Phaeton 90 Bi Plane Photo`s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Phaeton 90 Bi Plane Photo`s Page: [1]
Login
Phaeton 90 Bi Plane Photo`s - 3/9/2012 3:43 AM
dutchy50
Score: 101
Last Login: 5/17/2013
Status: offline
 Hello
Here are a few photos of my latest build, Phaeton 90 with OS 120 Surpass 111, ready for covering which will be in Monocote Maroon and Cream.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dutchy50 -- 3/13/2012 5:17 AM >
Hide Signatures
       Post #: 1
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 4:05 AM
rafeeki
Score: 101
Last Login: 5/20/2013
Status: online
Nice build. Who makes this kit?
Hide Signatures
(in reply to dutchy50)
       Post #: 2
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 4:06 AM
AA5BY
Score: 153
Last Login: 5/21/2013
Status: offline
The Phaeton 90 is a fine flyer. No doubt you will enjoy it.
Hide Signatures
       Post #: 3
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 4:27 AM
exsailor62
Score: 100
Last Login: 12/23/2012
Status: offline
Balsa USA makes the Phaeton.  Here is a link to a dealer where I got mine.  http://stewartaircraft.com/store/balsa-usa-model-kit-phaeton-90.html
_____________________________
Sam says - When the engine quits, the flying may not be over but, the fun is gone.
Hide Signatures
(in reply to rafeeki)
       Post #: 4
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 5:06 PM  1 votes
Rodney
Score: 169
Status: offline
I've built several of the Pheatons, both the 40 size and the large one. The last large one is the one I've had the most fun with as I did some extensive mods, much larger rudder with some area ahead of the hinge line similar to the J3 Cub"s, beefed up landing gear, firewall set back and a Quadra 72cc gasoline engine for power. A real ball to fly yet it will still slow down for a nice slow landing. On all of them (as well as a dozen or so other biplanes, I found the secret to nice flying is to make sure the upper wing is at about 1.5 degrees less angle of attack than the lower wing. All of them liked about 3 degrees right thrust and 3 to 5 degrees down thrust in the engine. The relative angle of the two wings was the most critical for nice handling at all flight speeds.
Hide Signatures
(in reply to exsailor62)
       Post #: 5
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 9:45 PM
JCOKEEFE
Score: 105
Status: offline
Beautiful job
Jerry
Hide Signatures
       Post #: 6
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 9:47 PM
exsailor62
Score: 100
Status: offline
I agree on the wing incidence details but, the lower wing saddle needs to be in the design reference to the stab. The Phaeton 90 will float in a headwind and really slow down for landing which makes it a nice bird to be a first "Big Bird" model. Some people recommend adding ailerons to the upper wing but, unless you build more stiffness into the wings as well, you are probably going to be happy with just the lower wing control surfaces.
Hide Signatures
(in reply to Rodney)
       Post #: 7
RE: Phaeton 90 Bi Plane Photo`s - 3/9/2012 10:11 PM
exsailor62
Score: 100
Status: offline
Here is a mod I added to my Phaeton 90 to use the stock muffler and still keep the fuel off the sides of the plane. I put a channel in the bottom of the firewall and fuse bottom to accomodate the muffler.  The engine is an old style ASP 108A off ebay for $68, new in the box.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Phaeton 90 Bi Plane Photo`s - 3/10/2012 5:49 PM
Rodney
Score: 169
Status: offline
Here is mine with Quadra 72cc engine
Click for fullsize
Hide Signatures
       Post #: 9
RE: Phaeton 90 Bi Plane Photo`s - 3/13/2012 5:08 AM
dutchy50
Score: 101
Status: offline
Thanks to everyone who replied to this forum on the Phaeton 90, its a shame Balsa USA don`t mention  anything on the plans or instructions  about incidence, this is my first Bi plane build so I hope it flys well!!!!. Will post more pics when covered, am waiting for my Monocote to arrive from Tower Hobbies. Has  a long way to travel to Australia!!! (hope it arrives soon!)
Thanks again
dutchy50
Hide Signatures
       Post #: 10
RE: Phaeton 90 Bi Plane Photo`s - 3/13/2012 3:31 PM
Gizmo-RCU
Score: 100
Status: offline
Rodney,
All I see is engine, Oh wait there is a plane behind it! I was worried about my G-23 being a little much! Nice plane!
Gizmo
Hide Signatures
       Post #: 11
RE: Phaeton 90 Bi Plane Photo`s - 3/13/2012 4:00 PM
AA5BY
Score: 153
Status: offline
BUSA does comment somewhere about the incidence issue. They actually recommend negative in the lower wing... but most owners choose not to do that after a build because doing so would require shimming the front of the wing in the saddle and I think the wing pegs are quite close to the bottom of the fuselage. It is simply easier to put the negative in the top wing by shims at the aft strut mounts.
