ElectroStik Conversion to Glow    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> ElectroStik Conversion to Glow
Page: [1]
Login
ElectroStik Conversion to Glow - 3/3/2012 4:22 AM
ckreef
Last Login: 5/17/2013
Status: offline
Just got back from the Perry, GA swap meet where I purchased the parts I needed to convert my Great Planes ElectroStik to glow.
There are many glow versions of this plane but I had the ElectroStik and I have never been happy with it as an electic plane so I decided to convert it to glow.  It is a slightly smaller version then their .40 sized glow so I was going to buy a TT Pro .36 for it but ............... I have a brand new TT Pro .46 sitting around  that has just enough run time to be broken in. It will be a slightly large engine for this plane but only slightly. The ElectroStik came as a tail dragger but I ripped the tail wheel off last flight taxing through grass so I am also going to convert it to a tri gear plane.
Off to start the conversion and will post pics as it progresses.
p.s. At Perry, GA I also bought another electric ARF I am going to convert to glow. Once this conversion is finished I will start a new thread for the next conversion.
Hide Signatures
       Post #: 1
RE: ElectroStik Conversion to Glow - 3/3/2012 6:36 AM
Twin_Flyer
Last Login: 5/22/2013
Status: offline
I bet your going to find that the .46 is way too much power for that plane and your first choice of the Pro .36 will be much better.
Whats the second plane you picked up?
Bill S.
_____________________________
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to ckreef)
       Post #: 2
RE: ElectroStik Conversion to Glow - 3/4/2012 2:48 AM
ckreef
Status: offline
You just might be right. I have been debating the .36 or .46 motor for some time now. I guess I need to give it some more thought. Anybody else have an opinion ????
I picked up a Maxford USA Gee Bee "Y" ARF kit. I plan on converting it to glow with a OS .15cv-a (pitts style muffler). After getting it home and making a bunch of measurements it appears doable with a bit of work.
Now onto this conversion. I first wanted to move the main landing gear back so I could convert it into a tri gear plane. (The last electric flight I ripped the tail wheel off taxiing it in grass).
Well I'm trying to upload the pics but RCu is not cooperating. Will try again in a little bit.
< Message edited by ckreef -- 3/4/2012 4:49 PM >
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 3
RE: ElectroStik Conversion to Glow - 3/4/2012 3:11 AM
ckreef
Status: offline
Cut out an opening in the middle 2 of the electric vent holes.
Click to see fullsize image.
Click for fullsize
< Message edited by ckreef -- 3/4/2012 4:50 PM >
Hide Signatures
       Post #: 4
RE: ElectroStik Conversion to Glow - 3/4/2012 4:32 AM
ckreef
Status: offline
You can see the original main gear position (on left) compared to the new position.
Click for fullsize
< Message edited by ckreef -- 3/4/2012 4:51 PM >
Hide Signatures
       Post #: 5
RE: ElectroStik Conversion to Glow - 3/4/2012 4:33 AM
ckreef
Status: offline
Double 1/8" ply main landing gear plate.
Click for fullsize
< Message edited by ckreef -- 3/4/2012 4:52 PM >
Hide Signatures
       Post #: 6
RE: ElectroStik Conversion to Glow - 3/4/2012 4:34 AM
ckreef
Status: offline
Main landing gear plate installed w/ blind nuts.
Click for fullsize
Hide Signatures
       Post #: 7
RE: ElectroStik Conversion to Glow - 3/4/2012 4:36 AM
ckreef
Status: offline
Sorry RCU  would only let me post 1 pic per message whats up with that ???
Main landing gear installed. I used some spare red MonoKote to cover the exposed wood. (Not exactly the same shade but close)
Click for fullsize
< Message edited by ckreef -- 3/4/2012 4:53 PM >
Hide Signatures
       Post #: 8
RE: ElectroStik Conversion to Glow - 3/4/2012 5:17 PM
Twin_Flyer
Status: offline
Looking good!!
Bill S.
Hide Signatures
       Post #: 9
RE: ElectroStik Conversion to Glow - 3/5/2012 3:11 AM
ckreef
Status: offline
Here is the servos reconfigured. I had to move the rudder servo more towards the middle to give room for the stearing linkage. I installed an additional servo for throttle. Also pictured is the charge jack/on/off switch installed.
Click for fullsize
< Message edited by ckreef -- 3/5/2012 3:13 AM >
Hide Signatures
       Post #: 10
RE: ElectroStik Conversion to Glow - 3/5/2012 3:13 AM
ckreef
Status: offline
This is the charge jack/on/off switch installed (outside view).
Click for fullsize
Hide Signatures
       Post #: 11
RE: ElectroStik Conversion to Glow - 3/11/2012 4:55 AM
ckreef
Status: offline
A 200 cc fuel tank (approx. 6.75 oz). 1/4" foam installed everywhere it will touch the fuselage directly.
