magnum XL 61 2 stroke carburateur problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> magnum XL 61 2 stroke carburateur problem
Page: [1]
Login
magnum XL 61 2 stroke carburateur problem - 3/18/2012 11:05 PM
yurdakut
Score: 100
Last Login: 4/7/2013
Status: offline
dear friends my magnum xl 61 's low speed needle spray bar is crashed...so can I use this  http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=13020
for replacement of my carburetor?or can you advice me a different solution?
Hide Signatures
       Post #: 1
RE: magnum XL 61 2 stroke carburateur problem - 3/18/2012 11:18 PM
d_bodary
Score: 100
Last Login: 5/22/2013
Status: offline
If you truly have a XL61 and not the XLS61 it will not work. You will need the carb listed for a ASP 91-108. I will try and get you the hobbyking part number in a couple minutes
_____________________________
I want my Six Dollars!!!!
Hide Signatures
(in reply to yurdakut)
       Post #: 2
RE: magnum XL 61 2 stroke carburateur problem - 3/18/2012 11:20 PM
d_bodary
Score: 100
Status: offline
It is the ASP 108 carb
part#
108A-91801X
$13.44
Hide Signatures
(in reply to d_bodary)
       Post #: 3
RE: magnum XL 61 2 stroke carburateur problem - 3/19/2012 9:25 AM
yurdakut
Score: 100
Status: offline
quote:
ORIGINAL: d_bodary
d_bodary first of all thank you for your intereset..sorry  my engine is magnum xls I have controlled again..so do you mean its( hk asp 61 carburetor for asp 61)for my engine?
Hide Signatures
       Post #: 4
RE: magnum XL 61 2 stroke carburateur problem - 3/19/2012 10:00 AM
asmund
Score: 111
Status: offline
Yes it will fit, ASP XLS .61 is the exact same engine as the Magnum XLS .61, just labeled differently.
Hide Signatures
       Post #: 5
RE: magnum XL 61 2 stroke carburateur problem - 3/19/2012 10:50 AM
yurdakut
Score: 100
Status: offline
dear friends thank you for your interest..
Hide Signatures
(in reply to asmund)
       Post #: 6
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> magnum XL 61 2 stroke carburateur problem
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
