-coil?
Hide Signatures
       Post #: 1
RE: Heli-coil - 2/15/2012 3:22 AM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
The glow plug is 1/4-32. For what you spend to by all the tools for one heli coil installation you would be better off to send it to Clarance Lee for repair. The kit will be north of $60 or more.
Just googled this from Amazon..... I was a bit shy of the price. Looks like it will do several repairs, but the coils are the cheap part.
http://www.amazon.com/HEL-5425-Heli-Coil-Airplane-Motor-Repair/dp/B00408H90M
_____________________________
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to telejojo)
       Post #: 2
RE: Heli-coil - 2/15/2012 3:51 AM  1 votes
earlwb
Score: 584
Status: offline
Yes they make 1/4-32 heli-coil kits for fixing stripped out glow plug holes. But one big caveat, is that some four stroke engines have the valves really close to the glow plug hole. You may or may not have room to drill it out and insert a heli-coil or not. So you want to check that carefully before you drill the hole and tap it.
I think what Clarence and others do in that case, is they machine and thread a bronze insert and the blind drill the hole down short of going all the way through. You can look at a 4 stroke glow plug and see the machined smaller unthreaded tip on them. They then use a bottoming tap and thread the partially drilled hole, and then insert the bronze insert and use permanent threadlocker on it. They let that set up overnight then drill the inside hole all the way through to fit the glow plug tips. Then they drill part way through and using a bottoming tap thread it for 1/4-32 glow plugs. Anyway, that is about the only way I can see someone doing it, if the vales are too close together.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to kenh3497)
       Post #: 3
RE: Heli-coil - 2/15/2012 4:34 AM
w8ye
Score: 318
Status: offline
Clarence Lee advertises in the back of Model Aviation Magazine.
C.F. Lee Manufacturing Co.
10112 Woodward Ave.
Sunland, Ca, 91040-3342
818-352-3766
leecustom@msn.com
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to earlwb)
       Post #: 4
RE: Heli-coil - 2/15/2012 4:53 AM  1 votes
Cyberwolf
Score: 655
Status: offline
I don't know about the 120, because I have not done one. But the other saitos I have done are drilled thru and tapped thru for the helicoil insert. But earl is correct some 4 strokes do have the valves to close to go all the way thru W/O hitting them so a method very much like he pointed out is what is used.
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to w8ye)
       Post #: 5
RE: Heli-coil - 2/15/2012 11:23 AM
telejojo
Score: 130
Status: offline
Thanks..................................
Hide Signatures
(in reply to Cyberwolf)
       Post #: 6
RE: Heli-coil - 2/16/2012 1:00 AM
summerwind
Score: 148
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: w8ye
10112 Woodward Ave.
818-352-3766
leecustom@msn.com
Ditto.............Clarence just blueprinted a couple engines for me and fixed a head bolt that was factory stripped...........4-40 is way smaller than i thought possible to fix. and gee, he charged me a whopping 5 bucks...............
AMA 70865
Team Satellite
Hide Signatures
(in reply to w8ye)
       Post #: 7
RE: Heli-coil - 2/16/2012 1:21 AM  1 votes
Cyberwolf
Score: 655
Status: offline
Mr Lee is still working for wages that was present back in the 60's *L*
Just kidding , he does a very fine job and does not charge anything for his work not to many left that are like that now days.
Hide Signatures
(in reply to summerwind)
       Post #: 8
RE: Heli-coil - 2/16/2012 3:13 AM
earlwb
Score: 584
Status: offline
Clarence Lee is the best in the business.
AMA # 928076
Hide Signatures
       Post #: 9
RE: Heli-coil - 2/16/2012 7:21 PM
HunkaJunk
Score: 109
Last Login: 3/5/2012
Status: offline
I have done a few Saito engines(and other 4 stokes) with stripped glow plug holes,  you must be very careful not to damage the valve seats when drilling and tapping for a repair coil.  If you are not confident you can do it without problems I would send it to someone, as others have mentioned.
For example, I repared a pair of stripped Saito 82s for a guy,  I had to change the angle of the glow plugs slightly when I prepped them for the coil repair to avoid getting into the valve seats.  I did the work on a small milling machine, which was considerably more accurate than a drill press. I have also put an insert into a blind hole so I didn't have to drill all the way through into the combustion chamber.  This also involved a mill, with and an end cutting end mill.
To err is human, to really mess things up requires government involvement
Hide Signatures
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Heli-coil
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.639RCU1
