E Flight F-86 Sabre    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> E Flight F-86 Sabre Page: [1]
Login
E Flight F-86 Sabre - 2/19/2012 12:03 PM
omra
Score: 100
Last Login: 5/18/2013
Status: offline
Hi guys,just a quick question.I have just finished the E Flight sabre and would like to run a seperate receiver battery pack & on/off switch to run the servos only,allowing the main lipo 4s to run the motor.Do I need todo anything differently?? and will the lipo pack still power up the reciever as it does now? or do you disconnect one of the wires from the speed controller to the reciever??
Any help much appreciated.
Regards OMRA
Hide Signatures
       Post #: 1
RE: E Flight F-86 Sabre - 2/19/2012 12:37 PM
rcmiket
Score: 116
Status: offline
You'll need to disable the the BEC in the ESC. Pulling the red wire on the ESC plug will do that. Normally I just use a 3inch extension with the red wire cut. Other wise you flight pack would be installed as usual. First turn on the flight pack then pull in your LiPo.
Mike
_____________________________
"while inverted down is up and up is expensive!!!"
Hide Signatures
(in reply to omra)
       Post #: 2
RE: E Flight F-86 Sabre - 2/19/2012 12:45 PM
omra
Score: 100
Status: offline
Thankyou mike.So just pull out the red wire of the speed controller yeah,will I still need to disable the BEC?
Hide Signatures
(in reply to rcmiket)
       Post #: 3
RE: E Flight F-86 Sabre - 2/20/2012 5:57 PM
wind junkie
Score: 105
Last Login: 2/23/2013
Status: offline
That's all you need to do. The main danger was that the BEC would fight (or charge) the on board RX battery (which you don't want). Removing the red wire connection effectively disables the BEC function of the ESC as far as the RX is concerned. No need to change anything else on your ESC.
Arguing with an engineer is like wrestling a pig. Everyone gets dirty and the pig likes it.
Hide Signatures
(in reply to omra)
       Post #: 4
RE: E Flight F-86 Sabre - 2/20/2012 8:49 PM
omra
Score: 100
Status: offline
Thank you for the post wind junkie,much appreciated,didn't want to disconnect anything and end up with a problem!! :-)
Thanks again.
Regards
OMRA
Hide Signatures
(in reply to wind junkie)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
