first airboat. help?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> first airboat. help?
Page: [1]
Login
first airboat. help? - 3/17/2012 7:02 AM
i luv duct tape
Score: 100
Last Login: 10/18/2012
Status: offline
so i want to build a small airboat with balsa and losi micro crawler electronics and i have 2 questions:
#1, do you want the motor to be speedy or torquey? i would think speedy so it lets of more air giving it more power?
#2, where could i get a small enough (cheap) prop?
thanks, Jake
_____________________________
young only once kid forever
to some its a hobby, to me its a way of life
Hide Signatures
       Post #: 1
RE: first airboat. help? - 3/17/2012 3:03 PM
1QwkSport2.5r
Score: 155
Last Login: 5/22/2013
Status: online
quote:
ORIGINAL: i luv duct tape
thanks, Jake
You want the motor to be capable of the middle zone between speedy and torquey. If you have a speedy motor (high Kv) you will need to use smaller diameter/lower pitch to get it to turn up in its "powerband" whereas a torquey (lower Kv) will be able to turn larger diameter/pitch props at a lower rpm.
Small props can be had for electric park flyers and the like. The prop size/pitch is dependant on what the motor is capable of. You may need to experiment with different props to find one that the motor will spin well enough, and provide enough thrust to move the craft you're going to build. If you build the hull too big and heavy, your motor may not have the oomph to get it moving well.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to i luv duct tape)
       Post #: 2
RE: first airboat. help? - 3/17/2012 7:22 PM
Mikeup
Score: 105
Last Login: 5/13/2013
Status: offline
Listen to Mr. Minnesota! He's good (real good ).He's dead on. I have a wooden 21" x 13" and put a 700 motor ( brushed ) with a 8"x 4 pitch on 2S prop  as a puller and fly. Watch the prop, i've been cut once and that was enough. Put a push-pull switch which cut off juice to rx for safety. Coat inside with thinned epoxy to waterproof.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 3
RE: first airboat. help? - 3/17/2012 8:52 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: Mikeup
Listen to Mr. Minnesota! He's good (real good ).He's dead on. I have a wooden 21'' x 13'' and put a 700 motor ( brushed ) with a 8''x 4 pitch on 2S prop  as a puller and fly. Watch the prop, i've been cut once and that was enough. Put a push-pull switch which cut off juice to rx for safety. Coat inside with thinned epoxy to waterproof.
I'll go one further on the epoxy bit - use finishing resin. Its already thinner in viscosity and is fuel proof. I use this on the outside of my projects by itself or with fiberglass cloth. I use Pacer Z-Poxy PT40 myself, but West Systems is very good too (but more $$).
One other thing to keep in mind - Know the limits of your ESC! If you try to push it farther than it should be pushed, you may end up with a burnt up ESC or a fire. If using LiPo, be especially careful. Use the right electronics for the job.
Hide Signatures
(in reply to Mikeup)
       Post #: 4
RE: first airboat. help? - 3/17/2012 9:16 PM
Mikeup
Score: 105
Status: offline
I forgot 1 thing that Harold of Cajun airboat told me. Now a prop like 8 x 4 will move more air than a prop like 8 x 6. Reason is a 8 x 6 will have a small air cone which is more concentrated. This differs iin boats where a small mono will use a 632 prop which has a small cone and be blazing fast. I have many 22" monos and do move. I use a 90 amp on my airboat above.
Hide Signatures
       Post #: 5
RE: first airboat. help? - 3/17/2012 9:28 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: Mikeup
I forgot 1 thing that Harold of Cajun airboat told me. Now a prop like 8 x 4 will move more air than a prop like 8 x 6. Reason is a 8 x 6 will have a small air cone which is more concentrated. This differs iin boats where a small mono will use a 632 prop which has a small cone and be blazing fast. I have many 22'' monos and do move. I use a 90 amp on my airboat above.
Low pitch props will turn faster but move the boat slower (think diesel tractor pulling a tree stump). High pitch props will turn slower but move the boat faster (think top fuel dragster).
In a perfect medium, a given craft will move forward however many inches of pitch the prop as per revolution. 4" pitch = 4" forward per revolution for example.
Good luck to the OP. Airboats are fun to build and even more fun to run I think. Nowhere near as fast (generally) as a wet-propped boat but still fun IMO.
woot!
Hide Signatures
       Post #: 6
RE: first airboat. help? - 3/18/2012 11:23 AM
i luv duct tape
Score: 100
Status: offline
thanks for all the input guys but, i may have left out a major detail: i already built the hull, and its only 6"x3". so i need a tiny prop and im using everything from a losi micro crawler. sorry about the misunderstanding guys. i already waterproofed the electronics with plasti-dip and the hull with hot glue in all of the cracks, inside and out, and im probably gonna paint it with a couple thick coats of black. this thing wont see much water, mostly around my house and possibly some mud or puddles. once again thanks guys!
-Jake
Hide Signatures
       Post #: 7
RE: first airboat. help? - 3/18/2012 1:53 PM
DJLaPalme
Score: 110
Status: offline
For a prop check the mini helicopters for a tail rotor blade. That may work for you. Your LHS(local hobby shop) may have them. Dennis
Affiliated with Mudmasher Airboats.
Hide Signatures
       Post #: 8
RE: first airboat. help? - 3/18/2012 4:48 PM
1QwkSport2.5r
Score: 155
Status: online
thanks for all the input guys but, i may have left out a major detail: i already built the hull, and its only 6''x3''. so i need a tiny prop and im using everything from a losi micro crawler. sorry about the misunderstanding guys. i already waterproofed the electronics with plasti-dip and the hull with hot glue in all of the cracks, inside and out, and im probably gonna paint it with a couple thick coats of black. this thing wont see much water, mostly around my house and possibly some mud or puddles. once again thanks guys!
-Jake
Do you think you could snap a photo of your rig and post it?
Hide Signatures
       Post #: 9
RE: first airboat. help? - 3/18/2012 6:18 PM
i luv duct tape
Score: 100
Status: offline
Hide Signatures
       Post #: 10
RE: first airboat. help? - 3/18/2012 6:59 PM
1QwkSport2.5r
Score: 155
Status: online
It isnt very often I can say this, but that looks pretty cute.. LOL.
Hide Signatures
       Post #: 11
RE: first airboat. help? - 3/19/2012 5:48 AM
i luv duct tape
Score: 100
Status: offline
lol ya, it is.... i guess. ive been into micros for about a year and a half or so, so its about the right size for me. i got the steering figured out and got all the electronics in and tried a homemade prop and i could only feel the air about an inch from it. maybe dead battery or the ps2 controller motor isnt fast enough. im sure i can find something better around here somewhere........
Hide Signatures
       Post #: 12
RE: first airboat. help? - 3/19/2012 9:42 AM
Altered1
Score: 106
Last Login: 5/21/2013
Status: offline
I made one up from a few blocks of balsa and the internals from a micro heli....  sadly I couldn't work out the twin thrust the 2 rotor motors gave me....  The tail rotor blades from a micro heli would work fine for this I think.
Hide Signatures
       Post #: 13
RE: first airboat. help? - 3/19/2012 3:57 PM
dadkins
Score: 104
Status: offline
I used the guts from a micro copter and had some fun with this little sucker.
I used the tail rotor props for...props.
made my own prop here for the cessna
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Altered1)
       Post #: 14
RE: first airboat. help? - 3/21/2012 1:30 AM
rcuname234
Score: 100
Last Login: 9/3/2012
Status: offline
Cool!
Hide Signatures
(in reply to dadkins)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