As others have pointed out... if in the process of building, the best course would be to adjust the stab a bit positive, which has the effect of moving the wings negative to the stab.
Hide Signatures
(in reply to Gizmo-RCU)
       Post #: 12
RE: Phaeton 90 Bi Plane Photo`s - 3/13/2012 10:08 PM
exsailor62
Score: 100
Status: offline
Here are two photos of my Phaeton incidence checks during final finishing and adjusting “N” struts for soldering. The meter was on zero but may look to be off since I took the picture from an angle.   I check the upper and lower wing at the root and tips to be sure incidence is correct and that the wings aren’t warped. I set the stab at zero by putting te plane on blocks and measured the other surfaces in relation to the stab, since I did not make any adjustments to stab incidence during construction.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Phaeton 90 Bi Plane Photo`s - 3/25/2012 9:56 PM
huntingdad
Score: 100
Last Login: 9/12/2012
Status: offline
I'm in the middle of building the 90 size. Glad I checked the forums.  So far things are going very well. Getting ready to mount the engine. I have an O.S. 1.08 and I'm looking for a pitts muffler so I can mount the engine sideways. In the mean time, I'm getting ready to build the n- brackets for the wings. Looking for suggestions for a color scheme. Any pictures out there? The blue and yellow made me think of the PT-19 I flew as a kid. Might work with the snoopy I'm using for a pilot.
Hide Signatures
       Post #: 14
RE: Phaeton 90 Bi Plane Photo`s - 3/26/2012 1:01 AM
AA5BY
Score: 153
Status: offline
quote:
ORIGINAL: exsailor62
If you set both wings and the stab at zero then be prepared with some shims to prop the upper wing up in the back. About 3/16 ought to be close.
Hide Signatures
       Post #: 15
RE: Phaeton 90 Bi Plane Photo`s - 5/2/2012 10:21 PM
dutchy50
Score: 101
Status: offline
 Here is the finished plane!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: Phaeton 90 Bi Plane Photo`s - 5/2/2012 11:42 PM
Gray Beard
Score: 314
Status: offline
Looks good but it is a shame to have to cover them and hide the bones. I added the ailerons to both top and bottom and got a much better roll rate out of the plane. As I recall the incidence was shown on the plans?? That was a long time ago so I'm probably wrong?
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 17
RE: Phaeton 90 Bi Plane Photo`s - 5/7/2012 1:48 PM
FlyingPilgrim
Score: 100
Status: offline
Holy Cow, Rodney!!! Does that thing have a kick-start?!! How did it balance with that much engine?
I know just enough to be dangerous
Hide Signatures
       Post #: 18
RE: Phaeton 90 Bi Plane Photo`s - 5/7/2012 5:03 PM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: FlyingPilgrim
I didn't say a thing but my first motorcycle only had a 50cc engine. Looks like the power band is just about right though!! I love it, really over the top!
Hide Signatures
(in reply to FlyingPilgrim)
       Post #: 19
RE: Phaeton 90 Bi Plane Photo`s - 5/7/2012 5:41 PM
Rodney
Score: 169
Status: offline
I think the engine and muffler weighed 7 1/2 pounds. I just moved the firewall back a bit and made new landing gear using 1/4 inch music wire. Balanced out well and flys great, still lands at a very low speed. It is currently on the wall as I let a friend fly it and he landed about 4 inches below the runway and the engine and firewall continued on down the runway. Very little damage other than a ripped out firewall.
Hide Signatures
(in reply to Gray Beard)
       Post #: 20
RE: Phaeton 90 Bi Plane Photo`s - 5/19/2012 3:00 AM
ckangaroo70
Score: 115
Last Login: 3/13/2013
Status: offline
My old Phaeton 90 with a Super Tigre 90 in the nose. I had the equivelant of about two concrete blocks up front to get it to balance with that small engine, but it pulled the plane around and boy could that bipe fly slow. Never had any other bipe that could fly so slow on landings. A real floater indeed and real relaxing to fly. I gave it away to another club member to enjoy, but kinda miss it.
Click for fullsize
Hide Signatures
       Post #: 21
RE: Phaeton 90 Bi Plane Photo`s - 9/4/2012 2:33 AM
maxwell 1
Score: 100
Last Login: 5/15/2013
Status: offline
I just picked one of these kits up,and was wondering what motor to use?????????? . Was thinking along the line of Saito twin any and all ideas welcome thanx Max
Hide Signatures
(in reply to ckangaroo70)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
