DL50 muffler question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DL50 muffler question
Page: [1]
Login
DL50 muffler question - 3/15/2012 3:20 PM
doublesixes
Score: 115
Last Login: 5/17/2013
Status: offline
I needed to replace the muffler for a DL50 engine and by mistake bought the option that has a nipple for smoke applications. The question is: should I use it as a regular muffler or should I block the hole in the nipple?
Thanks in advance.
66
Hide Signatures
       Post #: 1
RE: DL50 muffler question - 3/15/2012 3:36 PM
BarracudaHockey
Score: 280
Status: offline
I'd stick a short piece of fuel tube in it and plug it with a bolt or fuel dot, that way if you ever want access to the smoke coil you're not drilling out JB Weld.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to doublesixes)
       Post #: 2
RE: DL50 muffler question - 3/15/2012 3:56 PM
dasintex
Score: 126
Last Login: 5/20/2013
Status: offline
If the Smoke Oil Nipple is screwed in and not sodered/welded or pressed in place; just unscrew it and replace it with a small bolt.
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
       Post #: 3
RE: DL50 muffler question - 3/15/2012 4:13 PM
doublesixes
Score: 115
Status: offline
I think Ill start by filling the nipple hole with hi-temp silicone first as suggested by a pilot at the giants site. If the carb starts acting up or I see some residue on the inside of the cowl, I'll move to plan B which is to plug it with some fuel line and a dot. Thanks for the feedback!
Hide Signatures
(in reply to dasintex)
       Post #: 4
RE: DL50 muffler question - 3/15/2012 5:11 PM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
Gas turns silicone to jelly, so your silicone plug might or might not hold.
If you plug it with tubing, use neoprene rubber as regular Tygon type fuel tubing will melt from the heat.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DL50 muffler question
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
