Bunged up transmitter?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Bunged up transmitter?
Page: [1]
Login
Bunged up transmitter? - 2/20/2012 6:27 PM
LeviB
Score: 100
Last Login: 2/29/2012
Status: offline
Hi, I'm obviously a new guy here and have a question I hope is easy to answer. I went outside with the intention of flying my Supercub DSM yesterday, but when I plugged in the battery and turned on the transmitter, the elevator immediately went to the full down position.  The elevator stick does not move it, and neither will the trim tab.
Thinking maybe the servo had bit the dust I switched the plugs for the rudder and elevator on the reciever.  The elevator worked, but the rudder went full right. So to me, either the plug on the receiver is screwed, or something in the transmitter is telling it to bottom out in one direction.
Any help you guys can give is appreciated.
Hide Signatures
       Post #: 1
RE: Bunged up transmitter? - 2/20/2012 7:01 PM
BarracudaHockey
Score: 280
Last Login: 5/24/2013
Status: offline
What transmitter?
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to LeviB)
       Post #: 2
RE: Bunged up transmitter? - 2/20/2012 7:31 PM
LeviB
Score: 100
Status: offline
Oh sorry.  It's a Spektrum DX4e. Until yesterday everything was just dandy, so I really have no idea what it could be.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: Bunged up transmitter? - 2/20/2012 9:18 PM
navypoe1
Score: 100
Last Login: 4/11/2013
Status: offline
If you reverse the servo on the Tx does it go all the way up?
Steven
Hide Signatures
(in reply to LeviB)
       Post #: 4
RE: Bunged up transmitter? - 2/20/2012 9:21 PM
navypoe1
Score: 100
Status: offline
I am a futaba guy but i looked on their website and it says you can change modes with a switch. Try it again and see if the throttle stick moves the elevator or will any other stick move the elevator.
Steven
Hide Signatures
(in reply to navypoe1)
       Post #: 5
RE: Bunged up transmitter? - 2/20/2012 9:33 PM
red head
Score: 135
Status: offline
Unplug the battery and turn the tx off in that order. Now turn the tx on then plug the battery in in that order and see if that works. ENJOY !!! RED
Hide Signatures
       Post #: 6
RE: Bunged up transmitter? - 2/20/2012 10:55 PM
LeviB
Score: 100
Status: offline
quote:
ORIGINAL: navypoe1
I used the servo reversing switch on the Tx and the elevator went all the way up.
I also tried what Redhead suggested and that didn't work either.
Hide Signatures
(in reply to red head)
       Post #: 7
RE: Bunged up transmitter? - 2/20/2012 11:23 PM
ckreef
Score: 105
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: navypoe1
+1 on that.
Check out page 13 and 14 of the manual. If you got the transmitter in French mode (mode 1/3) it would behave just as your describing. Page 14 explains how to get it back into standard mode (mode 2/4).
Hide Signatures
       Post #: 8
RE: Bunged up transmitter? - 2/20/2012 11:24 PM
navypoe1
Score: 100
Status: offline
If you reversed it on the Tx and it went the opposite direction then it is something with the Tx and should not be servo or Rx related. Did you move the other sticks and see if the elevator moved? Check out Spektrums website about the DX4e. They have some bulletins about problems with this system. Is your "mode" switch on "mode II"?
Steven
Hide Signatures
(in reply to LeviB)
       Post #: 9
RE: Bunged up transmitter? - 2/20/2012 11:30 PM
navypoe1
Score: 100
Status: offline
Transmitters with affected PIDs may be found in the following products:
Blade mCP X RTF (BLH3500), E-flite Apprentice 15e RTF (EFL2725), Hangar 9 Alpha 40 DSM2 RTF (HAN4400) ,Hangar 9 P-51 Mustang MkII PTS RTF (HAN4425), Hobbyzone Super Cub DSM RTF (HBZ7400), ParkZone Radian RTF (PKZ4700), ParkZone P-51D BL DSM RTF (PKZ2200), ParkZone F4U Corsair RTF (PKZ4600), Phoenix R/C Pro Simulator 3.0 with DX5e (RTM30R5510/RTM30R55101).
This is off Spektrums website.
Steven
Hide Signatures
       Post #: 10
RE: Bunged up transmitter? - 2/21/2012 11:59 PM
LeviB
Score: 100
Status: offline
I did some more looking around and found that Tx's with these PIDs are affected
DX6i/DX5e/DX4e:
PID's beginning with the following prefixes: HS, HH, HT, HE, HA
Mine starts with HO, so I'm not sure what exactly that's supposed to tell me.
Hide Signatures
       Post #: 11
RE: Bunged up transmitter? - 2/22/2012 12:13 AM
navypoe1
Score: 100
Status: offline
Just call them.
Steven
Hide Signatures
(in reply to LeviB)
       Post #: 12
RE: Bunged up transmitter? - 2/22/2012 3:21 AM
ckreef
Score: 105
Status: offline
quote:
ORIGINAL: navypoe1
Just call them.
Just read the manual. Do some testing and figure out what is going wrong then if all else fails Just call them.
When plugged up the way you have it and the rudder or elevator is full to one side have you tried moving your throttle to see what happens?? Plug it up and then move every stick in every direction and write down what moves compared to what stick you moved. This should be the first step in determing what is going wrong. Have you forced your transmitter into std mode and then changed the switch to mode 2?? That transmitter has 4 modes and if your not in the right mode things wont work as expected.
Hide Signatures
       Post #: 13
RE: Bunged up transmitter? - 2/29/2012 1:42 AM
LeviB
Score: 100
Status: offline
For anyone who's interested, it was a short in the elevator rheostat. I picked up a Dx6i to replace it.
Hide Signatures
(in reply to ckreef)
       Post #: 14
RE: Bunged up transmitter? - 2/29/2012 1:46 AM
navypoe1
Score: 100
Status: offline
Thats good. Glad you got it figured out.
Steven
Hide Signatures
(in reply to LeviB)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
