RE: ESM 50cc Spitfire Assembly    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM 50cc Spitfire Assembly
Page: <<   < prev  1 [2]
Login
RE: ESM 50cc Spitfire Assembly - 11/5/2012 3:28 PM
ForcesR
Score: 105
Last Login: 2/22/2013
Status: offline
It’s been a while since I last posted, the assembly of the 50cc ESM Spitfire is almost complete. I changed my mind from installing a G62 and purchased the new DLE 55RA, a nice engine and should fit very nicely within the cowl, especially having rear exhaust.
I have run into a problem with installing the engine mount cylinder, its too large in diameter to fit into the fuselage; it’s over sized by approximately 1/16", (2mm). I am sure there are other ESM aircraft owners that have run into a similar problem with the fiberglass engine mount cylinder. Before I start hacking away at the fuselage; I would like to hear what other ESM aircraft owners did to allow the cylinder to fit into the fuselage.
This ESM Spitfire build has been a real pain in the backside; I had to fix problem after problem that should have been picked up by quality assurance before the Spitfire was released by the manufacturer. All other problems were fairly easy fixes, but this engine mount cylinder installation may become a nightmare to fix/fit
Roger
Hide Signatures
(in reply to ForcesR)
       Post #: 26
RE: ESM 50cc Spitfire Assembly - 11/5/2012 7:21 PM
Dbp7966
Score: 100
Last Login: 6/19/2013
Status: offline
Hi Roger,
Yes the DLE 55 will be spot on.
Sorry to hear that you have had so many problems, cant say I have anything to complain about.
Send me the diamieter of both ends and I will check on my spare tube.
Cheers
DB
Hide Signatures
       Post #: 27
RE: ESM 50cc Spitfire Assembly - 11/6/2012 1:28 PM
ForcesR
Score: 105
Status: offline
quote:
ORIGINAL: Dbp7966
Hi Roger,
Cheers
DB
Good day DB; I very much appreciate your assistance. The measurements of your spare cylinder will dictate whether I purchase a replacement mount cylinder or enlarge the fuselage opening. The following measurements of the engine mount cylinder were taken with a digital calliper.
On the cylinder I have, where the engine bolts on is: 5.140” or 130.5mm or 5 9/64” Dia.
The end that inserts into the fuselage is: 5.190” or 131.8mm or 5 13/64” Dia.
The fuselage opening that the cylinder inserts into is: 5.123” or 130.1mm or 5 1/8” Dia.
As you can see by the measurements of the mount cylinder, the fuselage opening is too small by 1.7mm or 3/32” diameter to allow insertion of the engine mount cylinder.
Roger.
Hide Signatures
(in reply to Dbp7966)
       Post #: 28
RE: ESM 50cc Spitfire Assembly - 11/6/2012 2:31 PM
splais
Score: 132
Last Login: 6/20/2013
Status: offline
ForcesR, don't feel like you are especially unlucky. I finished an ESM t-6 II recently. While it flys and looks great, it was a real PITA. Holes misaligned, parts didn't fit, poorly glued in places and on and on. Just huge amount of extra work. I think it is the price you pay for only paying 1/3 of what the plane should cost. Take your pick - cheap and lot of work, or expensive and lot easier. Now that I'm done, not so bad. At the time I was cussing and shouting at the walls.
< Message edited by splais -- 11/6/2012 3:02 PM >
Hide Signatures
       Post #: 29
RE: ESM 50cc Spitfire Assembly - 11/11/2012 2:45 PM
Dbp7966
Score: 100
Status: offline
Hi Roger,
Sorry its taken me a while but had to replace my  digital calliper.  My spare tube measures:
5.128"  or 130.29 mm at the engine mount end and 130.51mm at rear end.
If i remember mine was a tight fit.
Hope this helps you.  Anything else you need just let me know.
I also have a spare fuz so if you require anything just ask.
Cheers
DB
Hide Signatures
(in reply to splais)
       Post #: 30
RE: ESM 50cc Spitfire Assembly - 11/14/2012 8:04 PM
ForcesR
Score: 105
Status: offline
DB; thank-you for the information, I very much appreciate your time and effort to assist me. Your spare engine mount is smaller in diameter then the one I have, so based on your measurements I am going to order a replacement mount. There is no way I would even try to insert this oversized engine mount into the fuselage.
