RE: Another Ziroli DC 3 to be built...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Another Ziroli DC 3 to be built...
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Another Ziroli DC 3 to be built... - 11/4/2012 1:58 AM
Fili
Score: 100
Last Login: 5/24/2013
Status: offline
Are flaps needed, and how are the wings secured?
_____________________________
Phil
CORSAIR Brotherhood #20
Hide Signatures
(in reply to Fili)
       Post #: 26
RE: Another Ziroli DC 3 to be built... - 11/4/2012 5:43 AM
SIMCO
Score: 100
Last Login: 5/20/2013
Status: offline
Depends where you fly . If you fly in a no approach tree ring like me they will help. Long approach cornfield style I don't think it would make that much difference. Looks nice. Wing is bolted on in the 4 corners of the the fusalage.
Hide Signatures
(in reply to Fili)
       Post #: 27
RE: Another Ziroli DC 3 to be built... - 11/4/2012 1:04 PM
Fili
Score: 100
Status: offline
SIMCO you"re the best, thanks for your replies. My wing question is about after sliding the wing ends in the center section, is there any way that secures them to the center section? Set screw? hook? velcro? (Lol) or are then snug enough so that they stay on...?
Phil
Hide Signatures
(in reply to SIMCO)
       Post #: 28
RE: Another Ziroli DC 3 to be built... - 11/4/2012 3:15 PM
SIMCO
Score: 100
Status: offline
Generally a set screw will hold it. The Ziroli version has an internal hardwood block that is glued to the wing tube socket. It's threaded and the wing tube itself from the panel. If yours doesn't have it. i would suggest a strap arrangement across the 2 halves. IN HARDWOOD. Not some crappy balsa. Mininum hackjob. Might want to pin search the wing socket area at the 2 halves to look for a hardwood block. Maybe an inch or 2 at the most from the root. Also eyeball the socket, might have been done all ready.
Hide Signatures
(in reply to Fili)
       Post #: 29
RE: Another Ziroli DC 3 to be built... - 11/5/2012 9:25 PM
Fili
Score: 100
Status: offline
Wheels and fuel tanks in today!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to Fili)
       Post #: 30
RE: Another Ziroli DC 3 to be built... - 11/10/2012 3:33 PM
Fili
Score: 100
Status: offline
SIMCO, how much run time did you get on the 15oz tanks with the G38s?
Phil
Hide Signatures
(in reply to Fili)
       Post #: 31
RE: Another Ziroli DC 3 to be built... - 11/11/2012 5:42 AM
SIMCO
Score: 100
Status: offline
Half power flying about 20 minutes. More than plenty. Also figure in about 2-3 oz just in the fuel line.
Hide Signatures
(in reply to Fili)
       Post #: 32
RE: Another Ziroli DC 3 to be built... - 11/20/2012 10:23 PM
Fili
Score: 100
Status: offline
Center section mounted... Holy Moly she's big!
Click for fullsize
Phil
Hide Signatures
(in reply to SIMCO)
       Post #: 33
RE: Another Ziroli DC 3 to be built... - 12/11/2012 3:18 AM
2engsout
Score: 100
Status: offline
Hi Guys, I have 42 great flights on my Ziroli DC-3. I was the beta tester for the twinsync for gas engine applications from 2006- 2009. There are certain things that need to be done to it for reliable flight that are not in the book. You can see my DC-3 if you search Youtube videos " DC-3 by Rick Simmons FLt 2". The modifications outlined in the info is quite long so I did'nt post it, but it is a must read for anyone who is building or owns one. Send me a PM with your email and I will send it to you. It includes pics of what I did to the tail wheel. 2engsout
Hide Signatures
(in reply to Fili)
       Post #: 34
RE: Another Ziroli DC 3 to be built... - 12/11/2012 4:58 AM
Props4ever
Score: 106
Last Login: 5/23/2013
Status: offline
Its great to see the thread is still going on and more guys are building these awesome ZDc 3 models but you guys need to stop teasing me...I have pushed DC 3 in favor of 1:12 Boeing B747SP right from scratch ground up. Don't take me wrong I still very much enjoy these builds and will build my model eventually......almost lost 2 great deals on all built up ones due to logistic issue between US and Canada....
I do believe in KISS (Keep it simple silly), but doesn''t mean my models fall in this category!
CUB BROTHERHOOD# 173
Hide Signatures
(in reply to 2engsout)
       Post #: 35
RE: Another Ziroli DC 3 to be built... - 1/4/2013 12:44 AM
Fili
Score: 100
Status: offline
Beginning to glass...
