Von Ohain
Score: 100 Joined: 6/2/2005 Last Login: 5/10/2013 From: trondheim, NORWAY Status: offline
A while a go HK launched a new series of motors named "Turnigy XK". Its striking outward similarity, and similarity of specs, lead many (myself included) to believe these motors were rebranded Leopards, sold for a ridicilously low HK price. Because of the low price I ordered a Turnigy XK3674-1650 Kv with the intent of running it in my freshly bought Genesis. Just for the heck of it, I also included the stock Genesis motor in this comparison. Since it coincidentally turned out to be exactly the same can dimensions, 3674, and actually has a slotted stator, just like the Leo! Very rare for a cheapo inrunner, so I thought it might actually not be that bad afterall. So, the motors I will be comparing is: Leopard Red series 3674 2200Kv Turnigy XK series 3674 1650Kv Feisuda FSD 8Xl 3674 2075Kv (HK Genesis stock motor) Mechanical Comparison. End caps: Both supports the same dimension bearings, and look similar. They are also interchangeable between the motors, but they are different, as shown in the picture. Rotors: The rotors of the two motors appear identical, and are also interchangeable. The discoloration of the Leo is because its used, and has rust color. The wire wrapping around both rotors are the same gauge aswell. The shorter length of the Leo rotor is because I had a fight with it and the angle grinder, I guess they were equal length as new. Stators: This is the killer blow for the Turnigy XK. Unlike the Leopard, It does not have a slotted stator. I won't get too technical about why this is bad, but the design of this stator causes a large air gap between rotor and stator, and this is bad for the magnetic properties. Its resistance for magnetic flux. This also shows later on, when I compare efficiency of the motors. The unslottet Turnigy XK suffers badly. Leo on the left, Turnigy on the right. Feisuda FSD 8Xl. And lastly, the surprise from the underdog! An unknown brand chinese motor which contains (some) quality components! This motor does have a slotted stator! But the downside is, it has a rubbish rotor. Its a iron core rotor with magnets glued to the outside of it, and these magnets is not secured by any wrapping of any kind. When this motor gets hot, and spins up to high rpm, these magnets will be guaranteed to separate from the rotor, and ruin the very neat stator of this one. Plus, glued on magnets has worse heat dissipation than one piece magnets, so it overheats easier. Some measurements. I used a small propeller which I ran on each motor. I spun them up to the same RPM, checking with a laser tachometer (16500 RPM). Then I checked their power consumption. Since all motors were running exactly the same load at the same speed. Any differences is power consumption is a direct consequence of the motors efficiency, which in turn also means their heat generation. Since the motors were of different Kv, a slightly lower efficiency is to be expected from the highest Kv motor (Leopard). Leopard: Turnigy: Feisuda: Not surprisingly, the Leopard came out on top, but just with a slight margin. The real surprise here is the Genesis stock motor which is just marginally worse off than the Leopard. The disappointment is the Turnigy XP which is just a Amp hog. With a wind, and core, similar to a KB45 series motor, its outward similarity to a Leopard is just for show. Its amp rating is probably optimistic. Its power ratings is probably achievable, if you double the rated voltage (which you can). Each motors efficiency, compared to the Leopard. (NOT ACTUAL EFFICIENCY!!! If you can find the actual efficiency of any of these motors, I can also calculate the actual efficiency of the rest) Leopard (reference): 100% Feisuda: 95.8% Turnigy XK: 84.9% Edit: Filled in the name of the Genesis motor, thanks to 785boats
< Message edited by Von Ohain -- 3/11/2012 7:39 PM >
Hide Signatures
