Throttle Cutoff for electric with 9C    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> Throttle Cutoff for electric with 9C Page: [1]
Login
Throttle Cutoff for electric with 9C - 3/7/2012 10:29 PM
Bob93447
Score: 100
Last Login: 5/8/2013
Status: offline
I have a Futaba 9C that has the 2.4gig conversion module. I am trying to implement a throttle cutoff for my electric. That sort of function works well on the 8FG but I cannot get it to shut down the electric motor when I try to implement the same sort of cutoff with the 9C. Any hints or a detailed recipe available?
Hide Signatures
       Post #: 1
RE: Throttle Cutoff for electric with 9C - 3/12/2012 3:59 PM
Krysta
Score: 100
Last Login: 5/24/2013
Status: offline
What is your THR-REV set to in the Stick mode menu?
Check this and change it, then try setting up the Throttle Cut again.
If this is not the problem, can you give us more detail?
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
service@futaba-rc.com
Hide Signatures
(in reply to Bob93447)
       Post #: 2
RE: Throttle Cutoff for electric with 9C - 3/12/2012 10:10 PM
Bob93447
Score: 100
Status: offline
Krysta,
The throttle channel is reversed. It has been necessary to reverse this channel for every esc that I have encountered to date.
Bob
Hide Signatures
(in reply to Krysta)
       Post #: 3
RE: Throttle Cutoff for electric with 9C - 3/13/2012 4:02 PM
Krysta
Score: 100
Status: offline
Yes, that is normal with Futaba radios, but is the THR-REV set to reverse or normal in the Stick mode menu?
See page 31 of the manual if you are unsure what I am asking.
http://manuals.hobbico.com/fut/9c-super-series-manual.pdf
Thanks, Krysta
Hide Signatures
       Post #: 4
RE: Throttle Cutoff for electric with 9C - 3/13/2012 10:18 PM
Bob93447
Score: 100
Status: offline
Krysta,
No, I have not done the procedure that is described on page 31 of the manual you referenced. I take it that that procedure is necessary to get the trim to work properly? If I do the procedure, it says that it will reverse the throttles on all models in the memory, not just the one I want to reverse. What happens to the nitro models in memory that use the standard procedure?
Bob
Hide Signatures
       Post #: 5
RE: Throttle Cutoff for electric with 9C - 3/15/2012 6:56 AM
Bob93447
Score: 100
Status: offline
Krysta,
I have changed the throttle reverse per the instructions on page 31 of the manual per your suggestion. At this point the rate is set to zero and I get no impact when I switch on Throttle-cut. Do I need to change the rate or is there some other change that needs to be made?
Bob
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