Click for fullsize
Hide Signatures
       Post #: 12
RE: ElectroStik Conversion to Glow - 3/11/2012 4:56 AM
ckreef
Status: offline
Tank temporarly installed in the battery hatch (to check the fit).
Click for fullsize
Hide Signatures
       Post #: 13
RE: ElectroStik Conversion to Glow - 3/11/2012 5:01 AM
ckreef
Status: offline
Ok, I had a brain fart. The original location of the charge jack was going to conflict with the stearing linkage so I reinstalled it more towards the rear behind all the servos and under their linkage.
Click for fullsize
Hide Signatures
       Post #: 14
RE: ElectroStik Conversion to Glow - 3/13/2012 4:08 AM
ckreef
Status: offline
The back side of the new firewall (sideways). Blind nuts installed for the motor mount and the nose gear assembly.
Click for fullsize
Hide Signatures
       Post #: 15
RE: ElectroStik Conversion to Glow - 3/14/2012 3:17 AM
ckreef
Status: offline
Stearing linkage hooked up to rudder servo temporarily.
Click for fullsize
Hide Signatures
       Post #: 16
RE: ElectroStik Conversion to Glow - 3/14/2012 3:19 AM
ckreef
Status: offline
Firewall installed. Stearing assembly and linkage hooked up temprarily. I still need to cut the top of the stearing arm dowm and install the stearing arm linkage and cut the stearing cable to length. Slowly but surely it's all comming together.
Click for fullsize
Hide Signatures
       Post #: 17
RE: ElectroStik Conversion to Glow - 3/14/2012 2:51 PM
phatboy
Last Login: 6/16/2012
Status: offline
Cool build man. Thanks.
Hide Signatures
       Post #: 18
RE: ElectroStik Conversion to Glow - 3/17/2012 4:06 PM
ckreef
Status: offline
It's an awesome day for flying
The conversion is complete. All I need to do is hookup and adjust the trottle and stearing linkages. The maiden voyage is in my grasp.
OH CRAP - I forgot to charge the Rx battery last night I am completely bummed out.
To top it all off I can't fly tomorrow (previous engagement) which is our normal club day at the field. Oh well will  fly later in the week and take a few final pictures of the build tonight or tomorrow.
Hide Signatures
(in reply to phatboy)
       Post #: 19
RE: ElectroStik Conversion to Glow - 3/18/2012 1:29 AM
ckreef
Status: offline
After my previous post I hooked the charger up to the Rx and let it go for about 3 hours. I then finished up the conversion and went flying.
WOW I am one happy camper.  The conversion was a complete success. This just might be my new best plane. Very smooth flying, decent speed, and decent power. I flew it for 5 tank fulls. Here are the original and the conversion specs.
Great Planes ElectroSTIK origannly speced:
Wingspan 52.75"
Wing Area 589 sq in.
AUW 3 - 3.5 lbs.
Wing loading 11.7 - 13.6 oz/sq ft
Length 45.5 in.
Brushless motor equivelant to a .25 - .30
2200 mah 3s
Tail Dragger
My New conversion specs (same physical size)
AUW 4.25 lbs.
Wing Loading 16.6 oz/sq ft
Glow Motor OS .40 LA
Fuel Tank 6.75 oz.
12 + mins flying time @ 75% of the time WOT
Tricycle Gear.
I was able to acheive proper CG by installing the Rx battery in the fuselage just behind the trailing edge.
This conversion was such a success that I am now going to start on my next conversion. A Maxford USA electric Gee Bee "Y" w/ a 39 in wingspan. Will post a new build thread as that progresses.
Click for fullsize
< Message edited by ckreef -- 3/18/2012 1:30 AM >
Hide Signatures
       Post #: 20
RE: ElectroStik Conversion to Glow - 3/18/2012 4:18 PM
landeck
Status: offline
Very nicely done! You have saved a plane from the dark side!
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 21
RE: ElectroStik Conversion to Glow - 9/10/2012 1:36 AM
ckreef
Status: offline
 A while back I swapped out the .40 LA for a TT Pro .46. She was a screemer with unlimited vertical.
Unfortunatly this Saturday I was really flying her hard at WOT making very tight pylon raceing, full banked turns. Towords the end of the fuel tank the elevator servo started to go out. I cut the throttle way down and attempted to come around for a landing. On the last turn into final the elevator servo totally stripped out. I straightened her out but she slowly sank into the farmers field (past end of runway) doing a cartwheel upon hitting the ground.
Although not a total waste I am not planning on fixing her. I have another more approiate plane I'm looking at to house the TT Pro .46
If anyone attempts this conversion, totally cutout the servo bay and make a new servo plate, one that will hold full size servos. (hind sight is 20/20)
Hide Signatures
(in reply to landeck)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.684RCU1
