RE: HK-450GT CCPM Alloy T-Rex compatible - Part II    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part II
Page: <<   < prev  45 46 [47] 48 49 50 51 52 53 54   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:12 AM
fleetz
Score: 100
Last Login: 9/10/2012
Status: offline
You leave Spiros alone he is mine!
Hide Signatures
(in reply to ingleburn)
       Post #: 1151
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:14 AM
ahamay
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: ingleburn
Ok guys here is something that I need an opinion on. It can be good, bad or ugly I dont care. Just your honest thoughts.
Im thinking about going FBL and these are the options.
Convert 1 of my 2 flying GT's
Build my half finished pro kit that I think is going to cause me grief as everything is so tight in the frame
Or purchase 1 of these and start from scratch with decent parts
www.rc711.com/shop/alzrc-450-sport-3g-flybarless-helicopter-frame-kit-p-5652.html  Like the look of this kit and includes the head which means I can use my already purchased  Tarot head 1 on another build
www.oomodel.com/tarot-450-v3-rc-helicopter-kitshaft-driven-edition-p-60789.html  Another nice kit and TT and will use the FB head on the GT
As you can see Im not sold on the pros but maybe there is a reason why I should go down this path.
@ Phil. I know there isnt an Align option but Im sure you will add it.
@ Spiros. Mate I didnt block you, and its good to see the advice you have been giving to Kozzy. But Im not doing a FBL $9 heli.
@ All.  Looking forward to your replies.
I converted one of my GT's using the Tarot V3 FBL head. Im not sure if you have an FBL head already ?  You can buy one of them from locally here including postage -> http://www.aust-rc-tech.com.au/gallery/Flybarless%2BParts/tarot-trex-450-flybarless-rotor-head-set-tl45109/74084
This will drop straight onto the GT swash.  You already have the ZYX so you don't need anything else.
I think once you decide to go FBL you won't want to be buying any FB heads or parts for FB any more.  If you convert one of the GT's and use whatever spares you have in case you crash the second one and once they are all gone convert it to FBL as well.
_____________________________
Tarot 450 PRO V2 FBL zyx , Tarot 450 PRO V2 FBL zyx-s , MCPx V2, Nano CPx
Hide Signatures
       Post #: 1152
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:24 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
Yeah Jonesy I already have a head and converting the GT would be the logical step. Thanks for the imput.
Hide Signatures
(in reply to ahamay)
       Post #: 1153
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:26 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: fleetz
The postage would be more than the parts.
Hide Signatures
(in reply to fleetz)
       Post #: 1154
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:28 AM
ingleburn
Score: 100
Status: offline
Just found this and I like. One thing that worries me is the laptop being so close to the heli and getting in the way. Not a problem now.  www.rcgroups.com/forums/showpost.php
Hide Signatures
       Post #: 1155
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:31 AM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
+1!
I just went a step further and to make damn certain vibration was at a minimum, I bought THIS!
Glad to assist in money flyin' from your wallet!
b
Align 500CF FBL, MCP X, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
       Post #: 1156
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:37 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
I looked into this and I think it's more of a pita than anything.  If you mount it on the heli you still need to plug and un plug it from the gyro when you want to use it.  Just get a USB extension cable from a $2 shop.
Hide Signatures
       Post #: 1157
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:38 AM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
Ain't that some "S"??
Shame my 6 year old lap top doesn't have blue tooth!
b
Hide Signatures
       Post #: 1158
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 2:54 AM
Rob2160
Score: 183
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: rikybob
quote:
ORIGINAL: ingleburn
Just found this and I like. One thing that worries me is the laptop being so close to the heli and getting in the way. Not a problem now.  www.rcgroups.com="" href="">www.rcgroups.com/forums/showpost.php
b
Ah my pal.... ....Try This..
at a price even a Scotsman can't resist...
..... frakkin cylons...
Hide Signatures
(in reply to rikybob)
       Post #: 1159
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 3:00 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: sgbfly
Hi Again,
I can't wait to try this new Turnigy HeliDrive SK3 Competition Series 3600kv brushless motor.  It arrived yesterday and first impressions are good!
Simon
Great video and nice looking motor. It looks exactly the same shape and size as the Scorpion motor I have sitting by for my next build..
Mine is "coggy" also.. I think that is the strong magnets??
