whining noise or lag    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> whining noise or lag Page: [1]
Login
whining noise or lag - 3/2/2012 10:42 PM
dbigfoot111
Score: 100
Last Login: 3/24/2012
Status: offline
few days ago i took out my stampede and do a little clean up with WD40. today i took it to bash, it doesn't response like how it used to. the motor is spinning and everything but there is a whining noise, kind of like the motor is spinning but that spinning doesn't delivery to the wheel. its not as strong like it used to be. But when i pick up the truck give it throttle it spin but there is no whining noise. can someone please tell me what is going on? i also did a little adjustment tighten/loose up the clutch but it did not help.
any help is greatly appreciated
Hide Signatures
       Post #: 1
RE: whining noise or lag - 3/2/2012 10:48 PM
t9dragon
Score: 328
Last Login: 5/17/2013
Status: offline
Your slipper pads could be worn out, pinion or spur gear are stripped, need to tighten down the slipper clutch.
Hide Signatures
(in reply to dbigfoot111)
       Post #: 2
RE: whining noise or lag - 3/3/2012 10:13 AM
phmaximus
Score: 627
Last Login: 5/16/2013
Status: offline
yeah its not a good idea for spray oil on the car... all its going to do is make dirt get stuck to the oil.... use a can of compressed air if u dont have a compressor or use a paintbrush to dust it.... & to protect it use a dry silicon lube....
Ur problem could be u have lubricated the slipper clutch.... Do u have any thiners to clean it???
I would recomend removing the slipper assembly, cleaning it & the spur gear with thinners or warm soapy water then refit & adjust...
_____________________________
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to t9dragon)
       Post #: 3
RE: whining noise or lag - 3/5/2012 6:25 AM
dbigfoot111
Score: 100
Status: offline
can someone please tell me what is going on. i took out the diff. clean out to old oil. tired to tighten/loosen up the slipper. nothing has help. it the high rev sound is still there. Pretty much a lag in power, does not delivered to the wheel. i also did tried to crank it all the way down and did a 3/4 turn, but that didnt help. No Wheely on demand at all now. this is how i know there is something wrong.Its just weird how if i pick up the truck, it will not make the lag or weird pitch. When its on the ground it makes a weird pitch and lag in power. Just not as as strong as it used to be. this makes me really sad.
http://i261.photobucket.com/albums/i...1/IMG_1165.jpg
http://i261.photobucket.com/albums/i...1/IMG_1164.jpg
http://i261.photobucket.com/albums/i...1/IMG_1163.jpg
Hide Signatures
(in reply to phmaximus)
       Post #: 4
RE: whining noise or lag - 3/5/2012 6:42 AM
t9dragon
Score: 328
Status: offline
Picture links are not working...
Hide Signatures
       Post #: 5
RE: whining noise or lag - 3/5/2012 7:01 AM
phmaximus
Score: 627
Status: offline
Have u followed the power thro the drive line?
With the gear cover removed, & car sitting on the ground, what happens if u turn the spur gear by hand?
Have u had the wheels off??? are thew wheels still connected to the diff.
Hide Signatures
       Post #: 6
RE: whining noise or lag - 3/5/2012 7:59 AM
dbigfoot111
Score: 100
Status: offline
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1165.jpg
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1164.jpg
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1163.jpg
rear right shock is bent. need to replace that soon
Hide Signatures
       Post #: 7
RE: whining noise or lag - 3/5/2012 10:36 AM
phmaximus
Score: 627
Status: offline
Oh ok it's a new 4x4 stampede..... I just assumed it was the 2wd one...
I have never seen or worked on one of those. So I can't help that much.
There is one way to work out in the problem is in the front or rear..... Well providing it does not have a centre diff
Hold the rear wheels firmly on the ground with the front off the ground, give it some throttle.
Does it slip or make that noise? Or does it spin the wheels?
Do the exact test again but with the front firmly on the ground and the rear in the air...
Is it any difference between the 2 tests...
Hide Signatures
       Post #: 8
RE: whining noise or lag - 3/5/2012 10:41 PM
dbigfoot111
Score: 100
Status: offline
nope no different. or maybe my the stock tires just sucks!! cuase i changed out the tires. no more wheely at all curiosity what happen if i do that test you just told me and everything reponse well does that mean there is nothing wrong with the truck?
Hide Signatures
       Post #: 9
RE: whining noise or lag - 3/5/2012 11:08 PM
t9dragon
Score: 328
Status: offline
What does the slipper clutch pads look like?
Hide Signatures
       Post #: 10
RE: whining noise or lag - 3/6/2012 5:07 AM
dbigfoot111
Score: 100
Status: offline
i'll post up a picture tomorrow.
Hide Signatures
       Post #: 11
RE: whining noise or lag - 3/6/2012 10:17 PM
phmaximus
Score: 627
Status: offline
well if it has the same problems in both tests, it could be a problem with the slipper clutch, or the shafts from that to the diffs...
Yes changing tyres makes a huge differance. Put the other ones back on untill this problem is resolved... when u remove then just check that the hubs still have there pin
Hide Signatures
       Post #: 12
RE: whining noise or lag - 3/7/2012 12:20 AM
kahnen
Score: 141
Last Login: 7/16/2012
Status: offline
Did you glue the tires on?
Hide Signatures
       Post #: 13
RE: whining noise or lag - 3/7/2012 2:54 AM
dbigfoot111
Score: 100
Status: offline
i try to take off the other tires by baking. first time and didnt do it right. so it turn into trash a few days ago i clean up the oil with high air pressure now it seems to response better. here is what my rear differential look like. can you tell me what that black rubber is (slipper?)
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1168.jpg
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1167.jpg
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1166-1.jpg
http://i261.photobucket.com/albums/ii65/dbigfoot111/IMG_1166.jpg
Hide Signatures
(in reply to kahnen)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
