Fabric Runways ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Fabric Runways ?
Page: [1] 2   next >   >>
Login
Fabric Runways ? - 3/9/2012 6:28 PM
highhorse
Score: 116
Last Login: 6/19/2013
Status: offline
My club is exploring the use of fabrics (GEOTEXTILE. One brand is CONTECH) which lay over grass to form a runway, and is looking for reports of other clubs' experiences please.
The two major concerns thus far seem to be wear and tear from prop strikes and jet exhaust (i.e. Kingcats etc).
Feedback appreciated, thanks!
Don Ray.
< Message edited by highhorse -- 3/9/2012 7:22 PM >
_____________________________
RCU Rocks, I''d hate to be without it !!
Hide Signatures
       Post #: 1
RE: Fabric Runways ? - 3/9/2012 7:03 PM
STKNRUD
Score: 110
Last Login: 6/13/2013
Status: offline
The only "fabric" I know that is being used as a runway surface is Petromat. I have never heard of it being laid over grass. Once it is stapled down, it will stretch tight which I think would form a very undesirable trampoline like surface for a runway if laid over grass. And when the grass died or weeds, gophers came up under it, you would have a very uneven surface.
Petromat requires a very well prepared subsurface to work for any length of time and not have humps and bumps in it after water collects after a few winters, gophers attack, etc. I would not recommend Petromat over grass or even a subsurface that was once grass unless you did a very complete grass kill and subsurface prep.
Prop strikes are a problem for Petromat as are down-thrust jets. You can fly a down-thrust engine on it without issue but it requires the diligent consideration by the pilot...no start or run-ups on it, keep it moving after touch down and taxi-back and an immediate shutdown if you have a gear collapse.
The advantage to Petromat, if asphalt is not an option, is that it does shorten the roll-outs, is less expensive and maybe less daily maintenance than grass. However, you should look carefully at the repeated replacement cost of the Petromat. Depending on climate and thickness of the material (there is a variety of thicknesses) they may only last a few years.
I presume that asphalt is not being considered. If the grass was a good surface for planes, I would almost recommend staying with it over trying to cover it. It is a lot easier to fix if you have a hump or mound. For the most part, Petormat is used only where asphalt is not possible and you only have dirt.
George
I didn''''t say it was the plane''''s fault. I said I was blaming the plane.
Hide Signatures
(in reply to highhorse)
       Post #: 2
RE: Fabric Runways ? - 3/9/2012 7:08 PM
ianober
Score: 105
Status: offline
quote:
ORIGINAL: STKNRUD
The only ''fabric'' I know that is being used as a runway surface is Petromat. I have never heard of it being laid over grass. Once it is stapled down, it will stretch tight which I think would form a very undesirable trampoline like surface for a runway if laid over grass. And when the grass died or weeds, golfers came up under it, you would have a very uneven surface.
Petromat requires a very well prepared subsurface to work for any length of time and not have humps and bumps in it after water collects after a few winters, golfers attack, etc. I would not recommend Petromat over grass or even a subsurface that was once grass unless you did a very complete grass kill and subsurface prep.
George
Man, watch out for those golfers, they will swing those clubs and throw their balls at you!!
I can only assume you meant gophers?
One of the first clubs I flew at used astro-turf. I loved it!!! If you can find a place that is replacing theirs and you can get it for free then great, if not, PRICEY!!!
Hide Signatures
(in reply to STKNRUD)
       Post #: 3
RE: Fabric Runways ? - 3/9/2012 7:12 PM
STKNRUD
Score: 110
Status: offline
Thanks for the spell check.
George
Hide Signatures
(in reply to ianober)
       Post #: 4
RE: Fabric Runways ? - 3/9/2012 7:26 PM
Dr Honda
Score: 100
Status: offline
I fly a grass field, and if it's maintained... it's not to bad. We roll it a couple times a year, and it gets mowed every week during the summer. It's kept like the short grass on a golf course. I can even fly my little electric's off of it.
I don't think any fabric will be worth the time and effort. (for the expense) AND... I don't think it will live very long.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 5
RE: Fabric Runways ? - 3/9/2012 7:51 PM
two dogs
Score: 100
Status: offline
Don, 6 of us jet guys built a 600X60 runway using a heavy duty filter cloth used in highway construction. The product name is Mirafi FW404...it is made in Georgia... Google the product to find a vendor in your area
We built the runway 8 years ago and it has held up pretty well thru the harsh Fla sun and a couple hurricanes. King Cat and Bob Cat engines must have the down thrust greatly reduced to keep from burning the fabric......most other models do fine.
Flying off this fabric is like flying off grass without the dirt/sand. Our cost was about $6000.....
There are some tricks to laying the runway down to get a good smooth surface and to keep it on the ground.
