Engine for TFGS P-51    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Engine for TFGS P-51
Page: [1]
Login
Engine for TFGS P-51 - 2/21/2012 11:39 PM
impulse09
Score: 100
Last Login: 6/18/2013
Status: offline
Which engine would allow for the least amount of cowl cutting? I know a G45 with a prop extension only needs a couple of holes for the carb and spark plug wire. Is this the best choice available? (No electric motors please)
_____________________________
Don S :)
Hide Signatures
       Post #: 1
RE: Engine for TFGS P-51 - 2/22/2012 12:08 AM
Ram-bro
Score: 156
Last Login: 6/19/2013
Status: offline
you need a rear mounted carb like on he DLEs and DAs I believe. The only holes required would be for the muffler. In the pic you will see 2 TFGS P51s, the B model has the G62 and side carb and muffler, the D moel has rear card and a Pitts style muffler soon to be mounted
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to impulse09)
       Post #: 2
RE: Engine for TFGS P-51 - 2/22/2012 12:10 AM
ccostant
Score: 100
Status: offline
DA50 or DLE55 with JTEC P-51 specific muffler. Only cowl openings required are for muffler exhaust tubes on the bottom and airflow for cooling.
Hide Signatures
       Post #: 3
RE: Engine for TFGS P-51 - 2/22/2012 12:30 AM
impulse09
Score: 100
Status: offline
The head or plug doesn't pop out on the DA?
Don S :)
Hide Signatures
(in reply to ccostant)
       Post #: 4
RE: Engine for TFGS P-51 - 2/22/2012 1:02 AM
ccostant
Score: 100
Status: offline
You're right, the head and plug do stick out a bit. But it's pretty hard to cool engines in a P-51 with just the chin scoop opening. I think the only gas engine in the 50cc size that completely fits is the Revolution 52cc. I started out with that but read to many horror stories about overheating so I switched to the DA50. Here's a picture of mine to get an idea of how much the head/plug cap stick out.
Click for fullsize
Hide Signatures
       Post #: 5
RE: Engine for TFGS P-51 - 2/22/2012 1:28 AM
ccostant
Score: 100
Status: offline
Just a thought. If you wanted to go with the DA50, Sierra makes prop extensions (1 1/4 and 1 3/4) for the DA50. That might push the head far enough back to hide the head completely.
Hide Signatures
       Post #: 6
RE: Engine for TFGS P-51 - 2/22/2012 2:18 PM
tciranni
Score: 100
Last Login: 1/25/2013
Status: offline
Will a DA60 fit in this plane without having to cut open the sides of the cowling? I know holes will be required in the bottom for the muffler and cylinder head.
Hide Signatures
       Post #: 7
RE: Engine for TFGS P-51 - 2/22/2012 3:52 PM
ccostant
Score: 100
Status: offline
Can't say for sure on the DA60. I can tell you that a DA50 with a JTEC P-51 specific muffler fits in the cowl without opening up the sides. The DA50 is 81.7 mm (3.22") wide. Couldn't find any mechanical dimensions for the DA60.
Hide Signatures
(in reply to tciranni)
       Post #: 8
RE: Engine for TFGS P-51 - 2/22/2012 4:12 PM
ccostant
Score: 100
Status: offline
Okay found a mechanical for the DA60. Width is 3.147". Looks like it should fit. And JTEC has the specific P-51 muffler for the DA60. You should probably check the length as well to be sure.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Engine for TFGS P-51 - 3/16/2012 6:14 AM
Leroy Gardner
Score: 117
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
Kinda looks like this thread don't have much intrest at this point but here goes.
Engine is DLE 55 with J-tech in cowl muffler. Leroy
Click for fullsize
Click for fullsize
Click for fullsize
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
       Post #: 10
RE: Engine for TFGS P-51 - 3/16/2012 6:02 PM
Meschmidt
Score: 115
Status: offline
If you want the most power, here is how a Husqvarna 4.4 ( 73cc ) fits. Homemade muffler.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
