Brushless kv ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Brushless kv ?
Page: [1]
Login
Brushless kv ? - 2/29/2012 3:02 PM
SNOWMAN7765
Score: 100
Last Login: 3/3/2012
Status: offline
 Can someone help me understand the kv when it comes to brushless motors ? I am looking at the Mamba Max pro for my SCT and there are like 4 different kv's do I want a higher or lower number kv ? any info would be greatly appreciated.
Hide Signatures
       Post #: 1
RE: Brushless kv ? - 2/29/2012 3:14 PM
harralk
Score: 100
Last Login: 4/14/2013
Status: offline
the Kv rating for a brushless motor is the rating for "RPM per volt".  It's an obscure value used to determine how fast a motor will spin given a particular voltage input.
Here's an example:
a motor is rated at, let's say, 2000 Kv, and you have a 3S 11.1V battery.  That means at full power the motor will spin at 22,200 rpm.  The motor controller automatically increases power to the motor to get it to spin at the appropriate speed for any given voltage input.
What this means in the real world is that a higher Kv motor will spin faster, but also use more power.  Whereas a lower Kv motor will run longer on a charge, but won't move the car as fast.  One way to get around this is to use a lower Kv motor with a higher voltage battery.  That way you get higher speeds and lower power draws.
Hope this helps a little.
Hide Signatures
(in reply to SNOWMAN7765)
       Post #: 2
RE: Brushless kv ? - 2/29/2012 3:15 PM
crazy nick
Score: 119
Last Login: 5/19/2013
Status: offline
The lower the # the slower. Kv=1000 rpm/volt. A 2200 on 3s (11.1 volts) will spin at 24,420 rpm. A 3800 will spin at 42,280. And so on and so forth. 2s lipo is 7.4 volts so you times that by the kv and will give u the rpms the motor eil spin. All depends on the vehicle what to go w/ 4x4 you want to stay lower kv.more torque the lower you stay. More top speed the higher.
_____________________________
T&L Boyz, Trains & Lanes Easton,PA , Dirty Girl Bodies, freqeskinz.com, Mugen, Team Associated
Hide Signatures
       Post #: 3
RE: Brushless kv ? - 2/29/2012 4:11 PM
yakfish
Score: 426
Last Login: 5/21/2013
Status: offline
higher kv motors will givr you more rpm, but they will also run at a higher tempature compared to a lower kv motor. also the higher kv motor will have less toque than a lower kv motor. Its all about finding that balance between rpm, toque, and tempature.
Hide Signatures
(in reply to crazy nick)
       Post #: 4
RE: Brushless kv ? - 2/29/2012 4:19 PM
Eman77
Score: 375
Last Login: 5/24/2013
Status: online
I believe that Castle Creation's website also has a chart that shows recommended KV motors for different applications (TC, 4x4, etc) to give you a ballpark idea of what's a good range to look for or not for your vehicle. For example, a 7700kV in a big heavy 4x4 offroader - not a good idea. A 2000kV in an onroad lightweight touring car - maybe not a good fit either.
DT02-MS | Durga | Stadium Thunder | TT Frog | VS Tanks | TRF 801XT | CR-01 | F-150 | CRT.5
Hide Signatures
(in reply to yakfish)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
