100 OCTANE aviation fuel in gasser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> 100 OCTANE aviation fuel in gasser
Page: [1] 2 3 4 5 6 7   next >   >>
Login
100 OCTANE aviation fuel in gasser - 3/18/2012 3:49 PM
comanche260c
Score: 107
Last Login: 3/17/2013
Status: offline
I have a  Quadra 75 and a zenoha 38 gasser and wondering if i can and should use aviation gas 100 octane in them..  I have a small plane ,and have access to the  fuel.Will it harm or help the engine.No methonol in the aviation gas
Hide Signatures
       Post #: 1
RE: 100 OCTANE aviation fuel in gasser - 3/18/2012 3:54 PM
VF84sluggo
Score: 345
Last Login: 6/20/2013
Status: offline
My brother has been running 100LL in his weed eater, lawn mower, and electric generator for several years with no problems. Plus, AVGAS is muuuch less prone to going stale and gumming up the works than is MOGAS.
Some state concerns over the toxicity of the lead, but you probably suck in more toxicity running the gauntlet of smokers clustered outside the entrance at your office building or local WalMart than you would with the amount of AVGAS that would be encountered in small engine use.
< Message edited by VF84sluggo -- 3/19/2012 6:25 PM >
Hide Signatures
(in reply to comanche260c)
       Post #: 2
RE: 100 OCTANE aviation fuel in gasser - 3/18/2012 8:03 PM
Red B.
Score: 113
Last Login: 5/30/2013
Status: offline
AVGAS 100(L) contains tetraethyllead which is a highly toxic substance. I see no real reason to use AVGAS in model aircraft applications.
Here in Europe we have been running our gas engines on unleaded fuel for ages with no problems.
It is strange that so much is written about gasoline problems in U.S. forums. This is in stark contrast to the situation over here, where this kind of discussions died out many years ago.
_____________________________
/Red B.
Hide Signatures
(in reply to VF84sluggo)
       Post #: 3
RE: 100 OCTANE aviation fuel in gasser - 3/18/2012 8:53 PM
STUKA BARRY
Score: 130
Status: offline
quote:
ORIGINAL: Red B.
Some modelers are alergic to gasoline smell and AV gas is an alternative along with white gas (Coleman fuel). Performance wise, personally, I dont think its worth the extra $2-3.00 per gallon.
KEEP UM FLYIN
Hide Signatures
(in reply to Red B.)
       Post #: 4
RE: 100 OCTANE aviation fuel in gasser - 3/18/2012 9:57 PM
AJsToyz
Score: 304
Last Login: 6/19/2013
Status: offline
Store my planes in the basement and with out gas there's no smell. well worth the 2.00 bucks a gallon extra.
www.Deathbychina.com
Hide Signatures
(in reply to STUKA BARRY)
       Post #: 5
RE: 100 OCTANE aviation fuel in gasser - 3/18/2012 11:30 PM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
It depends totally on what oil you use, which Radio brand you use and what brand of vehicle you drive to take the planes to the field.
Fact is, there is no performance benefit in using Avgas. On some enigne brands, there is actually a performance loss (put an engine on a proper dyno as I have done and you will see it - XXX RPM on YYY prop doesn't cut it). There are also no "Long term reliabillity benefits of Avgas over Mogas for our engines. (Honestly, what you are running there isn't real high tech or high performance - just live with that fact).
If you don't want the smell of Mogas - Sure you can run avgas but it isn't worth going out of your way to get it (I know the OP already has it available but others don't).
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
(in reply to AJsToyz)
       Post #: 6
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 12:09 AM
AJsToyz
Score: 304
Status: offline
Steve,
I'm pretty lucky, no matter what way I take home I pass an airport.
