Building my first airboat, need help!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> Building my first airboat, need help!!
Page: [1]
Login
Building my first airboat, need help!! - 3/5/2012 9:13 PM
prsabordo
Score: 100
Last Login: 3/6/2012
Status: offline
hey everyone, i have a leftover nitro rc motor (xtm 15) and i want to put it to use.  So i was wondering if i can get some advice on how to build an airboat from scratch.  I was thinking about following this building plan, www.cajungatorairboats.com/id11.html.  What parts will i need to make my motor work for an airboat?  (prop size, prop mounting hardware, etc)  the materials i do have are: servos, transmitter, receiver, normal hardware(nuts bolts, screws), wood glue.
Hide Signatures
       Post #: 1
RE: Building my first airboat, need help!! - 3/5/2012 9:36 PM
dadkins
Score: 104
Last Login: 6/19/2013
Status: offline
I think you will want a bit smaller boat for that motor - more like 14 - 16 " long x 8 -10" wide - not sure you will have enough umph to get the gator goin. Scale it down 25% and that would probably be close.
Also, not sure what that engine is for ? Car ? if so you will probably need a prop hub.
Good Luck !
Hide Signatures
(in reply to prsabordo)
       Post #: 2
RE: Building my first airboat, need help!! - 3/5/2012 9:43 PM
prsabordo
Score: 100
Status: offline
thanks, yea its from a nitro r/c car.
Hide Signatures
(in reply to dadkins)
       Post #: 3
RE: Building my first airboat, need help!! - 3/6/2012 12:31 AM
1QwkSport2.5r
Score: 155
Last Login: 6/20/2013
Status: online
quote:
ORIGINAL: prsabordo
RC car engines don't work well in airboats because the crankshafts are too short. There are ways around it but it's a PITA.
Sell it or run it in a car would be my advice.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 4
RE: Building my first airboat, need help!! - 3/6/2012 4:15 AM
prsabordo
Score: 100
Status: offline
Thats the thing, the motor is discontinued so i cant sell it for anything.  The motor did come out of a car that was also discontinued so i cant find any parts for the car.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 5
RE: Building my first airboat, need help!! - 3/6/2012 1:27 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: prsabordo
If you're set on building a boat, an inboard setup would be the best solution to using the engine. Inboards still use a clutch so the crankshaft length won't be as critical.
Even if the engine is discontinued, if it runs good and holds good compression when warm, you should be able to get $20-$25 for it. Put it in the RCU classifieds and see what happens.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
