Have You Had Ignition Failures On Your Gasser?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Have You Had Ignition Failures On Your Gasser?
Page: [1] 2 3 4   next >   >>
[Poll]
Yes
  28% (68)
No
  49% (119)
Failed Pickup
  4% (12)
Failed Ignition Module
  17% (43)
Total Votes : 242
(last vote on : 12/13/2012 3:58 AM)
(Poll will run till: -- )
Login
Have You Had Ignition Failures On Your Gasser? - 3/6/2012 9:07 PM
SteveR Rambin
Score: 105
Last Login: 4/15/2013
Status: offline
Just a poll to see weather or not ignition failures are a common occurrence among you gas burners. Several of my friends now own or have owned gas engines from 20's to 100's by all of the popular manufacturers with most of them having had ignition failures at some time or another. This would tend to get expensive and may be a factor for me to stay with four stroke nitros.
Hide Signatures
       Post #: 1
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 9:27 PM
waynebang
Score: 100
Last Login: 5/21/2013
Status: offline
Ignition failure should not be a factor in determining whether or not to go gas. If you fly long enough you will probably have a failure. The ease of operation and the greater fuel economy of cheaper fuel is a real plus.
_____________________________
Wayne Voyles
combatplanesrc.com
Hide Signatures
(in reply to SteveR Rambin)
       Post #: 2
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 10:03 PM
BadAzzMaxx
Score: 448
Status: offline
I guarantee you that you will spend more on glow plugs than what will be spent on ignitions.
Milton
Contact Milton@rcextremepower.net
Team RCeXtremePower.com
Hide Signatures
(in reply to waynebang)
       Post #: 3
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 10:11 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: SteveR Rambin
....................Several of my friends now own or have owned gas engines from 20's to 100's by all of the popular manufacturers with most of them having had ignition failures at some time or another.....................
Might I suggest you get different friends, some that have better knowledge of gassers.
Seriously, done correctly, it's rare to hear of ign failures.
Instead of a 'poll' why not do a 'Search' with GOOGLE on "RC Ignition failure"
Then figure say less than 3% and figure it out for yourself.
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 4
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 10:19 PM
BadAzzMaxx
Score: 448
Status: offline
I have been selling ignitions for over three years and in that time I think I have had 4 at the most returned from failure, Not sure some of them were from over voltage.
Milton
Hide Signatures
(in reply to a1pcfixer)
       Post #: 5
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 10:39 PM
STUKA BARRY
Score: 125
Status: offline
If your worried about ignition failures, then go magneto. Zenoah and Quadra are still some of the most reliable engines on the market today.
KEEP UM FLYIN
Hide Signatures
(in reply to BadAzzMaxx)
       Post #: 6
RE: Have You Had Ignition Failures On Your Gasser? - 3/6/2012 10:40 PM
hobby_man
Score: 105
Last Login: 3/23/2013
Status: offline
quote:
ORIGINAL: BadAzzMaxx
Milton
I have glow plugs that are 8 years old in the same engine
Hide Signatures
       Post #: 7
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 12:40 AM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
Many times there is no problem with ignition box.
Spark plug cap and boot damaged by a crash is the main problem. Replace the spark plug cap and that's all ...
Hide Signatures
(in reply to hobby_man)
       Post #: 8
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 1:11 AM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: mpascual
That's what I was going to say. Drop one in on it's chin during a less than graceful re-entry and taking that cap out isn't to difficult at all! That's the only way I've managed to loose an ignition.
Hide Signatures
(in reply to mpascual)
       Post #: 9
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 1:18 AM
closetguy
Score: 166
Status: offline
i had one ignition go bad on my first gasser,they are not made to go past six volts.
Hide Signatures
(in reply to ahicks)
       Post #: 10
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 1:19 PM
Diablo-RCU
Score: 110
Last Login: 5/1/2013
Status: offline
I have had failures with DA, 3W and Falkon ignitions. My CH and RCexcl ignitions haven't failed......yet.
Anyone who has been flying gassers for the last decade has seen plenty of ignition failures.
Hide Signatures
(in reply to closetguy)
       Post #: 11
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 1:25 PM
BarracudaHockey
Score: 280
Last Login: 5/20/2013
Status: offline
I've had more servo or mechanical switch failures than ignition failures. On the list of things to worry about, anything on a vibrating airframe can go bad but its not something I'd loose sleep over.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Diablo-RCU)
       Post #: 12
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 1:41 PM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
never for me...
but admittedly I only fly one brand..
