RE: SAM's Big Kahuna, April 1st    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Scale Racing >> RE: SAM's Big Kahuna, April 1st Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: SAM's Big Kahuna, April 1st - 4/9/2012 8:58 PM
airraptor
Score: 131
Last Login: 6/20/2013
Status: offline
I flew the little spit this weekend but still have some work left on it. It is still to pitch sensitive. the elevator and rudder are very sharp at only .005-.007 thick. Anyway flew it with a GMS 47 turning a 10x7 at 14,800 ( one of my slow engines) and it was right at 128-130 range. i will rework the stab and rudder tonight and thinking of doing a YS 70 in it. Any thoughts on this. It has 407sq" right now the way you see it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to Tommy_Gun)
       Post #: 126
RE: SAM's Big Kahuna, April 1st - 4/9/2012 10:32 PM
tdstaf
Score: 103
Status: offline
That should be a good combo. I'm working on some with that wing area and motor
Who says scale warbirds have to be GIANT.
Hide Signatures
(in reply to airraptor)
       Post #: 127
RE: SAM's Big Kahuna, April 1st - 4/10/2012 12:13 AM
Jimmy Skids
Score: 100
Status: offline
I have a 70.
Spitfire Brotherhood #99
Outlaw Racing CD 2001 to present
Hide Signatures
(in reply to tdstaf)
       Post #: 128
RE: SAM's Big Kahuna, April 1st - 4/10/2012 12:50 AM
tdstaf
Score: 103
Status: offline
quote:
ORIGINAL: Jimmy Skids
I have a 70.
I thought you were a 1.15 Guy????
Hide Signatures
(in reply to Jimmy Skids)
       Post #: 129
RE: SAM's Big Kahuna, April 1st - 4/10/2012 12:58 AM
Jimmy Skids
Score: 100
Status: offline
actually a 1.20 guy, but I've been known to fly other stuff.
Hide Signatures
       Post #: 130
RE: SAM's Big Kahuna, April 1st - 4/10/2012 1:09 AM
tdstaf
Score: 103
Status: offline
My bad, arn't those getting hard to come by?
You still want a spiteful sized for a 1.15 at some point?
Hide Signatures
       Post #: 131
RE: SAM's Big Kahuna, April 1st - 4/10/2012 4:00 AM
Jimmy Skids
Score: 100
Status: offline
I have a decent collection of the 120's, and they are a little hard to come by, but not impossible. I believe a 1.15 size Spiteful might be a lot of fun to work on, but don't really have a lot of time to commit to projects at this time. I really liked the looks of the original. A 1.15 version would certainly haul the mail. Might have to work out a trade. Did you get your 1.40? I've got some of those also.
Jimmy Skids
Hide Signatures
       Post #: 132
RE: SAM's Big Kahuna, April 1st - 4/10/2012 5:22 AM
pjakew
Score: 100
Last Login: 6/18/2013
Status: offline
Speaking of 115s, I have a question about the mine. Here is a video segment that explains the scenario. Any help would be appreciated.
http://www.youtube.com/watch?v=Eufy2DGM41s&feature=youtu.be
"You Can Teach...Monkeys To Fly Better Than That!"
Hide Signatures
       Post #: 133
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:00 AM
PLANEBENDER
Score: 100
Status: offline
Hi Jake, To do that job the right way contact Central Hobbys and get a puller. They sell them for about $10.00. Here is a link for you. PS, That washer is shot!
http://www.centralhobbies.com/Tools/tool1.html#DRIVE WASHER PULLER
Planebender
If you screw it up , Just add more stickers
Hide Signatures
(in reply to pjakew)
       Post #: 134
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:37 AM
pjakew
Score: 100
Status: offline
Thanks Dave: I will order one ASAP. After you you remove it, how to you press the new one back on?
Hide Signatures
(in reply to PLANEBENDER)
       Post #: 135
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:40 AM
Jimmy Skids
Score: 100
Status: offline
Jake,
Ditto to Dave's comment. You will need a puller, and while you are at it get a new drive washer YS4325. The puller available at Central will work, but you really want something like the posi lock 103 puller.... it's not cheap but works every time. If you need help next time you are in Sacramento let me know and I can give you a hand. Also, I'll show you how to do the valves and then you can make your own video.... I'm camera shy.
Lastly, you may want to incorporate the "Skids Foundation" method for drive washer protection. When using a metal back plate against the drive washer of a YS motor, I install a nylon washer (found at OSH or any other hard ware store) that can be inserted between the drive washer and back plate. When you tighten down the prop/nut combination, the nylon is compressed between the spinner and drive washer. If you do have your prop spin loose the nylon washer will be destroyed, but you will save your drive washer.
Jimmy Skids
Hide Signatures
       Post #: 136
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:41 AM
Jimmy Skids
Score: 100
Status: offline
quote:
ORIGINAL: pjakew
Load the back plate, then prop, then washer and nut and tighten it up.... you'll be good to go.
Jimmy Skids
Hide Signatures
       Post #: 137
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:51 AM
pjakew
Score: 100
Status: offline
Far out fellas, thanks for the input!