The "best part" is, due to low cost we were able to make it a private "jets only field" ..... and we banned props.....to dangerous!!
if you want more info
727 542 0240
Dave Carter
St. Petersburg, Florida
Hide Signatures
       Post #: 6
RE: Fabric Runways ? - 3/9/2012 8:20 PM
STKNRUD
Score: 110
Status: offline
Petromat and Mirafi are virtually the same product used for the same purpose in asphalt overlays. Just different brands. For road construction, tests should no difference in performance. I doubt there is any difference you would notice as a runway material.
George
Hide Signatures
(in reply to two dogs)
       Post #: 7
RE: Fabric Runways ? - 3/9/2012 10:18 PM
kirkj
Score: 100
Last Login: 6/18/2013
Status: online
quote:
ORIGINAL: two dogs
The ''best part'' is, due to low cost we were able to make it a private ''jets only field'' ..... and we banned props.....to dangerous!!
727 542 0240
Dave Carter
Our club is voting on this very subject next meeting...it should pass the vote. will you please expand on your ground preperation advise?
we did visit one local club that has is down for 3 years now and it looks great. according to them they simply drug a fence to level and kill the grass, filled in low spots with sand and staked it down, tucking the ends on all 4 sides into a trench, and glued the seams with roofing cement. there were many spots from prop strikes that simply had a patch glued on.
Hide Signatures
       Post #: 8
RE: Fabric Runways ? - 3/9/2012 10:36 PM
JackD
Score: 100
Status: online
quote:
ORIGINAL: highhorse
Don Ray.
Our club (Woodland/Davis) went to petromat over a year ago and it seems to be holding fine. The key seemed to be doing a very good prep work on the surface before laying down the petromat. I just helped laying it down, but Dan Avilla and Jeff Lovitt (both in the forum) did a lot of the prep work. You might want to contact them, I'm pretty sure they can give you great advice
The end result is great. it is a little slower than asphalt, but is much more forgiving if you have a wingtip scrape or gear up landing. The biggest limitation seems to be the dowthrust planes like bobcat...
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
       Post #: 9
RE: Fabric Runways ? - 3/9/2012 11:33 PM
highhorse
Score: 116
Status: offline
If the stuff is gonna get toasted by the BVM "cats" etc then we will probably pass... Scorching some grass is no biggie, because the grass repairs itself in a week!
Hide Signatures
(in reply to JackD)
       Post #: 10
RE: Fabric Runways ? - 3/10/2012 12:49 AM
Xairflyer
Score: 105
Status: offline
Funny how everyone refers to it as down thrust when effectively it is up thrust ! The exhaust gases may be pointing down but the thrust is up
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
       Post #: 11
RE: Fabric Runways ? - 3/10/2012 1:22 AM
JackD
Score: 100
Status: online
quote:
ORIGINAL: Xairflyer
Semantics maybe, but it makes the plane go down, so I would consider it down thrust.
Back to petromat....
Jack Gerardo Diaz
Hide Signatures
(in reply to Xairflyer)
       Post #: 12
RE: Fabric Runways ? - 3/10/2012 1:44 AM
dsr71
Score: 100
Last Login: 6/3/2013
Status: offline
actually the product woodland has is geotech mat it has better uv resistance than petromat which i think is designed to be and underlayment for roads,,i agree with the other here that the ground need to be stablized and packed well before the mat is used or you will have the hidden pot holes ,the mat rolls out loose and with a few sunny days tightens up nicely don't be shy with the stakes holding it down ,we went with a stake at least every foot with a 6'' overlap for shrinkage in the centers and folded the edges over a few inches for more holding strength it get very tight after time,,in the end it is working fine dose require patching for prop strikes and turbine exhaust burns ,,but on a good note i show no signs of where on my bvm tires
up till now/bvm/comp-arf/fei bao/flyeagle/jetlegends/skymaster/tamsjet/futaba/hitec/jr/jetcats only
Hide Signatures
(in reply to JackD)
       Post #: 13
RE: Fabric Runways ? - 3/10/2012 3:23 AM
2walla
Score: 100
Last Login: 6/12/2013
Status: offline
If you already have grass and a means to irrigate it, expend the same amount of money in redoing the grass much happier in the long run.. If you are flying off of scrub that you cant get the water to irrigation. Geotextile is better than nothing but it is not maintenance free......... The owner of a local hobby shop here put in a geotextile runway and it was good for a while but all of the gophers digging under it made a lot of lumps.. It was ok for a .40 glow plane but larger scale gas planes could get bounced around a lot and it sucks to break a 75 prop on a perfect landing when you hit a gopher track you cant see under the geotextile...
