Need help starting nitrostar .12    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Need help starting nitrostar .12
Page: [1]
Login
Need help starting nitrostar .12 - 3/12/2012 11:52 PM
dark321devil
Score: 105
Last Login: 4/6/2013
Status: offline
i recently decided to get back into the hobby after a 2 year break. I got all my cars back running except my hpi nitrostar .12.
Symptoms:
- starts and runs only at half-full throttle. as soon as i let off, it dies. tried manufacturer settings and everything in between setting wise.
- fuel is good as it runs in all my other nitros with no problem.
- tried new plug
- made sure to rule out possible air leaks.
What am i missing?
Hide Signatures
       Post #: 1
RE: Need help starting nitrostar .12 - 3/13/2012 12:54 PM
controlliner
Score: 100
Last Login: 5/22/2013
Status: offline
Check your low speed needle. If it only has a HSN, check you idle stop screw and readjust the throttle opening to 1/16 in. You may be able to go to 1/32nd but throttle response may be a bit dodgy.
_____________________________
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to dark321devil)
       Post #: 2
RE: Need help starting nitrostar .12 - 3/13/2012 2:19 PM
Argess
Score: 151
Last Login: 5/23/2013
Status: online
Maybe try cleaning the carb. It could be gummed up after this time.
Sometimes when mine sit for a while, they run like that, but sort of clean themselves as fuel runs through the carb and after about 1/2 tank of running they're fine.
Hide Signatures
(in reply to controlliner)
       Post #: 3
RE: Need help starting nitrostar .12 - 3/14/2012 3:48 AM
JohnP2
Score: 268
Status: offline
Have you tried increasing the idle some? Does it idle and run fine, but once you go OVER 1/2 throttle and release it dies? Perhaps your HSN might be a litle rich?
I had a similar problem once, and leaned the HSN a bit and it took care of it. Just a thought.
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
(in reply to Argess)
       Post #: 4
RE: Need help starting nitrostar .12 - 3/15/2012 12:56 AM
dark321devil
Score: 105
Status: offline
its the other way around. It only stays alive at half throttle or more. dies even at 1/4 throttle.
Hide Signatures
(in reply to JohnP2)
       Post #: 5
RE: Need help starting nitrostar .12 - 3/15/2012 2:51 PM
controlliner
Score: 100
Status: offline
Check Idle Stop setting. These engines were made by Toki in Japan and they have simple carbs. If it runs at full throttle, then it's the idle stop screw. I have the .15 version and it has the same carb.
Hide Signatures
       Post #: 6
RE: Need help starting nitrostar .12 - 3/16/2012 4:08 AM
dark321devil
Score: 105
Status: offline
ok i will try all of these this weekend. but correct me if im wrong. i havent played with idle screw becuase i am under the impression that if it was idle screw issue, the engine would have been running at minimal throttle? i know it wouldnt run at no throttle but if it was idle screw wouldnt it at least run at minimal throttle?
Hide Signatures
       Post #: 7
RE: Need help starting nitrostar .12 - 3/16/2012 12:47 PM
controlliner
Score: 100
Status: offline
The thing is, if the idle stop screw moves from a good setting due to vibration you will have problems with a dependable idle. As smooth as these engines seem to run, they vibrate at super high frequency and it is this frequency that loosens adjustment screws only secured by a spring.
Hide Signatures
       Post #: 8
RE: Need help starting nitrostar .12 - 3/16/2012 2:45 PM
proanti1
Score: 341
Last Login: 1/6/2013
Status: offline
quote:
ORIGINAL: controlliner
They were actually made by Shuwa (Mecoa), who manufactures engines for Toki, HPI, Tamiya, and several other companies.
Her name was Lola. She was a show girl.
Hide Signatures
       Post #: 9
RE: Need help starting nitrostar .12 - 3/17/2012 3:44 AM
JohnP2
Score: 268
Status: offline
Did you get this fixed? If so, what was it?
Hide Signatures
(in reply to proanti1)
       Post #: 10
RE: Need help starting nitrostar .12 - 3/17/2012 3:52 AM
dark321devil
Score: 105
Status: offline
unfortunatly no. i planned on taking the engine off and and attaching it to a piece of wood to rule out almost everything.
I got the engine off the car and realized the flywheel was spinning free of the shaft. After a painstaking amount of labor i finaly got the clutch bell off. It was a pain to get off as the flywheel was loose from the shaft.
both spring on the clutch were cracked and broken. Now i cannot get the flywheel off the shaft. the nut holding the flywheel on is impossible to turn as when i turn it, it turns with the shaft. i have tried using a fan for heat with no luck. im at my wits end with this engine.
this engine has less then a gallon of gas through it so i dont want to junk it until its the ONLY option.
Hide Signatures
       Post #: 11
RE: Need help starting nitrostar .12 - 3/17/2012 1:33 PM
controlliner
Score: 100
Status: offline
The broken clutch springs would contribute to an unreliable idle. There might be thread locker on the flywheel nut. Heat the nut with a heat gun.
Hide Signatures
       Post #: 12
RE: Need help starting nitrostar .12 - 3/22/2012 3:42 AM
dark321devil
Score: 105
Status: offline
i finally got it off. some of you may not agree with how i got it off but i believe it was the only way. i took the head off the motor to where i can see the piston moving up and down. i used a piece of rubber (the rubber cap off glow ignitor) and 2 pencils inside the rubber cap to hold the piston from moving while i unscrewed the flywheel. i just ordered a new flywheel, collet, and clutch. once it comes in i will test it out and let you guys know
Hide Signatures
       Post #: 13
RE: Need help starting nitrostar .12 - 3/28/2012 11:42 PM
dark321devil
Score: 105
Status: offline
So I received the parts and replaced them.put the engine back to factory settings. Started right up. Purred like a kitten
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
