Unseizing nitro engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Unseizing nitro engine
Page: [1]
Login
Unseizing nitro engine - 2/27/2012 12:50 AM
velottatv
Score: 100
Last Login: 5/1/2013
Status: offline
Came across a plane from an estate sale and the engine is seized solid. The plane hasn't ran for several years. It appears to be a .46 but I haven't taken it apart to verify.
Anyone have any ideas on how to unseize? Soak in a cleaner? Heat up? Take apart? Put some oil through the carb then let it sit for awhile? The pilot was very meticulous so I'm sure he took care of it while alive, may he rest in peace.  Other planes were not seized. His collection has sat for at least two years.
Appreciate the help.
Hide Signatures
       Post #: 1
RE: Unseizing nitro engine - 2/27/2012 1:21 AM
Corsairman22
Score: 100
Last Login: 5/10/2013
Status: offline
If you can take it apart then boil water, then add cascade and
soak it.  Get an old toothbrush, the stiff  kind, and start brushing it off.
If it's gummed up or rusty that should take most of it off.  Oil it and
check if the bearings are smooth.  If not then you may have to use it for
parts.
                               Dave
Hide Signatures
(in reply to velottatv)
       Post #: 2
RE: Unseizing nitro engine - 2/27/2012 1:46 AM
DavidAgar
Score: 146
Last Login: 5/19/2013
Status: offline
I would pull off the back plate and inspect the inside. If it has bearing's you will see what kind of condition they are in. You can then fill it up with a good 3 in 1 oil or fuel and let it soak for a while. If it does not loosen up with that it may just be a parts engine. Good Luck, Dave
_____________________________
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to Corsairman22)
       Post #: 3
RE: Unseizing nitro engine - 2/27/2012 1:48 AM
vpresley
Score: 107
Status: offline
Hi
First you might try soaking it in denatured alcohol. Remove the carb, take the glow plug out, remove the back plate, then soak for a day or 2. You can disassemble the carb also. Might try a heat gun if really stuborn. But make sure no alcohol left on engine when you do.
Vince
Hide Signatures
       Post #: 4
RE: Unseizing nitro engine - 2/27/2012 1:06 PM
Rodney
Score: 169
Status: offline
Most probably an engine that used a castor oil based fuel. Just heat the engine up and it will most probably free right up. You can use a heat gun or better to just put it in an oven and heat it to about 250 degrees. Use some gloves and it will free right up if it was because of castor oil. Once free, it will be wise to check it out more closely by either partial or complete disassembly to check bearings etc. Once free, a liberal application of ATF (automatic transmission fluid) or other good oil will lubricate it and keep it free.
Hide Signatures
(in reply to vpresley)
       Post #: 5
RE: Unseizing nitro engine - 2/27/2012 1:42 PM
jester_s1
Score: 233
Last Login: 5/18/2013
Status: offline
I've soaked one in fuel before and it loosened right up after a couple of days.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to Rodney)
       Post #: 6
RE: Unseizing nitro engine - 2/28/2012 11:37 AM
piper_chuck
Score: 126
Last Login: 3/1/2012
Status: offline
quote:
ORIGINAL: Rodney
I use the method you describe to loosen the engine. While it's hot I use alcohol (rubbing, denatured, etc) to remove the gummed up castor. I pour the alcohol in the carb and exhaust ports, turn the engine a bit by hand and then pour it out. While I am doing this I can get a good feel for whether the bearings are smooth or gritty. When the alcohol starts coming out clear I am done. I then put the engine back in the oven to evaporate the alcohol. Then I take it out of the oven and lube it up.
AMA 87959
Hide Signatures
       Post #: 7
RE: Unseizing nitro engine - 2/28/2012 2:59 PM
velottatv
Score: 100
Status: offline
Hi Everyone, Thank you for the great ideas and suggestions. I used a heat gun until it turned after which I ran some fuel through the carb and out the exhaust port. A bunch of sludge came out so I rinsed with denatured alcohol the finished up with after run oil. Scrubbed the outside with the alcohol as well as the glow plug. The engine looks and feels brand new now. I don't think it was ran much from the previous owener as the plane itself requires a lot of work to get in the air. Thanks again for all the help. I plan on making a video of the plane flying to send to his widow just to let her know his spirit is still in RC flying.
Hide Signatures
(in reply to piper_chuck)
       Post #: 8
RE: Unseizing nitro engine - 2/28/2012 7:11 PM
jaka
Score: 158
Status: offline
Hi!
It has been said before and I say it again. If an engine with ball bearings, that has been laying for several years and was previously been run on Castor oil fuel I can garantie that the bearings need to be replaced! Beware! Just because you can turn it over after being heated doesn't mean the balls in the bearings are turning. In fact the axle can just slid on the inner surface of the bearing! Seen this happen mny times!
Soo! The only way of doing it is to take the engine apart and have a real good look at the bearings and do a proper cleaning.
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 9
RE: Unseizing nitro engine - 2/28/2012 11:15 PM
Corsairman22
Score: 100
Status: offline
Thank You!
Hide Signatures
(in reply to jaka)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