Hide Signatures
(in reply to dsr71)
       Post #: 14
RE: Fabric Runways ? - 3/10/2012 3:52 AM
STKNRUD
Score: 110
Status: offline
quote:
ORIGINAL: 2walla
Even worse when your jet, just after touch down, gets launched about 3 feet in the air from a hidden hump. Don't ask me how I know.
Hide Signatures
(in reply to 2walla)
       Post #: 15
RE: Fabric Runways ? - 3/10/2012 4:31 AM
Kenrico
Score: 100
Status: offline
i like the idea they used on the field in this video, no idea on cost but it is re usable if you ever have to change the field location.
http://www.youtube.com/watch?v=3J6tPhQMD2k
Hide Signatures
       Post #: 16
RE: Fabric Runways ? - 3/10/2012 5:16 AM
rv9-a
Score: 105
Status: offline
If your club happens to be in the vicinity of a paper mill you can ask them what they do with their used dryer felts. They are made of a synthetic material and can vary in widths and lengths depending on the paper machine. The felts off the machines at the mill I retired from went to several area R/C clubs.
Hide Signatures
(in reply to Kenrico)
       Post #: 17
RE: Fabric Runways ? - 3/10/2012 2:20 PM
aghost
Score: 100
Status: online
kirkj: We just recently replaced our petromat runway. This one had been in service since 2004. here is a link to pictures of that activity. Saturday we pulled up the old runway material. Sunday we laid down the new. Our runway is about 470' x 46'. We do not have any jets flying off the runway.
Our first petromat runway was installed in 1999.
https://picasaweb.google.com/108119852815191614003/BrianSARKSAlbum?feat=email
Hide Signatures
(in reply to kirkj)
       Post #: 18
RE: Fabric Runways ? - 3/10/2012 3:24 PM
aa1a
Score: 100
Status: offline
We put our petromat runway in about 6 years ago. We are going to replace it later in the spring. It is 40 feet wide. We used two 20' wide rolls overlapped and staked in the middle. The stakes were less of a problem than expected but we've found a way to sew the petromat so the stakes will be gone when we replace it. We did a very fine gravel underneath and rented a roller and rolled it. Prop strikes are a problem and we have a patching guy that patches monthly. We are on a very slight slope and despite a lot of effort to improve drainage, we have a problem with the gravel washing out leaving ruts under the petromat. They are more of a tripping hazard than anything else. We have no jet flyers so I can't comment on that. We have the drying belt from a paper mill (mentioned earlier) in our pits. It is also a very nice material. We started laying the material at 7:00 and had a finished runway by noon. Good luck with your project.
Jim
Hide Signatures
(in reply to aghost)
       Post #: 19
RE: Fabric Runways ? - 3/10/2012 5:16 PM
qwerty3
Score: 100
Status: offline
As far as flying off of it - I've found the petromat (or similar) to be rather slippery. A good grass runway is a lot more forgiving for sport-type airplanes on takeoffs - it's easier to keep the plane going in a straight line. For a heli, the petromat is slippery enough to let the machine swivel around on spool-up. The main advantage (over grass) is, of course, for scale-sized wheeled airplanes.
Hide Signatures
(in reply to aa1a)
       Post #: 20
RE: Fabric Runways ? - 3/10/2012 6:52 PM
highhorse
Score: 116
Status: offline
Lots of good info. Thanks guys.
Hide Signatures
(in reply to qwerty3)
       Post #: 21
RE: Fabric Runways ? - 3/11/2012 1:26 AM
hobby_man
Score: 105
Last Login: 3/23/2013
Status: offline
spmrc.com
ours is a belt from a pulp mill, we have aglime graded out under it for a base
Hide Signatures
       Post #: 22
RE: Fabric Runways ? - 3/11/2012 4:45 AM
sideshow
Score: 107
Status: offline
quote:
ORIGINAL: Xairflyer
The thrust on a Bobcat/Kingcat is pointed down...is it not?
eeeexcelent...
Bob Convery
Hide Signatures
       Post #: 23
RE: Fabric Runways ? - 3/11/2012 5:59 AM
STKNRUD
Score: 110
Status: offline
quote:
ORIGINAL: Xairflyer
Can't tell you how much I appreciate the info. Now I know why my jet won't fly...I had the engine in backwards.
Hide Signatures
       Post #: 24
RE: Fabric Runways ? - 3/11/2012 11:52 AM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: sideshow
quote:
ORIGINAL: Xairflyer
Yes the rear of the turbine is pointed down but remember the front is up, Thrust is a reactive force which means which direction it moves, think on a rocket pointing up the stuff out the back makes it go up so the thrust is up.
"To thrust up" to "thrust forward" etc.
www.jmaireland.com
Hide Signatures
(in reply to sideshow)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
