RE: Bendix Special by EcomRC    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Bendix Special by EcomRC
Page: <<   < prev  1 2 [3]
Login
RE: Bendix Special by EcomRC - 11/18/2012 4:01 PM
carlosmalone
Score: 100
Last Login: 5/22/2013
Status: offline
Hi Pope,
The width of the firewall is 77mm. The length firewall to backplate is 115mm. I had to recess the carb into the firewall to obtain the proper distance so be sure to reinforce the firewall.
I used to worry about ca hinges with gasers but this doesn't seem to be an issue. The hinges on the Bendix are solid and are holding up fine. I also used micro metal gear servos to save weight with this install. Please let us know if the engine will work for you.
Carl
Hide Signatures
(in reply to the pope)
       Post #: 51
RE: Bendix Special by EcomRC - 11/18/2012 11:01 PM
the pope
Score: 101
Last Login: 5/25/2013
Status: offline
Thanks Carl I think It might be a bi tight , but maybe with a bit of creative butchering it might fit . Will have to go have another measure . From memory it was about 80mm. Maybe on a angle it could work, anyway I have a few glow engines around that would do the job . Just had another measure and its pretty tight . Does the fuz have triangle stock on the firewall and if so is your measurement including the triangle stock or not ? Gheers the pope
Hide Signatures
(in reply to carlosmalone)
       Post #: 52
RE: Bendix Special by EcomRC - 11/19/2012 1:05 PM
carlosmalone
Score: 100
Status: offline
My measurements did not include the triangle stock.
Hide Signatures
       Post #: 53
RE: Bendix Special by EcomRC - 11/19/2012 2:21 PM
the pope
Score: 101
Status: offline
O.K. thanks Carl. I might have to get my mitts on one in person and see if it can be made to work . Cheers the pope
Hide Signatures
       Post #: 54
RE: Bendix Special by EcomRC - 1/14/2013 3:50 PM
Reverend
Score: 100
Last Login: 5/26/2013
Status: offline
Hey guys,
thanks for all the input, expecially to starmer.
One thing I changed, due to the fact that I am flying off grass, was the UC. I used 55mm wheels and drilled a surplus hole in the UC. The pants are now 10mm higher um and held by one M3 metal screw and a M2 Plastic one against turning. Should the wheel pants catch somewhere the plastic screws will give way and I hope to minimize damage.
Rev
Click to see fullsize image.
Click for fullsize
_____________________________
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
       Post #: 55
RE: Bendix Special by EcomRC - 1/14/2013 11:31 PM
Dowmer
Score: 100
Last Login: 5/14/2013
Status: offline
Rev,
Nice Mod.  I was considering doing the same but I never got around to it.  I did damage the UC spats a little when I hit a pothole in the runway.  I guess I could have avoided it by doing what you did.  Nice job.
Dowmer aka. Starmer
Flying:
P-40E 80"
Hide Signatures
(in reply to Reverend)
       Post #: 56
RE: Bendix Special by EcomRC - 1/17/2013 8:58 AM
Reverend
Score: 100
Status: offline
Thanks, but it still has to prove itself.
Pilotwise I was first looking at the slimline pilot from my stearman but he is just a tick too tall. I then checked Petes Pilots and had to get myself another cedric. He is perfect
Rev
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Dowmer)
       Post #: 57
RE: Bendix Special by EcomRC - 1/17/2013 9:01 AM
Dowmer
Score: 100
Status: offline
Nice, I gotta get one
J
Flying:
P-40E 80"
Hide Signatures
       Post #: 58
RE: Bendix Special by EcomRC - 1/17/2013 11:19 PM
Reverend
Score: 100
Status: offline
Something I really hate are holes im my cowls. I rang up my buddy Gerhard and he came up with this.
Me likey
Click for fullsize
Hide Signatures
       Post #: 59
RE: Bendix Special by EcomRC - 2/10/2013 7:21 PM
Reverend
Score: 100
Status: offline
Maidened today. -10°C but crystal clear. Used half the throws from the manual (40mm+/- seems a LOT!) and the CG at 82mm. Flew brilliantly from the first second. Thought I would definitely not do more than three flights in the cold, ended up with 56 minutes flying time and about 30+ touch and go's
Can only recommend this little plane.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 60
RE: Bendix Special by EcomRC - 2/10/2013 11:27 PM
Texastbird
Score: 150
Status: offline
It looks like a natural on the skis! Sweet.
Did the muffler set up do ok?
Hide Signatures
       Post #: 61
RE: Bendix Special by EcomRC - 2/11/2013 1:55 AM
Dowmer
Score: 100
Status: offline
Reverend,
Love the skis.!!  I agree with you.  This plane is one of my best pleasurable fliers.  It's my "go-to" plane when I just want to relax and have fun.  I noticed you mod'd the tail gear.  Where is it from?  I used Sullivan tail geat for mine.
Jason
Flying:
P-40E 80"
Hide Signatures
(in reply to Texastbird)
       Post #: 62
RE: Bendix Special by EcomRC - 2/11/2013 7:54 AM
Reverend
Score: 100
Status: offline
Muffler Setup working very well and I am glad I only have minimum cutouts in the cowl.
I really dont like those tail gear setups where the gear is directly glued to the rudder and the servo feels every "hit" directly.
I used this: click me softly
Rev
Hide Signatures
       Post #: 63
RE: Bendix Special by EcomRC - 2/11/2013 8:53 AM
Dowmer
Score: 100
Status: offline
Thanks Rev,
I looks just like the Dubro that I've used in the past.  It's a good tailwheel.
J
Flying:
P-40E 80"
Hide Signatures
       Post #: 64
RE: Bendix Special by EcomRC - 3/2/2013 1:50 AM
ckreef
Score: 105
Last Login: 5/17/2013
Status: offline
Since Bendix Specials are out of stock World Wide and have been for some time I think I hit pay dirt today
I went to the Perry GA rc swap meet. There was a RC Store that had brought a bunch of planes to sell. They had a Bendix Special they had partially built (just enough to hang it in their store).  They brought it to the show and I got it for $100. All parts are accounted for except the push rods. They didn't do a bad job with the partial build. I have a TT Pro .46 ready  to install in it. I just need to get some servos and push rods.
Well I tried to post a pic of it but RCU is not cooperating
Hide Signatures
       Post #: 65
RE: Bendix Special by EcomRC - 3/2/2013 5:57 AM
ckreef
Score: 105
Status: offline
Did a quick inventory. I have the eleator, rudder, and throttle servos. I have in my stash all the pushrods I need. At this point I only need to purchase  Aileron servos and I think I'm good to go. Going back to the swap meet tomorrow for some low priced servos.
Hide Signatures
(in reply to ckreef)
       Post #: 66
RE: Bendix Special by EcomRC - 5/13/2013 2:35 AM
ckreef
Score: 105
Status: offline
Finally got her going and ready to maiden within the next few days.
Tried to post a picture once again and no such luck
Hide Signatures
       Post #: 67
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