Hide Signatures
(in reply to aussiesteve)
       Post #: 7
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 12:39 AM
comanche260c
Score: 107
Status: offline
IM  ASKING THIS QUESTION BECOUSE IM THINKING AVGAS DOESNT HAVE THE ETHONOL IN IT THERE FOR WONT GUM UP THE CARB AS EASY. AV GAS  DRIES RIGHT UP IF YOU GET IT ON HANDS.I HAVE A FULL SCALE PLANE SO ITS AT MY FINGER TIPS
Hide Signatures
       Post #: 8
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 1:14 AM
aussiesteve
Score: 216
Status: offline
quote:
ORIGINAL: AJsToyz
Steve,
I'm even luckier than that - I have a full sized runway on my property and 2 Avgas powered planes in the hanger there (EA300 and PA32RT). Along with Drums of 100LL to fill them with
I also have the benefit of an actual Engine brake dyno at my disposal for these engines.
I don't run Avgas in my model planes because Premium pump gas is a much better option for those (Including my BME's which are quite high compression and quite high performance). Premium pump gas gives a better power curve in them.
The whole "Ethanol" argument is B/S nowadays. It applied a LONG time ago for a very short time. Modern Walbros do not have an issue with it.
However - IF the fuel smell is an issue - Avgas does smell nicer I guess. But you can also go to your local Candle making supply store and buy Candle scents to put in your fuel
Hey - it is a hobby after all, do whatever turns your crank I say
Hide Signatures
       Post #: 9
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 1:29 AM
Pelle Gris
Score: 100
Status: offline
Isn´t the AVGAS way too expensive to consider running in our gassers? Here in Denmark the price of AVGAS is at least 30-40% higher than that of regular MOGAS.
MOGAS: about 9$ a gallon.
AVGAS: about 12,50$ a gallon.
The only thing more expensive than AVGAS is Aspen pre-mixed gas, at 20,50 to 23,50$ a gallon. :-)
Thinking about these prices makes me glad I have a car with a tiny engine.....
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 10
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 2:37 AM
mbinkley
Score: 105
Last Login: 6/2/2013
Status: offline
Here is web site to help find ethanol free gas. Pure-gas.org
Hope it helps
Hide Signatures
(in reply to Pelle Gris)
       Post #: 11
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:26 AM  1 votes
tkg
Score: 657
Status: offline
AV gas.. runs hotter and makes less power. Doesn't smell as bad. Your choice
TKG
Too much power is just about right.
Hide Signatures
(in reply to mbinkley)
       Post #: 12
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:35 AM
comanche260c
Score: 107
Status: offline
you say it runs hotter  but will it idle diffrent? I started  my new used  quadra 75cc I got last week for first time  with av gas and  it seems it needs adjustments  didnt quite  idle smooth and quit  on idle .. is that due to the av gass???????????
Hide Signatures
(in reply to tkg)
       Post #: 13
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:44 AM
captinjohn
Score: 247
Status: offline
My choice is recreational fuel like for marine use.  No alcohol in it....25-40cents more and well worth it. Use google to find where they sell it. Darn good in motorcycles too.  You lose power with even 10% methanol acohol in you regular gas.  Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 14
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:50 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: comanche260c
NO....ever type of engine I used AV gas in ,ran better.  Do not let others BS you about that. If they had trouble it was the brand or mix of AV gas they used....or where they got it.   Capt,n
Hide Signatures
       Post #: 15
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 4:44 AM
OliverJacob
Score: 110
Status: offline
Is there any known problem using Avgas? I'd be happy to spend $2 more for the Gallon and get rid of the gas smell.
Hide Signatures
(in reply to captinjohn)
       Post #: 16
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 4:47 AM
brenthampton79
Score: 105
Last Login: 6/12/2013
Status: offline
I'm with steve on the 100ll argument, I would run what the manufacturer says to. I ran 100ll in a 2 stroke atv years ago due to the fact we have a 2000 gallon tank full of it, but soon learned it ruined the engine either due to the lead or something else. However it didn't have more performance due to the increased octane. Octane is an antiknock level not an energy boost. If you have a high compression engine then you need the higher octane but you get more performance due to the compression. I wouldn't run the 100ll in the engine unless it requires a leaded fuel which I'm going to guess it does not require lead since most modern engines require unleaded, there's a reason the engineers say this I figure in the manual.
N802KC AT-802A Work
N66EC Pitts S1-S Fun!!
Hide Signatures
       Post #: 17
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 4:48 AM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
Your problem is the carb diapharagms and settings, not the fuel...
