can you upgrade the cpu on the hitec aurora    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> can you upgrade the cpu on the hitec aurora
Page: [1]
Login
can you upgrade the cpu on the hitec aurora - 3/15/2012 7:39 PM
rcpilot1982
Score: 100
Last Login: 4/4/2013
Status: offline
i just bought the hitec aurora.I was reading that most lowerr cost processors are 10 bit and this radio has 10 bits.I also read that this chip gives this radio 1024 pixels.....and installing the xps modual will give this radio 6500 pixels i think.As well as make the radio faster.So does this mean that the xps modual will upgrade the power system of this radio to11 bits like the more expensive radios
Hide Signatures
       Post #: 1
RE: can you upgrade the cpu on the hitec aurora - 3/15/2012 8:03 PM
JIMF14D
Score: 104
Last Login: 5/20/2013
Status: offline
You are talking about more pixels on the screen or better command resolution and update rate to the servos?
Jim D
Hide Signatures
(in reply to rcpilot1982)
       Post #: 2
RE: can you upgrade the cpu on the hitec aurora - 3/16/2012 2:42 AM
rcpilot1982
Score: 100
Status: offline
i read that the xps modual added more pixels and night and day response speed.Since i also read in another article that the reason this radio has 1024 p is because it is using a 10 bit ads or something witch are a low cost unit.I also read that the 11bit units are used in the higher priced JR and Futaba radios.I thought that since this XPS modual is said to add more pixels an increase the speed of the radio.Then does that mean that the modual holds the major parts of the radio.The processor can be upgraded to rank right next to the higher priced radios
Hide Signatures
(in reply to JIMF14D)
       Post #: 3
RE: can you upgrade the cpu on the hitec aurora - 3/16/2012 4:05 AM
BuschBarber
Score: 104
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: rcpilot1982
http://www.rcmodelreviews.com/aurora9issues.shtml
Pixels are the components an image on your TV or Computer screen. A typical 17" computer monitor is set to 1024x768 resolution. An HDTV is typically 1080p. The larger number refers to the number of pixels that can be displayed Horizontally across the monitor or TV.
This has nothing to do with the Resolution of your RC radio transmitter. In that case, they are referring to the movement of sticks and the corresponding movement of the servos.
It appears that the XPS Extreme Link module provides extremely higher resolution - 65536 (16bit).
http://www.xtremepowersystems.net/xtremelink.php
The new XtremeLink® module for the Hitec Aurora 9 transmitter was shown. This new plug-in module interfaces directly to the Aurora 9's CPU and does not use the PPM pulse conversion method that is common with modules. As a result, the latency over the stock Aurora 9 is nearly cut in half! Testing by top pilots prove a dramatic improvement in control response due to the huge reduction in latency and superior resolution (65536 instead vs. 1024). More information about the latency difference can be found here. The XtremeLink® telemetry data (including signal strength) is available in the Aurora 9's display. We are working on adding support for Eagletree sensors and Hitec's sensor station to go along with our own sensors. The module can be wirelessly upgraded using our XDP device. The XtremeLink® system also does not have the "dead servo" issue like the Aurora 9 system does. When the Hitec receiver loses data and a failsafe occurs, there is a period of time where the servos do not have any holding force (like no power). It is possible that the servos can sit in this dead state if the signal comes and goes. Expected release date is February 15th.
This is definition of the resolution of an RC transmitter:
http://www.rcgroups.com/forums/showthread.php?t=861521
_____________________________
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 4
RE: can you upgrade the cpu on the hitec aurora - 3/16/2012 11:23 AM
Pippin
Score: 103
Status: offline
rcpilot32,
Most radio manufactures like Futaba and Airtronics use the 32bit H8SX MPU in there radios (like SD-10G or 8FG):
http://am.renesas.com/products/mpumcu/h8sx/index.jsp
What we see as 1024 or 2048 steps is mostly the result of the potentiometers used.
Many analog servos and some digital servos are made for 8 or 9 bits anyway.
Also, you would not notice any difference in servo resolution between 1024 or 2048 steps flying your models. Higher numbers are more important for the marketing departments than for the us. I even doubt whether you can notice a difference between 1024 and 2048 steps an the ruder or ailerons.
If you want to make full use of, let's say 1024 steps, you should to get some coreless servos.
The servo seem to be more important anyway. The bottle neck is the servo motor and the pot. A 3-pole motor, cheaply made gear train and low cost servo pot will be most happy with an old 8 bit radio.
Hide Signatures
(in reply to BuschBarber)
       Post #: 5
RE: can you upgrade the cpu on the hitec aurora - 3/16/2012 5:40 PM
rcpilot1982
Score: 100
Status: offline
ok and how many bits is the cpu in the hitec aurora.Is it 10.
Hide Signatures
(in reply to Pippin)
       Post #: 6
RE: can you upgrade the cpu on the hitec aurora - 3/16/2012 6:01 PM
BuschBarber
Score: 104
Status: offline
Read the links I posted, previously. I believe it is 10.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
