RE: Have You Had Ignition Failures On Your Gasser?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Have You Had Ignition Failures On Your Gasser?
Page: <<   < prev  1 [2] 3 4   next >   >>
[Poll]
Yes
  28% (68)
No
  49% (119)
Failed Pickup
  4% (12)
Failed Ignition Module
  17% (43)
Total Votes : 242
(last vote on : 12/13/2012 3:58 AM)
(Poll will run till: -- )
Login
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 3:47 AM
llindsey1965
Score: 111
Last Login: 5/20/2013
Status: offline
9 gas engines  8 electronic ign 1 magneto  zero failures , but i want to see those 8 year old glow plugs , i never got more than 3 months out of them  , one good flood and the plug was junk  . wow 8 years   !!!!!!!!!!  i always carried 5 or 6 spare glow plugs  when i flew nitro , only spare plug for gas  much cheaper   a few of my gas planes
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to kerwin50)
       Post #: 26
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 5:05 AM
jerrysu29
Score: 111
Last Login: 4/12/2013
Status: offline
Most Ingnition Failures are self induced and the same holds true with the glow engines. Most try to peak a glow engine on the ground take off and a few minutes later have a dead stick or a flight or two. Getting a glow engine to close to peak rpm on the ground results in burning out the element in the plug. Glow engines are the most simple engines to start there is. No matter what size. All my glow and gas engines when set properly start as easy as this one in the video
    http://www.youtube.com/watch?v=G5yM16CxEtA&context=C4795aefADvjVQa1PpcFNsrYXvfMPTTtvbJ_2S-VuGKeHUKwQcaRc=   OS AX 120 on a cool day.
_____________________________
AMA#158633
NMPRA#N33M
IMAA#26755
PROBRO #152
Hide Signatures
(in reply to llindsey1965)
       Post #: 27
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 2:00 PM
Rocketman_
Score: 110
Last Login: 5/25/2013
Status: offline
I only have 4 gas engines and they don't have loads of time on them so I may not be a good data point but I have had no problems with the name brand or the no-name ignition units. No failures out of the box either.
I can vouch for glow plugs lasting for 8 years. Maybe glow plugs are different from what they were in the old days. While It is true that my flying time is divided among several planes, I put a lot of time on them and I know for sure that I have not replaced a glow plug in 8 years. Some are run on 30% nitro.
I've observed experienced modelers leaning glow engines to get the very last RPM out of them on the ground then wonder why the plug won't light for the next flight.
Glow engines start easier than gas engines. How can they not start easier, they are very simple. I'm sure you can get the impression that glow engines are difficult to start when you watch someone jam a starter cone against a spinner on the first start of the day and spin and spin until their wimpy 7Ah starter battery sags. Doesn't it ever occur to some folks that glow engines, like gas engines, need to be choked to get the fuel to the carb?
I generally hand start my glow engines and yes after the initial start of the day they can be started by snapping the spinner in reverse rotation with your finger tips.
I've never used a starter on a gas engine even though it takes more flips to get them started after you get them properly adjusted. I don't consider them to be difficult to start, it just takes a few more flips.
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
       Post #: 28
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 4:10 PM
mikes68charger
Score: 106
Last Login: 5/23/2013
Status: offline
I had one ingition modual go bad, it was on a Hobbyking 52cc TYG motor. After 2 months of flying one day all my servos started to jump around and act funny.
I could hear a high pich sound comeing from the control box. replaced it and no issues since. I only use 4 cell Nicad packs for the control box. I have 6 diffrent other gassers with no issues.
Hide Signatures
       Post #: 29
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 4:11 PM
jerrysu29
Score: 111
Status: offline
Here is a video on how easy a gas engine should start. This was the First flight om my 26% Pilot Sbach with a DLE 30cc that has over 40 hrs. run time  http://www.youtube.com/watch?v=mnvue8CiGac&context=C4e8772dADvjVQa1PpcFNsrYXvfMPTTt3QDLnDHzS5jKcWU3XZ5M4=
AMA#158633
NMPRA#N33M
IMAA#26755
PROBRO #152
Hide Signatures
(in reply to Rocketman_)
       Post #: 30
RE: Have You Had Ignition Failures On Your Gasser? - 3/8/2012 5:39 PM
zx32tt
Score: 110
Status: offline
The only ignition failure I've had was on a DLE 55. The ignition module went belly up after about 30 minutes run time. OMP finally covered it under warranty. Never had a problem with CH ignitions EVER.
Hide Signatures
(in reply to jerrysu29)
       Post #: 31
RE: Have You Had Ignition Failures On Your Gasser? - 3/9/2012 5:35 AM
bcchi
Score: 650
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: zx32tt
Thank you.