Look forward to seeing it in in the air.. I really have to change hobbies again and get BACK to my Helicopters...
To dremel the flat spot on the shaft I put my motors into small plastic bags, Like these   I generally use two or even three bags inside each other and then just poke the shaft through far enough to dremel..
Absolutely NO chance of any metal shards getting into the motor that way.. works a treat..
Hide Signatures
(in reply to sgbfly)
       Post #: 1160
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 3:03 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: sgbfly
Trex 450 V2 Flybarless Conversion Videos
Hi Everyone, I've put together a video series describing the conversion of my HK-450GT to Flybarless. The videos are aimed at those considering their first FBL project and the videos are recorded in a build-along style.
Part 1 = Introduction
This is the first part of a 5 part video series describing the conversion of a HK-450GT (Align V2) helicopter to flybarless using a RJX type FBL head and the Tarot ZYX 3-axis gyro. This video is not technical and the actual build begins in part 2 where I will construct the rotor head.
Part 2 = Building A RJX type flybarless rotor head For A Trex 450
A detailed bolt by bolt build video of a Hobbyking RJX like flybarless rotor head (Product ID: DMDL-450FBL) for a 450 sized helicopter. The head will be used on a HK-450GT which is an Align 450 v2 clone. I'm sorry this video is so long & I'll try to improve and condense the following setup vids. That said, this video is ideal for someone to follow along as they build their FBL rotor head! (see notes below)
Additional Parts Required:
1) Main shaft and fixing bolts (or recycle the one currently on the helicopter or Align HS1280T for a V2 conversion)
2) 450 Pro Damper Rubbers (I use Leadershobby Product # 9394001225892) or Align part HS1291
3) Swashplate (Recycle existing or I used Leaderhobby # 9394001224608)
Optional Parts
1) Genuine RJX swashlocker arms, Hobbyking ID: HN70010 (These are a better fit to most swashplate ball linkages)
2) Pro Feathering Shaft, Hobbyking ID: GT450pro-143 (Better tolerances & screws than the one in the kit)
3) Tarot adjustable linkages (TL2639) - Great for fine tuning blade track & pitch
Tools Required
1) 1.5mm Allen Key (*2)
2) Ball Link Pliers
3) 4mm Hex driver
4) Vice (optional or something to press in interference fit bearings)
Sundries
1) Bearing or general purpose grease (for thrust bearings)
2) Silicone grease for the damper rubbers
3) Medium Threadlock
4) Stud-lock (optional for seating grip bearings)
5) Multi purpose oil (optional for pre-lubing bearings - I use Labelle 107)
Part 3 = Mechanical Installation
To complete this step you will need:
- Tarot zyx gyro, flybarless rotor-head and suitable cyclic servos (preferably digital and good quality)
- 1.5mm Allen Key (Hex key)
- Phillips #0 screwdriver
- Ball link Pliers
- Medium threadlock
- Cable ties
Optional Parts used:
- Align HS1074T Ball Links
- Hobbyking peel-n-stick foam tape (4mm) PRODUCT ID: ST-FOAM-DB
- CA glue and or hot melt glue (to complement the cable ties in wire tidying)
Part 4 = Installing the software and setting up the Tarot ZYX
Part 4 of the video series describing the conversion of a HK-450GT to flybarless. This part looks at radio settings and software setup. I decided to use John's excellent programming utility (www.fbl.net.nz) as it is more polished than the original Tarot version. John has worked hard to update, fix bugs and improve reliability over and above what Tarot have done with their version. I use a Turnigy 9x as the radio but the settings should translate to any programmable radio. A few other points to mention.
1) I had to split this video so my opening comment about having a maiden flight ready heli at the start of the vid is untrue. Part 5, which is to a finish, will follow within a day or so!
2) The sound sync is lost slightly during the scenes recording the desktop on the laptop.
Part 5 = Final Setup
In this video I refine the mechanical and software setup. The video demonstrates levelling the swashplate, setting the pitch range and setting the blade deflections. There is also some shake down testing and blade tracking adjustment followed by a look at the some of the advanced software tuning.
To complete this step some cable ties, snips (or scissors) and a pitch gauge will be required.
I hope this is a useful resource to those interested
Simon
Hi Simon,
Many sincere thanks for putting together this superb series of videos... I will definately refer to them when I get around to building an FBL Heli.
