RE: ECOMRC TigerMoth 1/4 Scale    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/4 & 1/3 scale built lasers types gas engine - ARF
Seller:  joebiplane
Details:   $500.00   |  6/7/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: ECOMRC TigerMoth 1/4 Scale
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: ECOMRC TigerMoth 1/4 Scale - 11/28/2012 7:33 PM
Dbp7966
Score: 100
Last Login: 6/17/2013
Status: offline
Seems about right, mine flys nice on 18Lbs.
I also have changed the differential on the Ailerons less on the down and it turns alot nicer now.
DB
Hide Signatures
(in reply to 600Bob)
       Post #: 151
RE: ECOMRC TigerMoth 1/4 Scale - 1/2/2013 3:04 AM
600Bob
Score: 100
Status: offline
Well it dried out enough to get a second test flight of the TM with the new CG at 7 3/8 inches.  After a few min. of flight it had an engine failure, my test pilot set it down in the cow pasture and it flipped over, only the prop was broken.  I am 90% certain that the fuel fill line came off the stopper plug that is a part of the switch box.
Also after the flight a friend of mine picked something up off the ground where I had started the plane.  It was 12oz. of lead that had fallen out of the front of the cowl, the epoxy didn't hold!  So in fact the CG for this flight at about 7 3/4 or even 8 in., right about where Hangar 9 says to balance their TM.  My pilot said it flew fine, still needed lots of down elevator while inverted.  Elevators have a slight amount of down trim for normal flight.
Didn't have any problem with it wanting to nose over during taxi in the grass either with 4in. tires.  The manuals CG is waaaaaaay too far forward.
Video to follow after it uploads.
Hide Signatures
(in reply to Dbp7966)
       Post #: 152
RE: ECOMRC TigerMoth 1/4 Scale - 1/2/2013 6:30 AM
jagfab
Score: 100
Last Login: 6/19/2013
Status: offline
thanks for the updates 600 bob and congrats on the flights
very reassuring since my cg is at about 7.5"
nice way to start the new year !!
Hide Signatures
       Post #: 153
RE: ECOMRC TigerMoth 1/4 Scale - 1/2/2013 4:37 PM
600Bob
Score: 100
Status: offline
Here is the video of the second flight, not knowing that 12oz of lead had fallen out of the front of the cowl.  The CG for this flight is approximately 8 inches from the leading edge of the fake fuel tank.
Minor rant.  Who thought it would be a good idea to remove eye level  viewfinders from video cameras?  I missed the actual landing when the engine failed but caught just a glimpse of it on it's back.
https://www.youtube.com/watch?v=dAuv6g9NiLY
Hide Signatures
(in reply to jagfab)
       Post #: 154
RE: ECOMRC TigerMoth 1/4 Scale - 1/5/2013 3:04 PM
flyalot
Score: 100
Last Login: 6/18/2013
Status: offline
Hi 600 Bob Thanks for the video. Will put my Moth back together and re balance. its warm today 29 F sunny and windy, blowing snow.
Nice break from a week of single number temperatures.
Have about a foot of the white stuff on the ground. The younger members of my club do fly off snow and frozen lakes and enjoy it.
Joe
Hide Signatures
       Post #: 155
RE: ECOMRC TigerMoth 1/4 Scale - 1/5/2013 7:50 PM
600Bob
Score: 100
Status: offline
My test pilot said it flew well and still didn't feel nose heavy, he thought it is my easiest plane to fly, he probably forgot how easy my Lazy Ace or 1/4 Cub are to fly     It will require the elev.. to have some down trim though.  Not surprising since the Hangar 9 TM flys with down trim as well, they designed it to act like a flying stab.
This is my test pilot flying his 40% Extra 260.  I had trouble keeping up with him at first.  My first attempt videoing with a new camera and sun glare on the view screen.
https://www.youtube.com/watch?v=rlWvNvo9Uso
Hide Signatures
(in reply to flyalot)
       Post #: 156
RE: ECOMRC TigerMoth 1/4 Scale - 6/13/2013 1:10 PM
ozzieflyer
Score: 100
Status: offline
quote:
ORIGINAL: Dbp7966
Hi Carl,
Just for you me old mate.
Install of the DLE 30.  I beefed up the inside of the bulk head( for my own peace of mind) with  10 mm ply plate.
With the stand offs she fits just right as indicated in the book from bulk head to prop driver.
I purchased a rap around and it sits very nicely.  Will run a 18 x 8 prop.
DB
Hi
I have just purchased one of these, very happy with the kit,
Was wondering about the distance for the engine from the Prop Hub to the Firewall. The manual I have is a little unclear, is it 160 mm ?
Thanks from 'DownUnder
Hide Signatures
       Post #: 157
RE: ECOMRC TigerMoth 1/4 Scale - 6/13/2013 5:10 PM
600Bob
Score: 100
Status: offline
I didn't measure the distance in mine,  The standoffs for the DLE 35RA worked out of the box.
Hide Signatures
(in reply to ozzieflyer)
       Post #: 158
RE: ECOMRC TigerMoth 1/4 Scale - 6/17/2013 4:10 PM
Dbp7966
Score: 100
Status: offline
Hi There,
Same here, my stand offs from my DLE 30 was spot on, what motor are you entending to use?
I can take my prop and cowl off if you need to know.
Cheers
DB
From on top
Hide Signatures
       Post #: 159
RE: ECOMRC TigerMoth 1/4 Scale - 6/19/2013 1:24 PM
ozzieflyer
Score: 100
Status: offline
quote:
ORIGINAL: Dbp7966
Hi There,
Cheers
DB
From on top
Hi DB,
that would be great.
I've just purchased an OS GF-40 to put in mine, so am just working out the stand offs I will need.
Hide Signatures
       Post #: 160
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
