6mm tygon to 3mm feul pipe?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> 6mm tygon to 3mm feul pipe?
Page: [1]
Login
6mm tygon to 3mm feul pipe? - 3/2/2012 8:58 PM
siddus74
Score: 100
Last Login: 5/18/2013
Status: offline
Guys I need some connectors, 6mm tygon to 3mm feul pipe? (Uat to P20 fuel pipe) can anybody offer any advice on what they use and a possible source?
Scott
_____________________________
siddus74
Hide Signatures
       Post #: 1
RE: 6mm tygon to 3mm feul pipe? - 3/2/2012 9:31 PM
Square Nozzle
Score: 105
Last Login: 5/22/2013
Status: offline
Why can't you make a step down fitting using the appropriate size brass tube for the tygon and solder in step down sizes of brass tube till you get to the size you need for the 3mm?
John
Hide Signatures
(in reply to siddus74)
       Post #: 2
RE: 6mm tygon to 3mm feul pipe? - 3/2/2012 9:42 PM
aquaskiman
Score: 100
Last Login: 5/21/2013
Status: offline
Festo 6 to 4 4 to 3
George
Hide Signatures
(in reply to Square Nozzle)
       Post #: 3
RE: 6mm tygon to 3mm feul pipe? - 3/2/2012 9:48 PM
Dr Honda
Score: 100
Status: offline
If it's really not available... I can turn you some on my lathe, but shipping to the UK will make them expensive.
****EDIT*****
I just looked, and a regular envelope weighing 3oz, with a ridged item is only about $3. Let me know if you want me to make them, and I'll figure out a price. (6m Festo barb to 3m festo barb)
< Message edited by Dr Honda -- 3/2/2012 10:32 PM >
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to aquaskiman)
       Post #: 4
RE: 6mm tygon to 3mm feul pipe? - 3/2/2012 10:35 PM
simont
Score: 100
Status: offline
Scott
Give Als Hobbies a call, they have probably the largest selection of Festo fittings and i am sure they will be able to help you.
Simon
Hide Signatures
       Post #: 5
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 9:16 AM
siddus74
Score: 100
Status: offline
Thanks to all ...
I worked out that the 4mm to 3mm festos can take a 4mm brass tube and the tygon when pushed on over 10mm is a very very good fit ... the ID of the tygon is slightly smaller than 4mm
Scott.
siddus74
Hide Signatures
(in reply to simont)
       Post #: 6
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 9:43 AM
jeff sewell
Score: 100
Status: offline
Perfect - get yourself some wire lock pliers and wire and you're done! Rough up the tube also - around it but not down it's length if you see what I mean!
Jeff
Exclusive UK JetLegend Dealer
Wren Turbines Dealer
Hide Signatures
       Post #: 7
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 9:56 AM
siddus74
Score: 100
Status: offline
Wire lock pliers, where does one get those from?
Scott.
siddus74
Hide Signatures
(in reply to jeff sewell)
       Post #: 8
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 12:04 PM
SniperWj
Score: 100
Last Login: 5/20/2013
Status: offline
Todd hv them
Hide Signatures
       Post #: 9
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 12:55 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: siddus74
Scott.
Al's Hobbies have them, I don't use a UAT with my P20, just a paper filter clunk in the main tank, the clunk is made from a paper filter obtained from "Inline filters" in the UK and a piece of lead soldered onto the bottom, be careful if you go this route as the paper filter is glued to the end caps, the outlet is a turned down brass clunk Hysoled into the other end cap, In case you don't know if you are going to use brass tube solder a barb onto the tube to wire tie behind.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 10
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 2:45 PM
Square Nozzle
Score: 105
Status: offline
quote:
ORIGINAL: siddus74
Thanks to all ...
Scott.
Will the Festo grip on the brass tube so it doesn't work it's way out and cause a leak? That's probably why Jeff is suggesting you rough up the tube. I would pull on the tube to be sure it's secure.
John
Hide Signatures
       Post #: 11
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 2:59 PM
flyinfool1
Score: 100
Status: offline
When I am going to put fuel line onto a piece of brass tube, I always put a single wrap of copper wire around the end of the brass tube and solder it in place, to act as a barb to make sure the fuel line can not come off. I do put a wire wrap on ALL barbed and tube connections.
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 12
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 3:00 PM
CJ2002
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: siddus74
Scott.
Don't waste your money on lock-wire pliers Scott, use ordinary pliers and introduce the tension and twist by hand. Important thing to remember is to put 2 wraps of wire around the tube so you don't end up with a 'pinch' point on the tube and, hence, a potential leak point.
Cheers,
Dick
Hide Signatures
       Post #: 13
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 3:23 PM
Xairflyer
Score: 105
Status: offline
This is what you want to join the tygon to the 3mm festo. It is a 4mm to 3mm reducer the male stem is 4mm.
Click to see fullsize image.
Click for fullsize
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to CJ2002)
       Post #: 14
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 4:07 PM
RCISFUN
Score: 105
Status: offline
http://dreamworksrc.com/catalog/festo-connector-p-58.html
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to Xairflyer)
       Post #: 15
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 4:32 PM
joeflyer
Score: 105
Status: offline
I use a straight hemostat to safety wire fuel and air lines.  Works great.
Hide Signatures
       Post #: 16
RE: 6mm tygon to 3mm feul pipe? - 3/3/2012 10:05 PM
davo580
Score: 100
Status: offline
get some brass step down barb fittings i know that you can get them i use them all the time when needed they are festo fittings if i remember
Hide Signatures
(in reply to joeflyer)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