Cheers mate!.
Hide Signatures
       Post #: 1161
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 3:08 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
I have plenty of extension cables and a usb program dongle but its so gadgety and I love my gadgets.
Hide Signatures
       Post #: 1162
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 3:17 AM
fleetz
Score: 100
Status: offline
Hi Simon,
I am trying mirror what and where you have bought you FBL gear from. I already have these main shafts from HK would they be suitable for your FBL mod?  http://www.hobbyking.com/hobbyking/store/__11516__HK450V2_Main_Shaft.html
Regards,
Ian
Hide Signatures
       Post #: 1163
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 4:20 AM
Tinkman
Score: 100
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: aircrash
quote:
ORIGINAL: Tinkman
Hey Guys,
Finally had a chance to get a flight in today. A complete success... No Crash!
I did get a chance to chase a coyote for a bit. Kind of fun actually!
Video is posting now. Should be ready in a few minutes.
Joaquin
Hi Joaquin,
Nice flight. You seem very relaxed and not bothered from the visitor !
I had seen billions of squirrels in NY, they were everywhere! Here we have at the villages only. But not coyote !
BTW, squirrel has the origin of the Greek word σκίουρος, but once I saw so many in NY I thought it should be the opposite!
So, your LH GY520 got lost on its way and you use a GA-250 if I understood right?
Recently I bought another GA-250 to try as the first couple I had got were problematic. I have read about its bounce back problem but I hope I can use it with either the MD922 or the ES9257/8 servo and if it is needed to set the delay that the new batch has.
Get some more videos,
Spiros
Spiros; Ya, the coyotes don’t bother me much. I’m bigger’n ‘em! Plus I had a flying coyote extinguisher with me at the time 8-) Yep, I had ordered a GY520 but I didn’t want to wait for it so I installed a GA250 I had laying around. It does the same thing on the 500 as it did on the 450.
Phil; Yes, I was pleasantly surprised at how quick I got my thumbs back too. Not that I ever had a mastery of flying, but I wasn’t as rusty I as thought I’d be. It was a nice relaxing flight. I wanted to fly again today, but the wind kicked up again to around 30 MPH. Too much for me…
Ya, the coyote kind of surprised me too. I wasn’t expecting to see him there, just a pissed squirrel! On the way into work this morning I saw two of them wondering around near the shop. They must be loving those squirrels!
Joaquin
Belt CP V2, HK 450 MT HK 500 CMT
Futaba 7C Tx, GY520 Gyro, S9257 Tail Servo
Hide Signatures
(in reply to aircrash)
       Post #: 1164
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 4:55 AM
Rob2160
Score: 183
Status: offline
Inspired by Simon's vids and the pace of this thread, this morning I pulled the original 450 GT out of storage (after six months) and refitted the main blades and labelle lubed everything. .
Took it for a quick flight a few minutes ago.
Wow, I had forgotten what a nice refined smooth and stable helicopter it is. . . Quark equipped also and my fastest heli in forward flight..
It was wonderful to fly her again. Tame by comparison to my highly tweaked 450 pro workhorse but so nice and relaxing. .
I'll get some new vids up soon.
Hide Signatures
(in reply to Tinkman)
       Post #: 1165
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 5:21 AM
aircrash
Score: 100
Last Login: 4/20/2013
Status: offline
Ian, I would say you stay flybarred for now. You have the gear be ready waiting for you to practice a lot with the coaxial, SIM and mCPX (harmless, almost) so to get the thumbs working, learning orientation and such.
By the time you`ll start attempting with the 450 newer FBL gear will be available. Better and cheaper. This is the rule, I hope there is no exception to this.
As the 450s are quite dangerous I would not rush to get to them. It would be also better if you had an easy to fly bird outdoors to practice.
Also as a beginner you`ll crash the bird will get some vibrations that the FBL unit won`t like, unlike with the gyro that will be easier to spot and fix.
I chose to go flybarred cause it is cheaper so I could have more than one bird and cause it was mature. I wanted to stay away from baby problems of the FBL systems, like some who have found that the first generation Align 3G did not made them happy.
Also I`m not so convinced a FBL would be easier for me in theoretical manner, but I don`t have one to compare.