Hide Signatures
       Post #: 138
RE: SAM's Big Kahuna, April 1st - 4/10/2012 6:49 PM
ChrisAttebery
Score: 100
Last Login: 5/3/2013
Status: offline
I've been rebuilding motors for 15 years or so. I have a battery terminal puller from Sears that I use to pull drive washers. I put it on and tension the puller, then hit the washer with a propane torch. It will pop right off. That one from Central looks like a POS. Get one that squeezes the arms together as it pulls, like this:
http://www.summitracing.com/parts/OTC-4611
Good luck,
Chris
Attebery Performance Engineering
Retired pylon racer - Losi SCTE - Kyosho SC-R
Hide Signatures
       Post #: 139
RE: SAM's Big Kahuna, April 1st - 4/10/2012 7:28 PM
Jimmy Skids
Score: 100
Status: offline
Chris,
I used to have one of those. They do work well, in fact I believe better than the Central one (I've had both). I ended up having the one you show break when the drive washer was really on tight. I don't use the torch method... probably would blow up my garage with my luck.
Jim
Hide Signatures
(in reply to ChrisAttebery)
       Post #: 140
RE: SAM's Big Kahuna, April 1st - 4/10/2012 9:52 PM
ChrisAttebery
Score: 100
Status: offline
Heat is your friend when disassembling motors. Bearings will fall out, sleeves that are seemingly welded into a case slide out, drive washers that have been over tightened on collets magically pop right off.
I've had that same battery terminal puller for at least 15 years and it still works fine.
I know the feeling on the use of flame in the garage. At one point I had 3-4 cases of 60% fuel, K sized rocket motors, automotive paint and black powder in my garage.
Hide Signatures
       Post #: 141
RE: SAM's Big Kahuna, April 1st - 4/10/2012 10:26 PM
Jimmy Skids
Score: 100
Status: offline
Hearing you on the flame part, but I'm more worried about me being accident prone than the fuel issue.... plus I don't want to blow up my car. I do use a heat gun from time to time on the bearings. I was able to find some of the posi lock pullers on Ebay one time for cheap and bought 3 of them for about what one normally runs. I kept one for myself and gave two away to good friends. One of which went to our local YS doctor. He swears by it now. The one I have is the 103 which is a 3 jaw puller. There is also a 2 jaw version which would probably work almost as well.
Skids
Hide Signatures
       Post #: 142
RE: SAM's Big Kahuna, April 1st - 4/12/2012 11:31 PM
pjakew
Score: 100
Status: offline
Video Update:
Drive washer replaced and review of Central Hobbies washer puller.
http://www.youtube.com/watch?v=j7dGQj1AbWY
Hide Signatures
       Post #: 143
RE: SAM's Big Kahuna, April 1st - 4/13/2012 11:53 AM
skymasterone
Score: 100
Last Login: 3/7/2013
Status: offline
quote:
ORIGINAL: ChrisAttebery
Instead of heat I tighten the puller on the drive washer and strike it with the handle of a screw driver. It pops right off! No heat to set the workshop on fire.
Hide Signatures
       Post #: 144
RE: SAM's Big Kahuna, April 1st - 4/13/2012 9:19 PM
airraptor
Score: 131
Status: offline
as skymaster has suggested this method works well. The thing to remember is to not hit the crankshaft end with anything hard. its best to put the nut on the end and lave the cranshaft just below the nut then you can strike it with a brass hammer. Do not use a dead blow and as it doesnt work with this method.
AMA # 186123
Hide Signatures
(in reply to skymasterone)
       Post #: 145
RE: SAM's Big Kahuna, April 1st - 4/13/2012 10:56 PM
Jimmy Skids
Score: 100
Status: offline
The only thing I hit my motors with is NITRO.... and of course every once and awhile.... the ground.
Hide Signatures
       Post #: 146
RE: SAM's Big Kahuna, April 1st - 4/14/2012 1:31 AM
skymasterone
Score: 100
Status: offline
quote:
ORIGINAL: airraptor
I TAP the side of the drive-washer. No need to get brutal with your engine.
Hide Signatures
       Post #: 147
RE: SAM's Big Kahuna, April 1st - 4/14/2012 3:39 PM
DonStegall
Score: 100
Last Login: 6/12/2013
Status: offline
Skids
Jimmy,
Thanks for the Posi Lock info. I've been looking for a decent long reach puller and both the 103 and 203 say they have a 3" reach http://www.posilock.com/ManPullers/man103opt.htm
Don Stegall - www.RCCalculators.com - The everyday app for R/C Modelers
www.RCPRO.org - www.facebook.com/RCPRO.org
www.Club40Racing.com - www.facebook.com/Club40Racing
www.ABMShowcase.com - www.facebook.com/AirBorneModelsShowcase
Hide Signatures
       Post #: 148
RE: SAM's Big Kahuna, April 1st - 4/15/2012 5:04 AM
Jimmy Skids
Score: 100
Status: offline
After speaking with a couple friends the recommendation is for the 103, which is the 3 jaw puller. It's 10-15 dollars more than the 2 jaw.
Jimmy Skids
Hide Signatures
(in reply to DonStegall)
       Post #: 149
RE: SAM's Big Kahuna, April 1st - 4/15/2012 4:52 PM
speedracerntrixie
Score: 194
Status: offline
Jimmy, I finally made it to Sheldons. No luck on the mount. I do have machining contacts and can check the possibilities of a billet mount.
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