BCCHI
Hide Signatures
(in reply to zx32tt)
       Post #: 32
RE: Have You Had Ignition Failures On Your Gasser? - 3/9/2012 2:03 PM
karolh
Score: 310
Status: offline
quote:
ORIGINAL: BadAzzMaxx
I guarantee you that you will spend more on glow plugs than what will be spent on ignitions.
Milton
So very true a statement as in the 10 years that I have been flying gas I have had only one minor ignition issue, which was quite easily fixed.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to BadAzzMaxx)
       Post #: 33
RE: Have You Had Ignition Failures On Your Gasser? - 3/11/2012 3:57 PM
rexbirk
Score: 105
Last Login: 5/18/2013
Status: offline
I started going away from glo three seasons ago. I have had Ignition issues. I did find a number of bad plug boots. They were shorting out internally, not from landing or crash damage though.
I'm going to try to convert my MLD-28's to an RcExcel Ignition and see what happens.
When gas engines are working they are really great. No comparison on fuel costs. When problems come along they frustrate me much more that glo though.
Is being a Circle Flyer a bad thing?
Rex Birkinbine
Hide Signatures
(in reply to SteveR Rambin)
       Post #: 34
RE: Have You Had Ignition Failures On Your Gasser? - 3/11/2012 6:37 PM
WhiteRook
Score: 108
Status: offline
i'm still wondering if the stock 3W IGNITIONS are better than the rxexl ones
Hide Signatures
       Post #: 35
RE: Have You Had Ignition Failures On Your Gasser? - 3/11/2012 11:00 PM
karolh
Score: 310
Status: offline
My friend DaleD has an MLD28 and the original ignition gave a lot of problems which made the engine unreliable. Replacing the stock ignition with an RC exl ignition made all the difference and since then the engine has been running great.
Karol
Hide Signatures
(in reply to rexbirk)
       Post #: 36
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 4:01 PM
SteveR Rambin
Score: 105
Last Login: 4/15/2013
Status: offline
Well thanks to all for the good information and advice. To date on those who responded YES on failures made up 40.2%, with those answering what type failure 75% were ignition module failures. Hopefully if some mfg. rep reads this forum they will look into why there is such a high failure rate. I really like the idea of gas engines, their sound, performance and low fuel cost but it doesn't seem like the ignition reliability is where it needs to be. By the way in the last 5 years of using four strokes I've replaced only 3 plugs.
Hide Signatures
(in reply to karolh)
       Post #: 37
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 4:11 PM
BadAzzMaxx
Score: 448
Status: offline
quote:
ORIGINAL: SteveR Rambin
I think a better poll would be to ask what brand ignition had failures, The problem with just asking about ignition failure is there are are some Asian made engines being sold that no matter what the end user does they are going to fail, Most of these are made by the same company that sells the engines.
Like I posted here earlier I have had maybe at the most of 4 ignitions returned to me in 3 years from product failure.
The RCexl ignition has proven itself to be the best ignition you can get next to the original CH ignition.
Milton
Contact Milton@rcextremepower.net
Team RCeXtremePower.com
Hide Signatures
       Post #: 38
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 4:15 PM
BadAzzMaxx
Score: 448
Status: offline
quote:
ORIGINAL: WhiteRook
For a blunt answer, No
Milton
Hide Signatures
(in reply to WhiteRook)
       Post #: 39
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 5:26 PM
DadsToysBG
Score: 125
Status: offline
After reading this thread I can't help but notice that most of the yes answers were using off brand systems. I have been flying gas for over 10 years and have had only one failure and it was my fault.
It was on a old 3-w. I believe it was a blue dot. I used a 6v battery. I had another one and have been using 4.8 and for the last 6 years it has worked fine. Dennis
DadstoysRC. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 40
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 7:13 PM
Gremlin Castle
Score: 110
Last Login: 5/17/2013
Status: offline
I would have to agree with Milton here based on 20 years of playing with gas engines. With 6 twins and 4 single cylinders in the mix I have had one failure on a CH ignition that had 7 years of continuous service and it was a connection failure between the coil and the high tension lead not an electronic problem. I have loaned a spare RCExcell module to a friend to replace a problem unit that he had with an earlier unit furnished on a Black Canyon G-62 but that is the only RCEXCELL unit that I know of that has had a problem and again it is several years old.
Most problems that I see are damaged plug boot connections and bad switches and cutoff units not the modules themselves. Since most of my collection is DA, Brison Zenoah and Taurus, I can't speak to the reliability of the other systems but I would put the overall all reliability as high as any of the considerable number of large displacement glow engines that I have operated in these same years.
