P 100 RX Acceleration    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> P 100 RX Acceleration
Page: [1]
Login
P 100 RX Acceleration - 2/17/2012 2:00 AM
indubitably
Score: 101
Last Login: 5/22/2013
Status: offline
I have just recieved my ECU back from JetCat, and the new screen says S for the latest mapping. This is to allow a faster acceleration. I immediately placed it in my Bandit, and fired it up. Yes im smiling, as it has made a difference notably in a more rapid response to throttle input. I might add that i had attempted to fix the problem by upping the Low throttle acceleration, and the High throttle acceleration from Normal to Fast. This had resulted in a very rough acceleration. Now that i have it back i made several starts, and there are no issues. NICE
John
Hide Signatures
       Post #: 1
RE: P 100 RX Acceleration - 2/17/2012 7:27 AM
Dave Wilshere
Score: 108
Last Login: 6/20/2013
Status: online
John
Yes, its also been done for the P-20X for those that want it. We have sent the first of the P-100RX ECU's back for UK people wanting faster acceleration and we are ordering a "floating" ECU so we can swap out units with customers, so they don't get a delay in flying while theirs goes back.
Dw
_____________________________
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to indubitably)
       Post #: 2
RE: P 100 RX Acceleration - 2/17/2012 4:16 PM
indubitably
Score: 101
Status: offline
A really good and considerate idea Dave, because i know how anxious i was waiting for the return of the ECU.
Are you using FAST on both the Low, as well as the High throttle settings? As i notice the LOW still has a little roughness in acceleration that is missing when Low throttle is set on NORMAL.
Before the change to S on the ECU the Fast setting in LOW throttle produced huge sputtering and flames.
John
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 3
RE: P 100 RX Acceleration - 2/17/2012 4:33 PM
Danneman
Score: 100
Last Login: 6/13/2013
Status: offline
Hi john.
I have my ECU at Jetcat for upgrade, as we speak. Just wondering if you have the fast setting on your ECU on both low and high throttle?
Regards Daniel
Hide Signatures
       Post #: 4
RE: P 100 RX Acceleration - 2/17/2012 7:48 PM
indubitably
Score: 101
Status: offline
Good question, since it did make a difference.
Low throttle - Normal, Fast
High throttle - Slow, Normal, Fast.
I had tried Fast - Fast before sending it in, and didnt notice a big difference in acceleration, but it grumbled a lot with spitting flames and then a flame out with fire.
Low Fast - High Normal had the same scenario. Had an extinguisher ready.
Low Normal - High Fast, and it worked ok, as before, possibly a little quicker on acceleration, but hoping for more.
New ECU last night and tried it without any challenges in regards to flames or big stuttering, but a few little stutters. Only a few minor stutters now with FAST - FAST. No stutters with the Low throttle at normal, High throttle at FAST. I believe i will keep it FAST - FAST for now.
I took iPhone video of the throttle response, but am not skilled in the way of editing, and placing the video. Maybe someone else can do that. It is noticeably faster, and am pleased with the benefit, and with the engine in general. Perfect for my Bandit.
John
Hide Signatures
(in reply to Danneman)
       Post #: 5
RE: P 100 RX Acceleration - 2/17/2012 7:57 PM
Dave Wilshere
Score: 108
Status: online
John
I run Normal on low and fast on high...but I always move throttle stick slowly on all my jets! Never get flustered turbines with my flying style. I think a long way ahead about throttle need and rarely throttle back more than 1/3 during flight.
Dave
Hide Signatures
       Post #: 6
RE: P 100 RX Acceleration - 2/22/2012 6:07 PM
indubitably
Score: 101
Status: offline
Thank you Dave,
I now know the wisdom of what you said and how you said it. And i believe that will be my goal in throttle management.
I also found out that if you hold down the manual button on the GSU when you turn on, then keep it pressed as the engine after it goes through its initial runs up, then keep the button held -move the throttle to full power slowly, then back down. You will see on the GSU a signal that momentarily will say something like "Throttle parameters set". Then let loose of the MANUAL button. After which you will see the fastest -smoothest - throttle response and best running engine. Im not sure if you have to do this if every time you fly, every time you reconnect the ECU battery. Maybe if you keep the ECU powered, then once a day, it seems to re-set the throttle parameters. Maybe when i fly it next i will see a before and after to see if it makes any difference, if i re-do the throttle maneuver.
John
Hide Signatures
       Post #: 7
RE: P 100 RX Acceleration - 2/22/2012 6:16 PM
schroedm
Score: 103
Last Login: 6/19/2013
Status: online
John,
Are you sure it didn't say "Pump parameters stored"?
Rgds
Mark
Hide Signatures
       Post #: 8
RE: P 100 RX Acceleration - 2/22/2012 7:17 PM
Vincent
Score: 105
Status: offline
John,
The only "fix" is to send the ecu to Wicox and let him update the software. What you are doing with that procedure is calibrating the pump voltage to the desired rpm ...right up to max power. It has nothing to do with throttle response.
Vin...
Hide Signatures
(in reply to schroedm)
       Post #: 9
RE: P 100 RX Acceleration - 2/23/2012 2:50 AM
indubitably
Score: 101
Status: offline
Mark,
It could have said that, in fact, it was just a flash of relevant words that confirmed what i was doing.
Vincent,
I had sent it in, and had it come back. It had worked better, then back to its old ways. That is why i went through the process. Today i was hoping to get away with the low throttle FAST ACCELERATION and had some trouble. So tried the slow throttle with MANUAL depressed. Well, i learned how little i know about these engines. Big fire balls. So i went back to NORMAL on Low throttle, and flew four flights with no further issues. I guess it just doesnt like FAST. I love the engine, and it is fast enough. Just like anything - if a little is good, more is better, at least we can try. I just wish i had video and sound. But i went to the extinguisher. But didnt have to use it
John
Hide Signatures
(in reply to Vincent)
       Post #: 10
RE: P 100 RX Acceleration - 3/7/2012 8:48 PM
Danneman
Score: 100
Status: offline
I recieved my ECU 2 days ago, now says 10.1s.
Fired it up in the bench whit low throttle - FAST, high throttle - FAST settings.
As Austin powers says; **** me that was fast
Noticeable faster response, no sputtering.
Regards Daniel
Hide Signatures
       Post #: 11
RE: P 100 RX Acceleration - 3/8/2012 3:51 AM
indubitably
Score: 101
Status: offline
I still have some issues, with grumbling acceleration, and balking. But if i do one slow to full throttle, then it seems ok for the rest of the flight.
I beleive that th low throttle should be on Normal, and not Fast. David has said the same, and it seems to be best that way. Any other input?
John
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.360RCU1
