RE: HK-450GT CCPM Alloy T-Rex compatible - Part II    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part II
Page: <<   < prev  47 48 [49] 50 51 52 53 54 55 56   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 2:46 AM
ingleburn
Score: 100
Last Login: 6/20/2013
Status: offline
quote:
ORIGINAL: rikybob
Here are some tuning tips!
b
Thanks Brian, hope I can keep that in the memory bank.
Hide Signatures
(in reply to rikybob)
       Post #: 1201
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 3:16 AM
Flying Fiz
Score: 100
Last Login: 5/30/2013
Status: offline
Its EFWOSR here, Enraged Former Walkera Owner Seeking Revenge.
EFWOSR hunted down the main Walkera distributor in HK, they are in the seedy back blocks of Kowloon, just near the live fish and dead duck markets, in fact it's the RC industry district of Hong Kong and is called "Szit Tat Tings Phast".
EFWOSR bravely stormed through the front doors of Walkera in Szit Tat Tings Phast district, he whipped off his shirt (which is usually a good thing to do here with 30 degree temps and 100% humidity) and showed the reasonably attractive female receptionist the scars on his shoulder and back from the Walkera 500D01 FBL heli that attacked EFWOSR due to its faulty 3G unit.
Initially EFWOSR thought she was simply overcome by his incredibly buff body and she was speechless with joy and rapture, and so he bravely pushed on and demanded a brand new Walkera V500D01 BUT with a BeastX FBL unit instead of their crap 3g Units.
EFWOSR should have stuck to just the heli and not with the BeastX as he's sure that's what pushed her over the edge. EFWOSR also thinks he may have misjudged the rapture thing as well.
As reasonably attractive female receptionist started to dial the local equivalent of 911, EFWOSR thought he should have stuck with the more simple stone throwing plan.
EFWOSR was last seen running between the bright orange ducks hanging up side down everywhere.
He successfully alluded everyone, if anyone was following that is.
Yours EFWOSR,
_____________________________
Lots of Planes, (no trains or automobiles), and lots of helis and not enough flying time!
Hide Signatures
(in reply to ingleburn)
       Post #: 1202
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 3:35 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Flying Fiz
Yours EFWOSR,
Hahaha well Ive given them your mobile number so they can track you. You aint getting those helis back without a fight
Hide Signatures
(in reply to Flying Fiz)
       Post #: 1203
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 4:32 AM
fleetz
Score: 100
Last Login: 9/10/2012
Status: offline
MWWWWWWWWWWWAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHH ! I just pi*sed my pants........
Yours EFWOSR,
Hide Signatures
       Post #: 1204
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 7:22 AM
fleetz
Score: 100
Status: offline
Thanks Jonesy,
Went to order the Align bearings from Zeejays and sold out. Inglebum I reckon has cut me off at the pass!
Cheers,
Ian
The align bearings you mentioned in your blather where do you get yours from. I am following the bouncing balls of what I know works. Already order from Simons list might as well order evrything that is qualified so I can put a crash down to pilot error and not blame the build!
Ian
[/quote]
Ian, I can highly recommend you purchase any align or blade parts from ZeeJay Hobbies.  They are near brisbane on the way to the sunshine coast.  There customer service is exceptional.  http://www.zeejayhobbies.com.au/
Jonesy
[/quote]
Hide Signatures
(in reply to ahamay)
       Post #: 1205
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 7:27 AM
aircrash
Score: 100
Last Login: 4/20/2013
Status: offline
Well, as I fixed the tail to the #1 bird now I`ll change only the tail blade grips to the #2 bird.
Again with the $9 kit`s tail blades but with the new batch ones, that have bearings instead of bushing.
I`m pretty sure it will have a rock solid tail.
The 450 $9 Sport runs smooth. No vibrations at all. I could put a cigarette on it and stay put.
The LH GY520 is stuck with just a piece of 3M automotive double sided tape, about 1.5mm thick, and there is no drift or wag.
Of course I must test it to forward flight.
The other $9 birds run also smooth.
Brian, as I have seen many videos with the ZYX all of them have a tail wagging problem. All of them wag just a little and so fast.
It must be the sensors or the software. Most probably both.
It can`t be the servo as then no servo would be good as there is so many videos from different owners and the same behaviour.
I`ll wait till I go to flybarless.
Newer units will be better (and cheaper) and till then I can use cheap cyclic servos. Anyway, I have not enough hours on CP to want the "better" stuff.
Wait for your both bird`s maiden flight video !
quote:
ORIGINAL: ingleburn
Speaking of these servos, I found a case for my broken 9257.  cy-model.com/Futaba-S9257-Case-Set-FUAS4143-0518.htm
Better than paying $19 for a new servo.
Have you bought one?
Good if it fits. Servo`s tabs break quite easily in a tail boom strike. I would use epoxy if I found none but if it fits then that would be nice.
