Need help identifying gas engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Need help identifying gas engine
Page: [1]
Login
Need help identifying gas engine - 3/24/2012 6:49 PM
jetfixr
Score: 100
Last Login: 5/12/2013
Status: offline
I picked up this gas engine at an estate sale recently, but I have no idea what it is. Can anybody identify this engine? Thanks for your help
Jeff
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Need help identifying gas engine - 3/24/2012 6:51 PM
spaceworm
Score: 143
Last Login: 5/19/2013
Status: offline
Looks like a Quadra to me, but the size escapes me.
Hide Signatures
(in reply to jetfixr)
       Post #: 2
RE: Need help identifying gas engine - 3/24/2012 7:04 PM
jetfixr
Score: 100
Status: offline
Maybe. The only things written on it is the number "82" stamped on the back of the cylinder, "Made in Canada" stamped on the bottom of the crank case, and "Made in USA" on the front of the magneto. It has a Walbro carb, and has "RT" stamped on the piston seen through the exhaust hole. Thanks for the input!
Jeff
Hide Signatures
(in reply to spaceworm)
       Post #: 3
RE: Need help identifying gas engine - 3/24/2012 8:01 PM  1 votes
tkg
Score: 657
Status: offline
Quadra 35/42
_____________________________
TKG
Too much power is just about right.
Hide Signatures
       Post #: 4
RE: Need help identifying gas engine - 3/24/2012 8:23 PM
jetfixr
Score: 100
Status: offline
Do you know any measurements I could take to confirm one?
Hide Signatures
(in reply to tkg)
       Post #: 5
RE: Need help identifying gas engine - 3/25/2012 1:43 AM
ahicks
Score: 669
Status: offline
I agree, Quadra/US engines. The fact there are no points makes it a later engine I believe, probably a 41/42
Hide Signatures
       Post #: 6
RE: Need help identifying gas engine - 3/25/2012 2:35 AM
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: jetfixr
Displacement = piston area X stroke
Hide Signatures
       Post #: 7
RE: Need help identifying gas engine - 3/25/2012 2:41 AM
jetfixr
Score: 100
Status: offline
Thanks for your help, but I know the displacement method. I was mainly thinking of muffler bolt spacing, weight, or some other identifying measurement. I will try to do the displacement though. Thanks,
Jeff
Hide Signatures
       Post #: 8
RE: Need help identifying gas engine - 3/25/2012 3:05 AM
jetfixr
Score: 100
Status: offline
Ok, I took spaceworm's advice and tried to measure the displacement. Without taking the engine apart I measure the displacement at 32.5cc's which I would assume would be a Quadra 32. Thanks for the input everyone.
Jeff
Hide Signatures
       Post #: 9
RE: Need help identifying gas engine - 3/25/2012 3:14 AM
w8ye
Score: 318
Status: online
They only made a 35 and the 41/42 in these sizes
< Message edited by w8ye -- 3/26/2012 12:20 AM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 10
RE: Need help identifying gas engine - 3/25/2012 3:25 AM
jetfixr
Score: 100
Status: offline
Ok. After looking at some pictures I am betting it is a Quadra 35. Like I said, I didn't take anything apart just took out the spark plug for measurement, so I am sure I was off a little. Thanks for setting me straight!
Jeff
Hide Signatures
(in reply to w8ye)
       Post #: 11
RE: Need help identifying gas engine - 3/25/2012 1:55 PM
ec121
Score: 130
Status: offline
The spring starter is also missing.
Hide Signatures
       Post #: 12
RE: Need help identifying gas engine - 3/25/2012 6:29 PM
northiceman
Score: 100
Last Login: 4/21/2013
Status: offline
Might be a chainsaw engine with some REAL aircraft engine parts - I have seen some very nifty and good performing engines in this category. Who would have the time to do all the work is a totally 'nother subject !
Hide Signatures
(in reply to ec121)
       Post #: 13
RE: Need help identifying gas engine - 3/25/2012 6:58 PM
rangerfredbob
Score: 115
Last Login: 5/16/2013
Status: offline
yeah, I say conversion also with as dirty as it is, and the carb adapter with the extra plastic. The Quadra's used chain saw cylinders anyway, didn't they? Either way it looks like a chainsaw conversion and they are usually ported decent
Hide Signatures
(in reply to northiceman)
       Post #: 14
RE: Need help identifying gas engine - 3/25/2012 8:44 PM
chris923
Score: 130
Status: online
It is a Quadra 35, I have serveral.
Chris923
Chris923
(Capt. Cluck) Screamin'' Chicken Squadron
The Flying Electrons
Meno. Falls, Wisconsin
Hide Signatures
(in reply to rangerfredbob)
       Post #: 15
RE: Need help identifying gas engine - 3/25/2012 9:13 PM
Rodney
Score: 169
Status: offline
While somewhat heavy for their power output, those old Quadras are a very reliable and robust power plant. Once set up they seem to run forever with little or no further adjustment If you have a big enough airframe, you will find that engine quite adequate. I have some that are at least 10 years old and still performing perfectly.
Hide Signatures
(in reply to chris923)
       Post #: 16
RE: Need help identifying gas engine - 3/26/2012 2:34 AM
jetfixr
Score: 100
Status: offline
Thanks for all of the input everyone! I believe it to be a Quadra 35, or something very similar. I plan to put it on a 9' span Nosen Citabria. It should be plenty of power.
Jeff
Hide Signatures
(in reply to Rodney)
       Post #: 17
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Need help identifying gas engine
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