Milton
Up elevator is not always your friend.
Hide Signatures
       Post #: 41
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 7:42 PM
pe reivers
Score: 646
Status: offline
Asking results is one thing. Interpretation of the results is another. Then finally  the most difficult: Phrasing conclusive answers.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Gremlin Castle)
       Post #: 42
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 9:24 PM
SteveR Rambin
Score: 105
Status: offline
Thanks for the good info. The reason I asked this question is firstly I don't know much about gassers and over the past few years what I've heard from friends from all over is " If you buy XYZ (China brand) you may as well get another ignition because the one that comes with the engine will fail in no time".
The other day another club member had trouble with his North American engine that he just got back from the mfg. as repaired ( Hall effect sensor replaced) and told that it ran fine in the shop but wouldn't hit a lick the first time he tried to crank it at the field. We changed plugs to a new one and connected the battery directly to the module. These guys have been flying gas engines for some time and have had ignition troubles with all of them. It makes me wonder if these modules are all made by the same few companies with different logo's stamped on them. The poll was just a way to see if module problems are experienced by gas burners around the country.
Thanks for all comments and who knows, discussing this might point to some mfg's more troublesome than others and may save someone some bucks to boot.
Hide Signatures
(in reply to pe reivers)
       Post #: 43
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 11:02 PM
pe reivers
Score: 646
Status: offline
Intend to do a poll on glow plug and ignition mfg's then? That might yield some interesting results.
One day when tuning a Webra blackhead I burned up my 5 spare Enya #3 plugs. Bad plugs? , bad engine? My bad?
Hide Signatures
       Post #: 44
RE: Have You Had Ignition Failures On Your Gasser? - 3/12/2012 11:10 PM
rexbirk
Score: 105
Status: offline
quote:
ORIGINAL: karolh
Karol
Did your friend have any trouble getting the timing correct? The MLD Ignition fires with the magnet in a different position than the RcExcel. The timing was too far advanced with the RcExcel sensor mounted on the stock sensor boss.
I did get a new Rcexcel sensor holder that has much longer arms. I am going to try that.
I have had a lot of ignition issues with those engines. I have 5 of them. When all is well they run great though.
Rex Birkinbine
Hide Signatures
       Post #: 45
RE: Have You Had Ignition Failures On Your Gasser? - 3/13/2012 3:05 PM
SteveR Rambin
Score: 105
Status: offline
He had just gotten the engine back from the OEM, repaired with a new pickup and told that it ran fine. He installed it on a bipe and took it to the field where it was cranked for the first time since getting it back. We replaced the plug with a NIB, connected the battery directly to the ignition, used different batteries, took the plug out and grounded it while turning it with a starter. No fire at all. I haven't seen him since (2 weeks) so I don't have any more info.
Hide Signatures
       Post #: 46
RE: Have You Had Ignition Failures On Your Gasser? - 3/26/2012 8:25 PM
SteveR Rambin
Score: 105
Status: offline
FYI My gas buddies were out this weekend and I found out that the OEM's ignition module was bad. A new RCEXL ignition module fixed it.
Hide Signatures
       Post #: 47
RE: Have You Had Ignition Failures On Your Gasser? - 9/27/2012 10:49 PM
rexbirk
Score: 105
Status: offline
Milton
+1 on this. Old thread I know but my MLD28 engines now run like watches with RcExcel Ignitions. I went thru more than a year of failed ignitions not realizing it was the ignition. I changed carbs, batteries, switches. Once I installed the Rcexcel on my two engines they ran perfectly. Also had an ignition fail on a PTE36 after an hour and a half of run time. The RcExcel was a direct replacement and fixed that one too!
Rex Birkinbine
Hide Signatures
       Post #: 48
RE: Have You Had Ignition Failures On Your Gasser? - 9/28/2012 12:16 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: lasers200
The only ignition I had luck with was CH. Once they went out of business had bad luck with everything else. This is one reason I went back to glow.
quote:
ORIGINAL: kerwin50
Of all the CH ing systems I have seen and been around I don't beleive I have ever seen a bad one not to say there hasn't been one.
quote:
ORIGINAL: zx32tt
They're back! C&H IGNITIONS NEW WEBSITE
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to lasers200)
       Post #: 49
RE: Have You Had Ignition Failures On Your Gasser? - 9/28/2012 12:38 AM
Ernie Misner
Score: 130
Status: offline
Aren't the flywheel / magneto setups heavier?
Thanks, Ernie
Hide Signatures
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Have You Had Ignition Failures On Your Gasser?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
