IFLY-4 Quadcopter - Cheap Aerial Imaging Platform    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Product Announcements & Manufacturer News >> IFLY-4 Quadcopter - Cheap Aerial Imaging Platform
Page: [1]
Login
IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 3/17/2012 6:53 AM
idea-fly
Score: 100
Last Login: 12/13/2012
Status: offline
Hi , everybody ,this is Joe ,I have no idea if I can post one thread here ,if can’t ,please let me know ASAP, and thanks in advance .If can, I hope more people who are interested in the quadcopter can see the thread. And most important is: I hope I can make some friends here , if you have any questions ,just let me know ,or PM me, thanks.
 FC
develop by ourselves, I2C escs; cortex M3 processor; supports acro/autolevel modes.
1. Centralized design It concludes the sensor such as Controller Chip .gyro and accelerate and so on. besides contains all the component that FC needs ,not only easy to setup but save a lot of space.
2. Advanced arithmetic advanced Integrated navigation algorithm and control algolithm , improve the Mobility and have a great flying.
3. Interior Low voltage alarm buzzer will start to alarm when the voltage is lower than 10.9 vl that means you don’t need to set any voltage alarm outside.
4. RC Support most of the RC that use the PWM output, adopt the FUTABA standard.
5. Two axis title autostabilization Can compatible with most two axis title ,automatic adjustment the camera mount and camera lens base on the attitude of the flight, make it more stabilize to shoot, Meet the needs of the Aerial lovers . Besides, it can be upgraded and expand Firmware can upgrade online easily , and we reserved the connector of the firmware expand.
ESC
small enough to set in the arm
1. current output persistent current 10Ashort time current 15A(less than 10 second)
2. mains input 3 quarter aluminum battery input
3. Connector style High speed I2C digital connector (100khz-400khz)
4. Safer Motor Shaft Lock Protection When the motor seize up or get stuck it will automatic stop the motor output and wait for seconds to reboot, so can Effectively Prevent the burn down of the ESC and motor then effectively protect your safe.
5. No noise of drive Adopt the high speed output, without the buzzing that the traditional Governor makes when it drive. Only can hear the sound of the propellerthat you can pay your attention to your flight ,make you feel so happy to fly.
IF2212 brushless outer rotor motor
Weight of motor45g/pcs, especially design for IFLY-4 quadcopter , IF2212 series motor is brushless outer rotor motor that adopt the newest magnet materials ,with more efficiency and bigger load voltage ,and The most exquisite production process ,top quality ,with best performance that you can ever find in the market. Besides, the special one oar clip institutions reduce the distance between prop and the motor, and then avoid the resonate cause by motor rotation and high speed acceleration and deceleration .  work with the precision propeller can make the flying more efficiency.
IFLY-CT6 SINGLE AXIS CAMERA MOUNT
IFLY-CT6 single axis camera mount adopt carbon fiber as material, work with precision bearing makes it less light, more accurate and more stable, is great for the AP/AV hobby to learn and take the sample, fix for most Card Digital Camera that sell on the market, also can load 9G-12G analog and digital servo ,with high compatibility.
1. High frequency suspension components make the photo shoot more stable and clear.
2. Mechanical camera shutter structure (adjust the camera shutter base on your Camera)
3. Pitchscale of the camera mount can reach ±50 degree (adjust it to meet your need)
4. Camera mount compatible 9G-12G (analog and digital servo) landing gear
Battery
Dimension: 107mmx34mmx22mm 11.1v 2200MAH 25C 3S1P resistance:3.1-3 weight: 180g charging time: about 1 hour f lying time:10 minutes or so.
< Message edited by idea-fly -- 4/24/2012 9:47 AM >
Hide Signatures
       Post #: 1
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 3/17/2012 6:55 AM
idea-fly
Score: 100
Status: offline
 POST SOMEWHEREELSE BEFORE
Hide Signatures
(in reply to idea-fly)
       Post #: 2
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 3/17/2012 10:33 PM
outdoorhunting
Score: 351
Last Login: 5/18/2013
Status: offline
Very interesting !! Need more info. Webb address ?
_____________________________
Too much horsepower- Just right !!!
Hide Signatures
       Post #: 3
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 3/18/2012 4:03 AM
idea-fly
Score: 100
Status: offline
WWW.idea-fly.com if can't open it ,please add my skype:joe520happy  or  msn:qwj520happy@hotmail.com,thanks
Hide Signatures
(in reply to outdoorhunting)
       Post #: 4
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 4/16/2012 8:57 AM
idea-fly
Score: 100
Status: offline
quote:
ORIGINAL: outdoorhunting
www.idea-fly.com ,thanks
Hide Signatures
       Post #: 5
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 4/18/2012 6:58 AM
idea-fly
Score: 100
Status: offline
seems no one are interested in the quad?
Hide Signatures
       Post #: 6
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 5/29/2012 3:41 AM
idea-fly
Score: 100
Status: offline
I wonder why I can't edit my own thread? just want to add some pictures and videos ,somebody tell me? thanks
Hide Signatures
       Post #: 7
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 5/30/2012 12:47 AM
outdoorhunting
Score: 351
Status: offline
I'm checking back for more info. Need a price & availability.
Hide Signatures
       Post #: 8
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 6/27/2012 9:41 AM
idea-fly
Score: 100
Status: offline
 I want to edit it (add the video),but I can't  edit it ,can you tell me why? if you really need to try it ,I can give you one at a good price ,and if you can introduce distributors to me ,(the quantities reach 20 pcs ) I will give you one free to test,or next time our new product comes out ,I will offer it to test ,free or very low price. Thanks.
Hide Signatures
       Post #: 9
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 7/3/2012 1:45 AM
mr_matt
Score: 116
Last Login: 5/19/2013
Status: offline
Did you find any distribution yet?
Matt
Hide Signatures
       Post #: 10
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 7/3/2012 4:23 AM
idea-fly
Score: 100
Status: offline
Hi Matt
we have two shops sell our quad in USA now ,They are skyhunterbobby ,helihobby, you can buy from them or if you are distributor ,you can buy from us directly,thanks.
Hide Signatures
(in reply to mr_matt)
       Post #: 11
RE: IFLY-4 Quadcopter - Cheap Aerial Imaging Platform - 1/30/2013 12:07 AM
frenchstan
Score: 125
Last Login: 1/30/2013
Status: offline
I've been trying to find replacement IF2212 motors for IDEA-FLY's IFLY-4 quadcopter, since Hobby King is out of stock again. SkyHunterHobby.com is out of stock, but HeliHobby.com does have them in-stock and has shipped me one. Surprisingly, IDEA-FLY itself doesn't appear to sell them direct via their web site. Strange.
PLEASE NOTE: Many companies list the IF2212 motor as having a 3mm shaft diameter. THE SHAFT IS NOT 3MM, IT IS 6MM!
If anyone knows about any other source for the IF2212 motor, let us all know.
Finally, somewhere I saw an IFLY-4 with orange arms, but of course I forget to note the site. Anyone know the outfit selling the IFLY-4 with two orange arms? (Yes, I know I could paint the black ones orange - but I want two spares, so why not get 'em that way?)
PZ:T28,Cub,210,P51,F27,ABX,ABC,CX,CP,B400! GWS: F4U,EStart, P51,SStick,F
FrbrdII. CAP 580, FoMoCo,Cox WBs, Ascender, Fo
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
