Header TOPQ7925/6    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Kit Manufacturer Direct Support Forum >> Great Planes, TopFlite, Duraplane, US Aircore >> Header TOPQ7925/6
Page: [1]
Login
Header TOPQ7925/6 - 2/21/2012 2:55 PM
edbu1
Score: 100
Last Login: 5/23/2013
Status: offline
Bax: I've been told that this item is no longer available. Is this correct? I also understand that the TOPQ7925 and TOPQ7926 will both work for the G series Suepertigre 75. Is this correct? If discontinued, any replacment headers available?
Ed
Hide Signatures
       Post #: 1
RE: Header TOPQ7925/6 - 2/22/2012 3:27 PM
Bax
Score: 169
Last Login: 5/24/2013
Status: offline
They're different sizes and won't work for both engines. The O.S. is 43.8 mm between the mounting holes and the ST is 47 mm between the mounting holes.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to edbu1)
       Post #: 2
RE: Header TOPQ7925/6 - 2/22/2012 3:31 PM
edbu1
Score: 100
Status: offline
Bax: My understanding is that TOPQ 7925 and 7926 are both for Supertigre engines. The 7920 is for OS engines. I have a ST G-75 engine.
Are the 7925 and 7926 both discontinued with no replacment by Top Flite?
Hide Signatures
(in reply to Bax)
       Post #: 3
RE: Header TOPQ7925/6 - 2/23/2012 12:53 PM
edbu1
Score: 100
Status: offline
With further investigation, it appears that the 7925 header is made for the S series of Supertigre engines, which means that the mounting bolts pass through the header and screw into the engine crankcase. The 7926 header is made for the G series of Supertigre engines, which means that the mounting bolts pass through the engine crankcase and screw into the header. I believe that both have the same, proper dimension from mounting bolt to mounting bolt. So I should be able to use the 7925 on my G series of Supertigre engine. Using the 7925 on the G series will require longer bolts that will pass through the header and be held on with locknuts.
Hide Signatures
(in reply to edbu1)
       Post #: 4
RE: Header TOPQ7925/6 - 2/23/2012 3:43 PM
Bax
Score: 169
Status: offline
I made a bad lookup. I compared the OS header to the ST header. Please note that the ST headers are discontinued and no longer available.
Hide Signatures
(in reply to edbu1)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.157RCU1
