YS 110s problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS 110s problems
Page: [1]
Login
YS 110s problems - 3/6/2012 5:29 AM
BPF
Score: 100
Last Login: 4/8/2013
Status: offline
I have had this engine for about a year. On its maden flight it experienced a crash from blowing off the wings of the aircraft. So I sent the engine in to YS parts and service to be repaired and they send it back in about 4 week and they said it was back to working condition. I have been running the engine until to day when I started up the aircraft and when i hit 100% power the engine came to a slow stop and hasn't started since. If anybody has any thoughts please let me know.
Hide Signatures
       Post #: 1
RE: YS 110s problems - 3/6/2012 2:07 PM
petec
Score: 101
Last Login: 5/20/2013
Status: offline
Blockage in the fuel system comes to mind. You'll need to do a little detective work. If the engine is inverted it'll be easier as you can put the throttle fully open and pull the prop through 10-20 rotations and if no fuel is dripping out of the carb then it isn't taking a prime. It is important that you do this by hand as an electric starter will draw the fuel into the engine instead of letting it drip.
_____________________________
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
(in reply to BPF)
       Post #: 2
RE: YS 110s problems - 3/7/2012 1:16 AM
BPF
Score: 100
Status: offline
I thought to try that and it didn't make a difference.
Hide Signatures
(in reply to petec)
       Post #: 3
RE: YS 110s problems - 3/7/2012 1:53 AM
petec
Score: 101
Status: offline
Exactly what did you try?
Hide Signatures
(in reply to BPF)
       Post #: 4
RE: YS 110s problems - 3/7/2012 2:56 AM
BPF
Score: 100
Status: offline
I opened up the carb and hand turned the prop but I also noticed I was not getting any pressure.
Hide Signatures
(in reply to petec)
       Post #: 5
RE: YS 110s problems - 3/7/2012 4:21 AM
petec
Score: 101
Status: offline
How many cranks? Give me all the details you can, it will help me understand what is going on.
Hide Signatures
(in reply to BPF)
       Post #: 6
RE: YS 110s problems - 3/9/2012 8:23 AM
BPF
Score: 100
Status: offline
The engine will start up and idle but when I bring up the throttle it dies.
Hide Signatures
(in reply to petec)
       Post #: 7
RE: YS 110s problems - 3/9/2012 4:55 PM
petec
Score: 101
Status: offline
So what changed to make it go from hasn't started since to will start but not throttle up? My thoughts are still on a blockage in the fuel system or a nicked line in the tank.
If you pull the needle valve out completely, put the throttle wide open (without a glow driver) and crank the engine through you should get a good flow of fuel coming out of the needle valve opening. If not there is something blocking it further up the line. You did flush out the fuel filter right?
Hide Signatures
(in reply to BPF)
       Post #: 8
RE: YS 110s problems - 3/25/2012 5:27 PM
BobV1700
Score: 100
Last Login: 12/22/2012
Status: offline
Just a thought..........................that reminds me of the problems I had which we all discussed on an earlier thread 28/11/2011 or thereabouts. My problem started with the rear bearing cage breaking up and scoring the cylinder and piston very badly. I also found that the fuel system would not pressurize at all and in fact the engine would tick over very briefly but quit as soon as I began to throttle up. I eventually found the brass crankcase bushing had rotated a small amount, enough to completely block off the crank case to regulator vent hole and hence no pressure. Just a bit of a guess here, but if you attach a length of fuel pipe to the crankcase pressure nipple and place the other end in a small container of fuel and then spin the engine over with an electric starter you should see air bubbles in the container of fuel?. If not the crankcase is obviously not producing any pressure and fuel will not flow in sufficient quantity to run properly. Obviously the fuel line(s) and one way valve needs to be checked and properly working in place first.
It just reminds me of my problem, ie no pressure in the system and the engine only running for a few seconds and then quitting.
Bob
Hide Signatures
(in reply to petec)
       Post #: 9
RE: YS 110s problems - 1/6/2013 3:42 AM
cubarican323
Score: 100
Last Login: 5/15/2013
Status: offline
HELLO I HAVE A YS 110 AND I SET UP THE FUEL FILTERS AND CHECK VALVE AND SEALED THE LINES AND WHEN I GO TO START IT MY STARTER BAERLY TURNS THE PROP I THINK IT MIGHT BE LOADING UP. WHAT DO YOU THINK IM DOING WRONG? PLEASE HELP
Hide Signatures
(in reply to BobV1700)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS 110s problems
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