Modified BOL chassis www.rcuniverse.com/forum/fb.asp?m=9422710
brushless mod www.rcuniverse.com/forum/fb.asp?m=9460961
Hide Signatures
       Post #: 1206
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 7:38 AM
ahamay
Score: 105
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: fleetz
Thanks Jonesy,
Cheers,
Ian
Ian
Try perthrc.com.au.  I havn't ordered from them but word on the street is they are pretty good.  They have everything Align.
Tarot 500 FBL ZYX-S, Tarot 450 PRO V2 FBL ZYX , Tarot 450 PRO V2 FBL ZYX-S , MCPx V2, Nano CPx
Hide Signatures
(in reply to fleetz)
       Post #: 1207
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 7:51 AM
Flying Fiz
Score: 100
Status: offline
Another shop for the Aussies is this one;
http://www.wattsuprc.com.au/
I have purchased quite a bit from them and all good. First the DFC and now the new Align tail system, check it out on Wattsuprc 's webpage (item 3 on the advertising on the home page) looks neat.
BTW I think they have the DFC heads in stock.
Phil.
Hide Signatures
       Post #: 1208
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 7:56 AM
Flying Fiz
Score: 100
Status: offline
BTW, don't forget if you are buying the new Align FBL DFC heads you need to have Align feathering shafts thrust bearings as the kit doesn't .
Be careful when ordering as the Align feathering shafts come in various configuration, so if you dont see a DFC feathering shaft I would get the Pro version.
Wattsuprc is in Sunnybank QLD.
Hide Signatures
       Post #: 1209
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 8:21 AM
fleetz
Score: 100
Status: offline
Yep me too and I am 4 weeks off being a Grandpa!
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: rikybob
A "Disco Nap" is what folks did in the '70's after working all day and before partying all night they took a short "Disco Nap".
Our local pilots (real ones) who fly for the agency refer to it as a "Safety Nap"!
Will mail that Gyro out tomorrow!
All the best!
b
In Australia we call it a Grandpa nap. Been guilty of taking a few of them.
Hide Signatures
       Post #: 1210
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 8:25 AM
Flying Fiz
Score: 100
Status: offline
Hey Brian,
Congrats on getting the 450 sorted it looked and sounded smooooth as buddy.
But I need you to now let yet another moth free.
I notice that you have Align fibregalss mains on the bird. And for fishtakin they are great, but I did notice a difference in responsiveness, better control and more pop with the FBL (or 3G) Align blades. So for a mere $17 and I'm sure you could get them cheaper, they are well worth it. I think the Tarot 3G blades are $15 or maybe $12. They have different stiffness and weighting. You will notice the difference in just normal sports flying.
Best,
Phil.
Hide Signatures
       Post #: 1211
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 8:44 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Unfortunately I've been back at work this week and with the amount of stuff that's broken and I need to fix I've had no time at night to play Heli's as I've been too tired...damn.
I'm all excited now as I have evrything to finish the built of my Tarot 450 PRO V2 (The same one that Phil put into the scale fuse).
I'm going to use the new Tarot ZYX-S with a satellite rather than a full range reciever.  We'll see how that goes.
Jonesy
I havent heard of anyone doing that yet so looking forward to seeing how it goes.
Well after a lot of reading I'm going to skip the satellite on the ZYX-S and use my genuine spektrum AR7000 rx with Satallite for now.  There is a bit of confusion on how to bind and set the right DSM mode etc.  I don't want any issues with this new Tarot 450 PRO FBL.  I'll wait untill there is concrete evidence that it works and the steps to set it up.
Hide Signatures
       Post #: 1212
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 9:11 AM
aircrash
Score: 100
Status: offline
Hey Brian,
Best,
Phil.
Hi Phil,
Anyway I see Brian have even an Align neckstrap in the near future.
A good thing his LHS can have. A person with the enthusiasm, money, skills, passion of Brian.
Good to see more and more people have the money for Align.
Bad for others who expect to find a similar component at an affordable price.
As there are must be left such ones, as if there were no affordable birds there then there would be even less Align owners.
Go get them (Walkera)
PS. I hope you didn`t made a deal to get about a dozen of more birds there! You must stop before you hit the number of my fleet.
Spiros
Hide Signatures
       Post #: 1213
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 9:49 AM
Flying Fiz
Score: 100
Status: offline
Hiya Spiros,
I've stopped counting my helis, mostly ex helis now, but I can safely say I've had more helis than you have had taramosalata and Souvlaki put together.
When I count co-axials, various sorts of fixed pitch (a complete waste of time in my opinion) and CP helis the count would be more than 30, maybe more than 40.  I still have lots of skeletons laying about in the garage in boxes with busted blades, heads, frames etc etc. and I have sold all those that were still in good working order.
There actually is a decent RC business area in Kowloon and I might even have a walk through there tomorrow, I'm suffering HWS* already.
best,
Phil
* Heli withdrawal syndrome
Hide Signatures
(in reply to aircrash)
       Post #: 1214
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 10:15 AM
aircrash
Score: 100
Status: offline
I was just kidding,as if I was there then I would increase the number of my fleet by a lot.