Roger
Hide Signatures
       Post #: 31
RE: ESM 50cc Spitfire Assembly - 11/14/2012 8:18 PM
Dbp7966
Score: 100
Status: offline
Hi Roger,
The pleasure is all mine.  I agree I would not try putting that in, you would not get it out LOL.
Just ask  Cheers
DB
Hide Signatures
       Post #: 32
RE: ESM 50cc Spitfire Assembly - 3/24/2013 6:52 PM
Meschmidt
Score: 115
Status: offline
Unfortunately I lost my ESM 89" Spitfire during testing. I have a perfectly good engine cowling, set of Spring Air retracts, Likes Line struts, wheels wheel pants, and cannons ready to drop in if anybody interested. Will sell all at a reasonable price. Paul
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Meschmidt -- 3/24/2013 7:38 PM >
Hide Signatures
       Post #: 33
RE: ESM 50cc Spitfire Assembly - 3/24/2013 7:04 PM
91zulu
Score: 130
Status: offline
Ah man that sucks major...
_____________________________
91-Zulu
Hide Signatures
(in reply to Meschmidt)
       Post #: 34
RE: ESM 50cc Spitfire Assembly - 3/24/2013 8:14 PM
Dbp7966
Score: 100
Status: offline
Hi Mate,
Really sorry to hear that and she looked pritty nice.
DB
Hide Signatures
(in reply to 91zulu)
       Post #: 35
RE: ESM 50cc Spitfire Assembly - 3/24/2013 8:25 PM
OldScaleGuy
Score: 120
Status: offline
Sorry to hear that. Too far gone for a rebuild?
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 36
RE: ESM 50cc Spitfire Assembly - 3/24/2013 9:51 PM
Meschmidt
Score: 115
Status: offline
Yes, not rebuildable. Suspect one of the elevator servos gave out. This plane flies really well and flew it about a dozen times getting the engine settings right. It surprised the hell out of me when it went in. I guess a I'm not meant for a Spitfire. Lost two in a year. Paul
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 37
RE: ESM 50cc Spitfire Assembly - 3/29/2013 3:30 PM
Meschmidt
Score: 115
Status: offline
Anybody need these? Look in the buy and sell section on warbirds for details. $250. Paul
Click for fullsize
< Message edited by Meschmidt -- 4/4/2013 10:08 PM >
Hide Signatures
       Post #: 38
RE: ESM 50cc Spitfire Assembly - 4/4/2013 1:51 PM
dgiatr
Score: 100
Status: offline
quote:
ORIGINAL: Meschmidt
didnt you have elevator pull pull system on it;
Hide Signatures
       Post #: 39
RE: ESM 50cc Spitfire Assembly - 4/4/2013 2:04 PM
Meschmidt
Score: 115
Status: offline
No, I used two elevator servos in tray with carbon fiber pushrods.
Hide Signatures
(in reply to dgiatr)
       Post #: 40
RE: ESM 50cc Spitfire Assembly - 4/4/2013 6:31 PM
fw190
Score: 100
Status: offline
What servos were you using?
It seems the only way for an elevator problem with two servos is one of them completely locking up in a full deflection. ( I don't use a y connector on dual elevator servos, I use two channels on the receiver instead)
Happy Flying!
Hide Signatures
       Post #: 41
RE: ESM 50cc Spitfire Assembly - 4/4/2013 10:05 PM
Meschmidt
Score: 115
Status: offline
I think thats where I screwed up. I used Hobby People AM 50 High Torque Metal Gear servos. The plane was flying straight and level, basically hands off, then took a nose dive from 300 feet. I don't think the servo stripped in flight, but rather the vibration caused the electronics in one of the elevator servos to go AWOL. The crash was so bad, there was not much evidence left electronically to analyze the problem. By the way, the two elevator servos were on a Y harness. One going bad will affect the other one.
Hide Signatures
(in reply to fw190)
       Post #: 42
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