Click for fullsize
Phil
Hide Signatures
(in reply to Props4ever)
       Post #: 36
RE: Another Ziroli DC 3 to be built... - 1/4/2013 2:01 AM
SIMCO
Score: 100
Status: offline
You will need a wallpaper spreader when you get to the wings. Just grind off the teeth. HA
Click for fullsize
Hide Signatures
(in reply to Fili)
       Post #: 37
RE: Another Ziroli DC 3 to be built... - 1/4/2013 2:25 AM
Fili
Score: 100
Status: offline
quote:
ORIGINAL: SIMCO
Ha! I always used a credit card (expired of course...Lol)
Click for fullsize
Phil
Hide Signatures
(in reply to SIMCO)
       Post #: 38
RE: Another Ziroli DC 3 to be built... - 1/19/2013 5:43 PM
Fili
Score: 100
Status: offline
Slow but sure.... Progress is progress. I got my pilots fromhttp://www.bestpilots.typepad.com/ awesome, Thanks Lyle! More glassing and sanding...
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to Fili)
       Post #: 39
RE: Another Ziroli DC 3 to be built... - 1/19/2013 6:31 PM
ivves
Score: 100
Last Login: 5/18/2013
Status: offline
Hi there.
Here is a video of my Ziroli DC-3. http://www.youtube.com/watch?v=mLGP9JcAPVk Still flying great.
And here is my photoalbum building the DC-3 https://picasaweb.google.com/114147169365273223027/MyDC3ZiroliAlbum#
Ivan
Hide Signatures
(in reply to Fili)
       Post #: 40
RE: Another Ziroli DC 3 to be built... - 1/20/2013 7:14 PM
PLANEINSANE1
Score: 100
Last Login: 4/18/2013
Status: offline
will resize...file too big he sez...shheeshh
< Message edited by PLANEINSANE1 -- 1/20/2013 8:27 PM >
Hide Signatures
       Post #: 41
RE: Another Ziroli DC 3 to be built... - 1/20/2013 7:19 PM
PLANEINSANE1
Score: 100
Status: offline
My nearly finished dc3....in the Philippines
Hide Signatures
       Post #: 42
RE: Another Ziroli DC 3 to be built... - 2/2/2013 6:20 PM
Fili
Score: 100
Status: offline
thanks ivves, I've seen your flight on youtube before..Nice!
Cockpit done, nose attached, filling and sanding now. Does anyone have a pick of their engine mounted, I'm going with the G38, but did you guys use the mount?
http://www.bennettbuilt.com/shop/EnginesZenoah_BG38_CID.html
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to PLANEINSANE1)
       Post #: 43
RE: Another Ziroli DC 3 to be built... - 2/3/2013 3:41 PM
SIMCO
Score: 100
Status: offline
I used the flat steel plate with the G38. Worked good. You will however need to make aa balsa ring on your firewall for the cowl to fit. Also used the factory exhaust.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Fili)
       Post #: 44
RE: Another Ziroli DC 3 to be built... - 2/7/2013 1:37 AM
Fili
Score: 100
Status: offline
Thanks Simco. Looks like that factory exhaust wont stick out as far as the BB muffler..... Moving along with the glassing. Should be able to start panel lines this weekend. Here's my color scheme!
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to SIMCO)
       Post #: 45
RE: Another Ziroli DC 3 to be built... - 2/18/2013 1:10 PM
Fili
Score: 100
Status: offline
Moving along. I have today off and every second of it is dedicated to thew workshop!
Question! on the wing set screws, plans show they're on the top, what did you guys do? a "headless screw? did you drill a hole thru the wing tube for the screw to pass into? any pics? thanks in advance!
Also, any pics on your throttle linkage?
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to Fili)
       Post #: 46
RE: Another Ziroli DC 3 to be built... - 2/18/2013 4:00 PM
SIMCO
Score: 100
Status: offline
On Ziroli's plans, there was a wing block between the bottom of wing and wing tube out of hardwood. Drill and tap threw the block and tube. I used a socket head screw. If you are going top down, small drill the hole for the screw, CA the area and enlarge the head area so the socket head fits flush. 6/32 is more than enough. Screw is not load bearing. Just keeps the panel from sliding off. Sorry no pic.
Hide Signatures
(in reply to Fili)
       Post #: 47
RE: Another Ziroli DC 3 to be built... - 2/18/2013 5:23 PM
Fili
Score: 100
Status: offline
quote:
ORIGINAL: SIMCO
Thanks SIMCO, I would've preferred to go from the bottom, but the builder mounted the hardwood block on the top....
Click for fullsize
Click for fullsize
Phil
Hide Signatures
(in reply to SIMCO)
       Post #: 48
RE: Another Ziroli DC 3 to be built... - 3/4/2013 2:31 AM
Fili
Score: 100
Status: offline
Panel lines started on the fuse. Both engines in, almost completely done with filling.. THEN, A stink bug came out to say hello to my vacuum cleaner today.....
Phil
Hide Signatures
(in reply to Fili)
       Post #: 49
RE: Another Ziroli DC 3 to be built... - 3/4/2013 2:32 AM
Fili
Score: 100
Status: offline
is it only me having trouble uploading pics?
Phil
Hide Signatures
(in reply to Fili)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.109RCU1