Ingleburn, if you want to go FBL then why buying an FB kit? The Sport is nice and more forgiving with its belt. Take an FBL Sport.
Modified BOL chassis www.rcuniverse.com/forum/fb.asp?m=9422710
brushless mod www.rcuniverse.com/forum/fb.asp?m=9460961
Hide Signatures
       Post #: 1166
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 7:00 AM
Edmund2
Score: 100
Last Login: 5/17/2013
Status: offline
Brian, you will love this one.  Mrs E asked what I would be buying as a from me to me with my incentive bonus as the 550E bought last year has only flown 3 times that she is aware of and hope that it is not  another helicopter. So off to the gun show I go and returned with an automatic powder dispenser as well as a "sealed" box containing a "new"  mCPX., with 6 lipos, lots of parts and blades. "Bound' it to the DX6i charged it and then showed her how the little one flies inside the house.
She wants one too!!!!!.
Edmund
BTW. Shawn, I did a sub MOA with the .50 cal muzzleloader from 100 meters, 3 into 1 jagged hole
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
       Post #: 1167
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 7:55 AM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: fleetz
Hi Simon,
Regards,
Ian
Hi Ian,
Yes, they will be fine.
Simon
FBL FTW!
Hide Signatures
       Post #: 1168
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 8:48 AM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
I hope you were just unlucky and got a dodgy one of those INO-LAB servo's and it's not going to be a trend with them.
Yes me too!  In all seriousness there are enough positive reviews out there to suggest it was just bad luck.  I pulled the offending servo apart and all the circuits checked out except for a lifeless motor.  I'm not too bothered about it at this stage but if it happens again....
FBL FTW!
Hide Signatures
       Post #: 1169
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 9:12 AM
aircrash
Score: 100
Status: offline
Unfortunately Simon all things can fail. No matter how much they cost. Not in RC parts but in everything is out there.
I would not be surprised if an Align servo died, Futaba do as well, neither if it was a Savox.
In my previous post I said I went flybarred cause they are cheap and could have many.
Forgot to add that I wanted a cheap platform so even if it crashes I will not have to pay a lot.
So no branded, and no FBL as it costs a lot more. That`s why I have not started with the Blade 450 as well.
So a servo dies midflight, bye bye good Align super combo.
An FBL servo dies, costs at least 7 times more than one suitable for FB.
If it fails after some use you must conclude that it is time to change all three of them as they may have started wearing out, so the cost raises to at least 21 times more.
But that`s the game.
Some other enjoy the cheap, other the better performance.
Hide Signatures
       Post #: 1170
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 10:25 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Edmund
Now you do really need to hide the other one or else you will be in trouble. Or else box the new one up, give it to her then drag the other one out.
Hide Signatures
(in reply to Edmund2)
       Post #: 1171
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 10:50 AM
aircrash
Score: 100
Status: offline
It happened again !
The new joke of some unreliable ebay sellers that sell LH parts.
Bid an item and again after I won it and they had not marked it as shipped I asked and got a reply that the item is (supposed to be)  faulty and cannot be sent.
What a joke. I`ll quit messing with them. They are ridiculous. They could set a desired low price or set a logical buy it now price.
They just try to fish some fools that bid and bid again with no ending.
The bad thing is ebay gives the right to them to do so. But ebay should had set a limit of such actions (they earn money though if it is sold, the more a seller sells the more they earn).
If one such seller sends a request to cancel the transaction do not cancel it. They just want to take back the ebay fee of the sold item. Just get your money back and leave negative feedback.
Hide Signatures
       Post #: 1172
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 11:27 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: sgbfly
Hi Again,
Simon
That's a nice looking motor and reasonably priced as well.  Be interesting to see how you go with it.
Jonesy
Hide Signatures
       Post #: 1173
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 11:45 AM
Edmund2
Score: 100
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: Edmund2
Edmund
Nope all the same one, had the Blade box in my office and just moved the wooden wine bottle "hanger" to my car before I left for the gun show then packed it in there. After the crash it was rebuilt and looked new, thus the "new" indication. She did not see me flying it on the farm before as my car is parked in the shed and the wooden box contains "gun" goodies as far as she was informed. Many trees and other buildings in the way.
Hide Signatures
       Post #: 1174
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/3/2012 11:54 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: Edmund2
Edmund
Hide Signatures
       Post #: 1175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