But kidding aside without counting the 3ch ones I still own the number you said.
Only that my most expensive one is the Blade 450.
I like cheap, like many.
Ask my wife ! Thanks God she has a lot of understanding ! Or tries to have.
< Message edited by aircrash -- 5/4/2012 10:36 AM >
Hide Signatures
       Post #: 1215
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 11:35 AM
sgbfly
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: ahamay
Here's a prime example of crap quality parts.  These are the Tarot reverse thread adjustable rotor head linkage rods for FBL helis.  The ones that Simon is using in his FBL videos. I ordered a few of these with some spares for the Tarot 450 PRO FBL.  The hole has been drilled off centre and punched through the side wall.  Smallest amout of pressure and they bend like paper.  Nice try fail Tarot.  I do however have two good sets of these that came with my Tarot V3 head and the 450 PRO fbl head so Im guessing it's a bad batch. If i wanted to put my engineering skills to work I could fill the hole with JB weld and adjust them with a set of pliers .
Hi Jonesy
Sorry to see that.  There is a better quality alternative by Xtreme with product code EA-045 whixh I have used in the past.  They are a little more expensive at nearly $10 a set.  Amongst others Miracle-mart sell them which is one of the best overseas hobbyshops.
The one fault I had with the Xtreme parts was sometimes the plastic link rod ends were a little loose but because I have plenty of others I never saw it as a problem (eg Align HS1074)
Simon
FBL FTW!
Hide Signatures
       Post #: 1216
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 12:03 PM
Edmund2
Score: 100
Status: offline
Brain, I had those naps too, in the timeframe you mentioned. Could give John Travolta a go in my time on the disco floor, today my hips are killing me.  Danced on Saturdays to get comp tickets for Wednesdays to get comp ticktes for Friday, to get comp tickets for Saturday. Eventually had a reserved table next to the dance floor and just walked in without tickets.
Anyhow do have some flying planned for tomorrow as to what and where is still to be decided, will NOT be a BOL though.
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
(in reply to sgbfly)
       Post #: 1217
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 12:49 PM
aircrash
Score: 100
Status: offline
Hi Edmund,
Good you have the mCPX flying home.
I think you have a Spektrum radio or something? Why don`t you buy an Orange RX610 to convert the Belt-CP ?
I think it`s one of my favourite things from Hobbyking. There are not many, but there are some things I find nice there.
Now I must find a motor. Not something powerful but rather not power hungry.
I have all the other parts to make one more 450.
I could buy just one more Esky 4200KV but I don`t know why, most probably just to know what else I can buy, I say to try either a Hobbymate or Turnigy or Tarot motor.
Maybe I should give a try to the Hobbymate as I already made an order and did not added the Turnigy.
Have some good flights tomorrow and have some fun,
Spiros
Hide Signatures
(in reply to Edmund2)
       Post #: 1218
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 1:22 PM
Edmund2
Score: 100
Status: offline
Spiros, I have thought about matching my DX6i with the Belt CP as it would make flying it so much easier. The stock E-Sky TX is a dog but I eventually got to grips with it after spending many hours trimming it for a straight up lift without any input but throttle.  Have not chrashed since.
Enjoy your weekend.
Edmund
Hide Signatures
       Post #: 1219
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 3:30 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Jonesy
Yeah I would hate to see you trash it on the first flight. Stick to what you know works and let someone else blaze the trail.
Hide Signatures
       Post #: 1220
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 3:32 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: fleetz
Thanks Jonesy,
Cheers,
Ian
Ian
Jonesy
Hahaha I only bought a couple of sets. Did you try  revolutionrc.com.au/bearings/cat_114.html
Hide Signatures
       Post #: 1221
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 3:40 PM
fleetz
Score: 100
Status: offline
Thanks mate....Jeez it is like a Chinese menu.....
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: fleetz
Thanks Jonesy,
Cheers,
Ian
Ian
Jonesy
Hide Signatures
       Post #: 1222
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 4:20 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: fleetz
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: fleetz
Thanks Jonesy,
Cheers,
Ian
Ian
Jonesy
If you need to find the part numbers look here  www.hobbyking.com/hobbyking/store/uploads/375648423X4838X25.pdf
Hide Signatures
       Post #: 1223
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 4:59 PM
fleetz
Score: 100
Status: offline
Thanks mate got the right part number. The manual is an excellent reference....got that save away now.
Don't work too hard..
Regards,
Ian
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: fleetz
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: fleetz
Thanks Jonesy,
Cheers,
Ian
Ian
Jonesy
Hide Signatures
       Post #: 1224
RE: HK-450GT CCPM Alloy T-Rex compatible - Part II - 5/4/2012 6:13 PM
Rob2160
Score: 184
Status: online
A couple of recent flights...
..... frakkin cylons...
Hide Signatures
       Post #: 1225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
