just a quick question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> just a quick question
Page: [1]
Login
just a quick question - 3/22/2012 2:27 PM
Shady9503
Score: 100
Last Login: 5/22/2013
Status: offline
 Hey guys so i have a quick question, when i block my exhaust to shut off my buggy (tornado S30) it just keeps on running lol car runs great and i love it but im assuming i have a leak somewhere? and im having trouble getting the engine primed when i block the exhaust aswell
_____________________________
Tornado S30, Earthquake 3.5, Hurricane XTR
Hide Signatures
       Post #: 1
RE: just a quick question - 3/22/2012 2:47 PM
bigblueford
Score: 100
Last Login: 12/25/2012
Status: offline
I agree, does sounds like you've got a leak.  First place I would check would be the little blue rubber coupling between the exhaust header and muffler.  It shouldn't have any holes or tears in it.  It should two tie-wraps, one to clampit to the header and one to clamp it to the muffler.
Also check to make sure the header flange screws are tighten down.
Redcat Caldera 10e MT
Redcat Twister XTG Pro ST
Hide Signatures
(in reply to Shady9503)
       Post #: 2
RE: just a quick question - 3/22/2012 3:34 PM
Shady9503
Score: 100
Status: offline
hey well i know its not that rubber coupling cuz i changed it the other day for that exact reason lol had a tear in it :P
 but the header flange screws? im not exactly sure what those are? ive only been in this hobby a year but im obsessed lol getting my next RC this monday also could a bad manifold gasket be the cause aswell?
Hide Signatures
(in reply to bigblueford)
       Post #: 3
RE: just a quick question - 3/22/2012 3:39 PM
bigblueford
Score: 100
Status: offline
There are two small screws that attached the exhaust header to the engine block, your manifold gasket goes between the header manifold and the engine block, so the two screws I'm talking about also hold the manifold gasket in place.
Hide Signatures
       Post #: 4
RE: just a quick question - 3/22/2012 3:46 PM
Shady9503
Score: 100
Status: offline
 ahhh ok i see what your talking about, yess i know those screws i tightned them myself a week ago but i think i did it too much and might have wrecket that gasket, could that be my problem? also missing one screw from my pullstart must have lost it bashing and now theres a small opening
Hide Signatures
       Post #: 5
RE: just a quick question - 3/22/2012 4:11 PM
bigblueford
Score: 100
Status: offline
Missing pullstart screw won't cause the leak, but should be replaced.  Sounds like maybe you should retighten all the nuts and bolts.  Get yourself some blue locktite and use it on the screws to help hold them tight for a longer period time.  Go thru the entire car and remove one screw at a time, put blue locktitre on it, and reinstall snuggly.  Be careful not to over tighten and strip out the hole.
Remove the muffler, hold your finger over the exhuast pipe, and blow into the end with the rubber coupler.  It should not leak air.
Hide Signatures
       Post #: 6
RE: just a quick question - 3/22/2012 5:23 PM
Shady9503
Score: 100
Status: offline
Thanks for your help
ill do everything you just said and let you know!
Hide Signatures
       Post #: 7
RE: just a quick question - 4/3/2012 12:38 AM
allenmiller25
Score: 100
Last Login: 4/3/2012
Status: offline
check for a air leak around the pinch bolt that holds the carb on i beat my self to death for three weeks with a redcat caldera that was leaking air
Hide Signatures
       Post #: 8
RE: just a quick question - 4/3/2012 1:25 PM
Shady9503
Score: 100
Status: offline
 Thanks for all your help guys! i found the leak the gasket from the engines exhaust port to the manifold was pretty much disintegrated :P i changed it and everythings good she runs like a dream
Hide Signatures
(in reply to allenmiller25)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.282RCU1