RC Ignition
Hide Signatures
       Post #: 18
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 5:15 AM
comanche260c
Score: 107
Status: offline
ok  so who really knows the answer   will av gas hurt my motor in my quadra75 if I use av gas or not..is there anyone out here that has used av gas in there gassers for years  and it still runs good????  lets go by someone that put it thru the real test
Hide Signatures
(in reply to Antique)
       Post #: 19
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 7:02 AM
AJRCUSTOMCRAFTEDRC
Score: 100
Last Login: 6/18/2013
Status: offline
wow i just don't get it ..
< Message edited by AJRCUSTOMCRAFTEDRC -- 3/19/2012 5:39 PM >
Hide Signatures
       Post #: 20
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 10:48 AM
AJsToyz
Score: 304
Status: offline
That's it, it's a hobby!
As far as the running part goes, I don't really care. I'm not about to put avgass in my lawn mower, but I don't store the lawn mower under my bedroom.
And some of US? Actually have there own some what home made engines!
Andy
Hide Signatures
       Post #: 21
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 1:03 PM
Mr_Grump
Score: 105
Status: offline
I've been using 100LL and a good synthetic oil for years at 40:1 and I run it in everything. No oder, evaporates quickly and with a good synthetic oil, you don't need a preservitive for long term storage. I use it in everything from an old G23 running hot in a gas heli to a 70cc twin. I also use the same mix in my weed eaters. I leave fuel in the weedeaters when the seasons done for winter then top them off and restart them in spring.
Is there a problem in store for me? Don't know but so far, I've very satisfied. I also know top IMAC competitor who uses it and he swears by it.
So... read all these posts and make your own decision. I'm happy.
Mr G
Hide Signatures
       Post #: 22
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 2:54 PM
WRK
Score: 105
Status: offline
AVGAS = more cost, a bit less power and less smell, more toxic.
Hide Signatures
(in reply to Mr_Grump)
       Post #: 23
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:22 PM
Firepower R/C
Score: 110
Last Login: 6/15/2013
Status: offline
I am not a fuel expert, but if you properly configure your engine to run on 100LL, i.e. raise the compression slightly, adjust the ignition curve and carb settings, it WILL produce more power. Like has been said already, 100LL allows higher compression without damage, and higher compression basically means more power. Plain and simple. That is why aviation piston engines use it... max power equals max safety & efficiency. The Aviation community has been struggling for years to come up with a substitute for 100LL, and would have gone to MOGAS long ago if there was any benefit. You can split hairs here, but this is just a generalization.
If you don't make changes to your powerplant, it is basically a waste... but I still use it sometimes because it is available to me.
Firepower R/C
Saving un-loved R/C airplanes around the world
Hide Signatures
(in reply to WRK)
       Post #: 24
RE: 100 OCTANE aviation fuel in gasser - 3/19/2012 3:41 PM
Zeeb
Score: 111
Status: offline
Hmm.....
Typing in all caps is considered yelling on forums, I know you're probably frustrated with the lack of a clear answer but that's really because there are so many opinions and "experience" reports. I spent 30 years as a firefighter and one of the most common answers given by a victim of a fire about why he was doing what caused the fire; "I've always done it that way".....
That said I'm also a licensed A&P mechanic and that d*mn blue 100LL is possibly the worst thing that ever happened to full scale piston aircraft engines. 'Gotta burn more of it to keep the engine cool as it has much less lead than 100/130. Fouls the sparkplugs and the engines don't produce the same power especially the turbocharged versions.
While it's called "low lead", it still has a BUNCH more lead than any auto fuel.
I put some 100LL in a big Honda Goldwing one day to get me to the gas station and it was running like crap by the time I got there. When I got back and pulled the plugs they were all lead fouled.
I would NOT use it in my small air cooled gas engines because of my experience with the fuel, but if you want a fact to go by, DA will void your engine warranty if it's had AvGas run in it and they can tell when it's taken apart. So while it's not your engine brand, if DA doesn't like it in their engines that's certainly a valid recommendation in my book....
Zeeb
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> 100 OCTANE aviation fuel in gasser
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.515RCU1