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 13
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 2:53 PM
MTK
Score: 203
Status: offline
Interesting.... Suspect that much of the ignition problems, however few, are related to engine vibration getting to the modules. Yet another reason to soft mount most any single cylinder for our models. Twin cylinders are also prone to vibes except quite a bit less.
Been soft mounting my 30cc, 40cc and 55cc engines and over the past 3 years and some 1000 flights, zero issues. And the benefits to airframes and radios are there too
Regards,
MattK
Hide Signatures
       Post #: 14
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 3:32 PM
mogman
Score: 100
Status: offline
I have 3W, RCEXL, CH..(both old throttle coupled and synchro spark), no issues..........(yet!)
Hide Signatures
(in reply to MTK)
       Post #: 15
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 5:39 PM
SteveR Rambin
Score: 105
Status: offline
Good point on the soft mount. Shakey frames breakey wires.
Hide Signatures
(in reply to MTK)
       Post #: 16
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 7:59 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
Been mounting ignition circuits inside on a plate across the engine mount for 24 YEARS..Only failures were my fault, I didn't put enough electronic silicone over the circuit to keep the capacitors and parts from shaking...
Put some C&H circuits there too...Same result....
RC Ignition
Hide Signatures
       Post #: 17
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 8:05 PM
lasers200
Score: 100
Last Login: 5/16/2013
Status: offline
The only ignition I had luck with was CH. Once they went out of business had bad luck with everything else. This is one reason I went back to glow.
Hide Signatures
(in reply to Antique)
       Post #: 18
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 8:29 PM
Ed
Score: 121
Status: offline
3 engines with mags, and 3 engines with ignitions, .................. zero failures !
Hide Signatures
(in reply to lasers200)
       Post #: 19
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 10:18 PM
pe reivers
Score: 646
Status: offline
Having used magneto, CDI and all other kinds of ignitions: Yes, like all manmade contraptions they have failed on me. Sometimes because of my ignorance, sometimes they just failed. So did glow plugs. I threw away more glow plugs than ignitions though. The fact that I carried a dozen spare glow plugs in my glow engine days speaks for itself. Nowadays I do not carry spare ignitions, because gas is much more reliable. Thinking of it, I do carry a spare plug, just in case I need to help a friend out.
PS,
My diesel engines never needed to have a plug changed
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Ed)
       Post #: 20
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 11:01 PM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: pe reivers
..............................Thinking of it, I do carry a spare plug, just in case I need to help a friend out.
I keep all my DLE/3 plugs, just in case somebody I DON'T like needs one.
quote:
PS,
Cheater!
Jim L.
Hide Signatures
(in reply to pe reivers)
       Post #: 21
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 11:04 PM
Warbird Man
Score: 105
Status: offline
Never had a magneto system fail. Electronic ignitions are overated.
Warbird Man
I love the smell of AV gas in the morning.
Smells like.... victory
Hide Signatures
       Post #: 22
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 11:20 PM
scaleman57
Score: 100
Last Login: 5/13/2013
Status: offline
I have to agree with Hobbyman,I have a12 year old Saito 180 in a giant scale Cub with over 200 flights on it and I am still using the original glow plug.If you avoid lean runs they should run for a long time. Ihave been flying gassers for a few years ( DLE ,DA,Fuji) never had an ignition failure,then again I do run them carefuly and only go with 4.8 volts.
Hide Signatures
       Post #: 23
RE: Have You Had Ignition Failures On Your Gasser? - 3/7/2012 11:25 PM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: Warbird Man
I have had magneto systems fail on several occasions. Usually a bad coil and no visible reason for the failure. The spark would just get weaker and weaker over time then finally just go away. The one on my Stihl saw has got weaker over the last two seasons so even those have problems.
No failures on EI yet.
Hide Signatures
(in reply to Warbird Man)
       Post #: 24
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 3:00 AM
kerwin50
Score: 100
Status: offline
Of all the CH ing systems I have seen and been around I don't beleive I have ever seen a bad one not to say there hasn't been one.
Hide Signatures
(in reply to Truckracer)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Have You Had Ignition Failures On Your Gasser?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.593RCU1
