KINGTECH K80F 'GLOW BAD..'    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> KINGTECH K80F 'GLOW BAD..'
Page: [1]
Login
KINGTECH K80F 'GLOW BAD..' - 3/17/2012 6:11 PM
POWER JET
Score: 100
Last Login: 5/21/2013
Status: offline
 Hi guys,
i have a Kingtech k80F kerostart and today when i landed my plane and when i tried to start up again for the second flight i had a message on GSU says..
'GLOW BAD'
and the turbine doesn't start up.
The turbine is brand new with 20 minutes of run time..
Does anybody knows what this means?
I hope that is not what i'm afraid of...malfunction on the kero plug?!!
Thank in advance for any replies guys...
_____________________________
No excuses...!
Hide Signatures
       Post #: 1
RE: KINGTECH K80F 'GLOW BAD..' - 3/17/2012 7:49 PM
racer8297
Score: 100
Status: offline
Just guessing, but could it be that the ECU battery needs charging? Or a bad connection to the igniter?
Jim
Hide Signatures
(in reply to POWER JET)
       Post #: 2
RE: KINGTECH K80F 'GLOW BAD..' - 3/17/2012 8:43 PM
MNModels
Score: 100
Last Login: 5/20/2013
Status: offline
Hi,
First check ECU amp circuit. In kero mode set trim max and throttle max.. The starter motor should engage. See screen 2 for reading for amps.
If this ok, then you have a bad connection on the Kero copper wire. I have found that the varnish on the wire was not removed when soldered to terminal. Take off cover ad check the wire for good electrical continuity...
Regards
Morne
MNModels
Skymaster & Xtremejets
Hide Signatures
       Post #: 3
RE: KINGTECH K80F 'GLOW BAD..' - 3/17/2012 9:19 PM
Kenrico
Score: 100
Status: offline
check the harness to where it connects with the Turbine (the green plug). If the connection is loose then the starter wouldn't spin either. Happen to me once and i freaked out until i realized the starter was dead also and checked the plugs and found it was halfway out.
Hide Signatures
(in reply to MNModels)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
