Gyro For a Warbird Project…..the shame I know I know    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Gyro For a Warbird Project…..the shame I know I know
Page: [1]
Login
Gyro For a Warbird Project…..the shame I know I know - 2/22/2012 4:59 PM
tfarmer96
Score: 125
Last Login: 6/20/2013
Status: offline
I have a large project that will start later this year and because of the type of aircraft I think im going to opt for a gyro on the rudder. I have been told the Mossi is a hand full on the ground so i thought it would be a good idea. Got the fuse in the other day and am buying all the gear for it now. I have never used one before and would like to know what the best gyro for this job would be.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tfarmer96 -- 2/22/2012 6:53 PM >
_____________________________
Spitfire Brotherhood #2
www.wyliewarbirds.com
Hide Signatures
       Post #: 1
RE: Gyro For a Warbird Project…..the shame I know I ... - 2/22/2012 6:08 PM
Scar
Score: 131
Last Login: 6/19/2013
Status: offline
I've used a gyro on my little Sukhoi, because I'm planning to use one on the P-38 that may be finished some day. My experience with the cheap (well, for that price range) Futaba gyro has been good. The sensitivity is adjustable, and it was easy to use.
I will suggest you pick one up and see what it does for you on an aerobatic plane that you're already familiar with.
Just my 2¢ worth,
Dave Olson
The true soldier fights not because he hates what is in front of him, but because he loves what is behind him GKChesterton
Hide Signatures
(in reply to tfarmer96)
       Post #: 2
RE: Gyro For a Warbird Project…..the shame I know I know - 2/22/2012 7:21 PM
tfarmer96
Score: 125
Status: offline
quote:
ORIGINAL: Scar
Just my 2¢ worth,
Dave Olson
That sounds like a good idea i have a 260 i use for a motor breakin plane that would be handy for that.
Hide Signatures
(in reply to Scar)
       Post #: 3
RE: Gyro For a Warbird Project…..the shame I know I know - 2/22/2012 7:43 PM
glazier808
Score: 291
Last Login: 6/18/2013
Status: offline
I've got a Futaba 401 gyro, have not got around to using it yet, but the guys who have talked highly of it.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 4
RE: Gyro For a Warbird Project…..the shame I know I know - 2/22/2012 9:30 PM
ROGER RUSSELL
Score: 115
Last Login: 6/17/2013
Status: offline
http://www.rcuniverse.com/forum/m_6056543/anchors_6056543/mpage_1/key_/anchor/tm.htm#6056543
Read this if you already haven't
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to glazier808)
       Post #: 5
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 12:50 AM
dasintex
Score: 126
Status: offline
Hey Terry;
The link to the other discussion thread that Roger provided has a ton of info; my own experience, I run a Gyro on the Rudder/Tailgear of all my tail dragging Warbirds; I have had excellent results using the Futaba 350GYA Gyro, which was a Gyro that could be used specifically for Airplanes, the 350 was single axis, the 351 was dual Axis, I use it in the AVSC Mode, I turn it on for take off, and off once in the air; unfortunately, the 350 or 351 is no longer for sale in the US; everytime I see one for sale I buy it up; however, the Futaba 401 and the Hobbyking Clone of the 401 I have read work just as well.
Doug.
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 6
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 3:35 AM
dasintex
Score: 126
Status: offline
Terry;
Another Gyro to consider which is made specifically for Planes is the JR G370A http://www.horizonhobby.com/products/g370a-aircraft-rate-gyro-JRPG370A when I run out of Futaba 350 Gyros these JR 370 Gyros look promising, the Futaba 401 should work, I have one but I haven't used it yet; the 350's were great because they were specifically made for planes although the 401's are pretty much the same and should work the same as the 350's
Doug.
P-40 Brotherhood #3
Hide Signatures
(in reply to dasintex)
       Post #: 7
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 5:03 AM
tuskegee
Score: 105
Last Login: 5/25/2013
Status: offline
A GYRO......come on guys......phyic They are great. I have one in my Grasshopper(J-cub). The G370A running abput $160.00 is a good one. Hey they use them at top gun and if it will get me in the sky and help keep me their....I will use it. Oct 2011 Fly RC has a little spot on it and in the Nov 2011 Model Airplane. Also on there web site you can read up on the use of them.
Tuskegee
U.S.Army(ret.)
Hide Signatures
       Post #: 8
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 2:42 PM
77chickenhawk
Score: 105
Status: offline
i have this one for my yellow aircraft p-40 (rudder)
http://www.horizonhobby.com/products/g500t-tail-lock-ring-gyro-heli-JRPG500T
Just Make It Look Real !!!
Hide Signatures
       Post #: 9
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 7:11 PM
Thunderbolt47
Score: 111
Status: offline
For shame Terry!
Not sure a gyro will be of much help on a Mossy. The rudder is so ineffective anyways. The best thing is to counter rotate the engines. A couple of my buds build a Smith Mossy (110") they had 3.2 brisons on it. (over powered for sure) It was very difficult to get in the air with the engines turning the same way. After counter rotating one, it was super easy.
BTW, The full-scale was steered using foot brakes.
Kelly
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 10
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 7:19 PM
tfarmer96
Score: 125
Status: offline
thanks Kelly...this one is a 124 ich blown up Brain Taylor. I didnt want to make one of the da 60 spin backward but I might have to do that if its as bad as i have heard.
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 11
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 9:15 PM
Thunderbolt47
Score: 111
Status: offline
You could always hook the gyro up to the brakes! LOL
124" will be cool for sure.
What retract are you going with. I remember them saying the Centry Jet ones were very pricy for the Don Smith one.
Hide Signatures
       Post #: 12
RE: Gyro For a Warbird Project…..the shame I know I know - 2/23/2012 9:24 PM
tfarmer96
Score: 125
Status: offline
I spoke with Lenny about it im sending him the plans for them and he is going to fix me up
Hide Signatures
       Post #: 13
RE: Gyro For a Warbird Project…..the shame I know I know - 2/24/2012 12:21 AM
flycatch
Score: 118
Status: offline
JR has one designed just for what your needing don't be missled by Futaba.
Hide Signatures
       Post #: 14
RE: Gyro For a Warbird Project…..the shame I know I know - 2/24/2012 2:39 AM
Ed
Score: 121
Status: offline
It's the JR 370 A that you want to be looking at. The A means that it's for Aircraft only. Futaba dosn't have one for aircraft only. It's the latest in MEMS technology, and don't buy a cheap piezo gyro, I have had them fail.
And no shame if you value your aircraft.
ed
Hide Signatures
(in reply to flycatch)
       Post #: 15
RE: Gyro For a Warbird Project…..the shame I know I know - 2/24/2012 5:12 AM
Peter_OZ
Score: 108
Status: offline
who makes the fuz?
fun police have struck again
Hide Signatures
(in reply to Ed)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
