Heli servos for pattern (stab)?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> Heli servos for pattern (stab)?
Page: [1]
Login
Heli servos for pattern (stab)? - 2/21/2012 6:25 PM
gaRCfield
Score: 156
Last Login: 5/25/2013
Status: offline
Any reason for or against using heli servos in pattern? I found a set I'm interested in - size, weight, and strength are just what I need. They have plastic gears and a speed of 0.1sec (too fast?). They are a decent brand, so I'm only concerned about application.
_____________________________
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 1
RE: Heli servos for pattern (stab)? - 2/21/2012 6:39 PM
TimBle
Score: 162
Status: offline
I prefer heli servo's. They are tpically the best quality at any price point. Fast and good enough torque for pattern. Best of feature of all is they return to centre everytime, no over shoot.
Hide Signatures
(in reply to gaRCfield)
       Post #: 2
RE: Heli servos for pattern (stab)? - 2/21/2012 7:32 PM
rcpattern
Score: 100
Status: offline
Agreed. I used to the run the heli 9254 and the BLS254 on the elevator of my Black Magic with the DEPS system. The speed and centering is excellent.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to TimBle)
       Post #: 3
RE: Heli servos for pattern (stab)? - 2/22/2012 1:35 AM
TonyF
Score: 108
Status: offline
Depends entirely on the servo. I tried some of the very fast JR 8717 heli servos on ailerons once and really didn't like them. They are outstanding heli cyclic servos, I use them in several models, but I felt they were a little nervous for a pattern model. So unless someone has some experience with the servo you are thinking of, you're sort of taking a gamble.
TonyF - Team Horizon, Team BJ Craft, Team Contra Drive, Neu Motors
2010,2009 US Masters Champion,2011 Masters Also-Ran
Hide Signatures
(in reply to rcpattern)
       Post #: 4
RE: Heli servos for pattern (stab)? - 2/22/2012 3:42 AM
nonstoprc
Score: 110
Status: offline
A speed of 0.1 sec for elevators is pretty fast. I am using futaba 9650s (rated at 1.1 sec @ 6.0v) and need to dial in -20% exp near the center.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to TonyF)
       Post #: 5
RE: Heli servos for pattern (stab)? - 2/22/2012 6:48 PM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
Everybody seems so concerned because of "fast" servos. The servo will only move as fast as you move the stick on the TX. The fast servo will just be more faithful to the stick movement.
Ken
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to nonstoprc)
       Post #: 6
RE: Heli servos for pattern (stab)? - 2/22/2012 6:54 PM
TimBle
Score: 162
Status: offline
Correct.
And they allow you too input corrective actions quickly and remove the command without big movements. i.e. they are more subtle
Hide Signatures
(in reply to kenh3497)
       Post #: 7
RE: Heli servos for pattern (stab)? - 2/23/2012 4:15 PM
cmoulder
Score: 106
Status: offline
Now that my sequences include snap rolls I am appreciating the benefits of faster servos.
Nothing like having it stop when you tell it to.
Bob
Hide Signatures
       Post #: 8
RE: Heli servos for pattern (stab)? - 2/23/2012 10:26 PM
kenh3497
Score: 115
Status: offline
While I've not used this brand of servo, they got some pretty good reviews on one of the heli websites. The price is sure right and they are fast and strong. Kryptonite gears and the output is unthreaded if you want to tap for a M3 screw.
http://www.audacitymodels.com/products/category.aspx?ID=2a214a63-1e28-4604-8c80-f06b7e38cdea
Hide Signatures
(in reply to cmoulder)
       Post #: 9
RE: Heli servos for pattern (stab)? - 2/24/2012 12:00 AM
nonstoprc
Score: 110
Status: offline
quote:
ORIGINAL: kenh3497
Everybody seems so concerned because of ''fast'' servos. The servo will only move as fast as you move the stick on the TX. The fast servo will just be more faithful to the stick movement.
Ken
To get good scores on most of the pattern sequences, my advice is not to move the elevator stick fast. Rather, you want to move it very gentally around the center and no corrections. You could get better result by loosing some mechanic advantage on linkage so that the stick movement is "amplified". Note that the elevators move no more than +/- 20 or so degrees most of time.
Hide Signatures
       Post #: 10
RE: Heli servos for pattern (stab)? - 2/24/2012 2:17 AM
Rendegade
Score: 105
Last Login: 5/24/2013
Status: offline
When I put savox servos in my wind s, I was amazed at the change in speed of the aircraft's response. It took a while to get used to, as I had to stop 'leading' the plane, and putting in servo movements before they were required, so the servo would move when I needit it to, and as stated above I had to slow my movements down, things got really good.
I now find that slow servos feel 'slow' and I have to lead with my inputs a lot more.
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
       Post #: 11
RE: Heli servos for pattern (stab)? - 2/24/2012 4:46 AM
nonstoprc
Score: 110
Status: offline
Interesting. Which savor servos do you use for elevators? Thx
Hide Signatures
(in reply to Rendegade)
       Post #: 12
RE: Heli servos for pattern (stab)? - 2/24/2012 5:20 AM
Rendegade
Score: 105
Status: offline
The SH 1350's These were in a a windS 110.
Hide Signatures
       Post #: 13
RE: Heli servos for pattern (stab)? - 2/24/2012 6:29 AM
Ekvien
Score: 100
Status: offline
I have been using Align DS 520 on dual elevators and DS 610 on rudder and after 50 flights it seems to be reliable and precise servoes in a mid size pattern plane. So in my next project i consider to use Align all around.
Hide Signatures
       Post #: 14
RE: Heli servos for pattern (stab)? - 2/24/2012 7:14 AM
TimBle
Score: 162
Status: offline
SAvox 1256, 1257
Align DS510 or 610 are excellent.
The Savox Low profile 1251 is winning me over on price and performance. Excellent wing servo's!
Their mini's in the tail of a Wind S would be awesome I imagine.
These and Futaba's new S9072SB is simply stunning pieces of kit for pattern. Ditching my Hyperion's. Too slow and heavy
Hide Signatures
(in reply to Ekvien)
       Post #: 15
RE: Heli servos for pattern (stab)? - 2/24/2012 7:46 AM
Rendegade
Score: 105
Status: offline
I should point out that I'm also running a 1258 on rudder and 1251's on ailerons.
Savox all the way baby!
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
